Question about Husqvarna 22 hp 42" Yard Tractor YTH22V42
Husqvarna 42" Yard Tractor YTH1542XP rear fuel line leak
I have fuel line leak near the fuel tank. Looked and it's in a hard to get to location. Without taking the entire seat assembly off & the mower deck, I'm trying figure what has to come off to replace it. I guess I need to replace the line from the tank to the fuel filter. Level: good mechanical ability. Thanks!!
  • Husqvarna Master
  • 2,478 Answers
Been looking the parts diagram, it shows 1 line on the tank. Need to replace line.
Posted on Nov 26, 2013
  • 48 Answers
SOURCE: husqvarna yard tractor
give the model number of the tractor to any dealer - they should keep key switches in stock
Posted on Oct 21, 2008
vincob
  • 718 Answers
SOURCE: was mowing right along and the mower deck just
Check your drive belts first see what happens.
Posted on Aug 30, 2010
SOURCE: Disconnecting/bypassing the seat safety switch
I want to disconnect the seat shut off switch on my Husqavna 25 hp lawn tractor
Posted on Oct 20, 2010
SOURCE: husqvarna 7021 kohler 173cc looks like its leaking
The carburetor probably needs cleaning -- the float is sticking.
Charlie
Posted on Jan 07, 2011
  • 407 Answers
SOURCE: My Husqvarna lawn tractor deck will not engage
First check the belt.Make sure it is tight when the lever is engaged,and the engine is off.Make sure the belt is on all pulleys,and inspect for frays in the belt.If the belt is ok then,run your hand under the fender around the area of the lever.Make sure there is no debris blocking the lever from fully engaging.If that is good.Next inspect the linkage between the lever`s handle and the deck.Again make sure there is no debris and all connections are snug.
Posted on May 16, 2011
How do l connect part 532170201 or what part does this connect to and what is it for
It is the transmission bypass rod. It used to the transmission in neutral so can push the mower around with engine not running.
Feb 01, 2015 | Husqvarna Lawn Tractor Yth1542xp Owners...
Mower shuts off after running about 5 minutes. i blew thru gas line towards tank and seemed like there was resistance tnen it opened up. ran another 5 minutes and same thing happened . model is husqvarna...
Check the fuel tank cap. It needs to let air into the tank and has a small hole to enable this. Try running the engine with the cap loosely in place to verify this is the cause. If you can't clean it get a new one.
Jul 01, 2014 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I have husqvarna yth1542xp runs about 5 minutes then shuts off. iblew thru gas line towards tank seemed like something was in line or tank. started and it ran another 5 minytes or so and same thing...
Try it with the fuel cap loose ( not off just loose). This will see if the tank is venting properly. You may also have a bad fuel filter, fuel lines or trash in the tank.
Where is the fuse holder on a Husqvarna YTH22V42 (42
they are taped to the harness and most below the battery or fuel tank what ever way its set up
Jun 28, 2012 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
Tractor won't start. Acts fuel starved. I see very little fuel in the filter which is new. I suspect the fuel pump assembly is bad. Any easy way to test the pump? 20hp Kohler engine.
you can to this in two ways. pull the out put hose off, turn the engine. be vary careful, to see if fuel comes out. or do a pressure test about 3 to 5 pds. check the tank. I have seen flays and other ?? in the tank plugging the lines. blow air throw the lines (not the pump)
Oct 13, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Blowing fuses
try unplugging the pto, starting the mower and then engaging the blades. If it still blows a fuse the problem lies in the mowers wiring. If not the problem is the pto. Hope this helps
Jul 13, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Possible leak in a fuel line?
likely is a fuel line as your fuel pump is located in the gas tank... as it's is under fairly high pressure you should get it fixed as soon as you can
Apr 15, 2009 | Buick LeSabre Cars & Trucks
My husqvarna GTH2448T has to be choked to run
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes.
Oct 06, 2008 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna 22 hp 42" Yard Tractor YTH22V42 Logo
159 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
