Acoustic solutions LCD32762HDF suddenly blue screen and 'No Signal' message and 5 miute countdown. Signal OK as have tested co-ax with smaller tv.
Was working OK. Changed channel and NO Signal message appeared with 5 minute count down to auto power off. Co-ax OK as have tested with smaller tv and signal OK.
  • Chris Stevens
    Chris Stevens Nov 26, 2013
    Problem solved. Caused by my mother pressing wrong buttons on remote.
HDTV GURU
  • 261 Answers
SOURCE: need help installing subwoofer
Just run "RCA" cable to sub and split off to both L&R with y adaptor and hookup to suboutput on receiver and plug into outlet and you should be a bangin then. GOOD LUCK. GURU JAY
Posted on Mar 22, 2008
  • 374 Answers
SOURCE: "No Signal" but aerial working ok on other tv in house!
Your son more than likely changed the input source. You may be able to change it back by pressing the channel up/down button or you may have to enter the menu on the tv and change inputs that way. PS's will usually connect using a video input using a red/white/yellow cords. You may also want to ensure the connections are in their proper place as I do not know how savvy your son is at changing the setup over to play his PS. If you use a modulator to connect to the TV-either the PS or aerial- ensure that it is powered up also. I hope this has been of assistance to you and thanks for using Fix Ya. If I can be of further assistance let me know.
Posted on Oct 08, 2008
SOURCE: 37" Polaroid LCD TV No signal appears when select channel
I was having same problem, and think I got lucky and found fix.
Try unplugging the TV and waiting 30 seconds, then plug back in.
You will likely get blue screen with "No Signal".
Go to Menu, then scroll down to "Setup". Select "Factory Reset" then hit "Yes."
This did it for me. Wish you all luck.
Posted on Dec 03, 2008
full str pka
  • 14 Answers
SOURCE: no signal and blue screen
hello
i think you might have a blue screen of death on your tv
--full str pka
Posted on Dec 31, 2008
  • 10 Answers
SOURCE: VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
Posted on May 23, 2009
Acoustic solutions tv screen flashing coulour blue red and green what is the problem and how to solve me help please i need help
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
These flashes are fault indications, called blinking codes.
May 22, 2014 | iLO 3200 32 in. LCD Television
My sharp aquos has gone to a blue screen and message saying not supported, why has it done this?
Suddenly it is plugged into what? The TV only works when a signal is sent to it. The TV is probably fine, but of course it's the messenger. Must be where the problem is.
May 04, 2014 | Televison & Video
Have purchased new 37" toshiba.
Check the lead from the lounge to the bedroom is connected correctly. The blue screen means no signal.
Jan 01, 2011 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
Acoustic solutions tv lcd32762hdf will not turn on
Power Supply board is dead.Replaced the power supply board.Tries these websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 17, 2010 | Broksonic CCVG-3276 32 in. LCD TV
Bush lcd tv has sound but no picture when switch on tv screen is blue then goes black and you can hear the proggramme that is on
acoustic solutions lcd tv when i switch it on the screen flashes blue, green then red no picture??? it was working ok last night any ideas?
Jan 23, 2010 | Polaroid FLM-2632 Television
I have a tv sky box in lounge and 2nd tv in a different room connected by a co ax cable. I need a desription or a diagram to get everything working. It worked prior to having a new carpet fitted and the...
Check first that the Co-Ax cable is firmly plugged into your SKY box in your lounge.
(I'm assuming that the carpet fitters did NOT put a nail thru your co-ax cable or pushed the cable onto any metal carpet grippers???)
If they might have done this accidentally, then, that's why it doesn't work!
Then make sure that the co-ax cable is plugged firmly into your second TV. Sometimes the central connector within the co-axial socket becomes loose and needs nipping back together with a pair of long-nosed pliers.
I'm assuming that you have plugged the Infra-red remote eye unit back into the second TV aerial socket - before you plugged the co-ax cable back in?
If you have, press the SKY remote to see if the Infra-red LED can be seen in the remote pod.
Finally, make sure that you have selected the correct channel number (or Input) on your second TV remote to select SKY.
Nov 18, 2009 | Televison & Video
No s lead output on tv
For this, the easiest way to do it would be to get an audio/video converter. Costs less that $20.00. This will allow you to connect S-video, red white and yellow a/v cables as well as co-ax cables. Hope this helps you. If not, let me know.
Oct 27, 2009 | Televison & Video
Acoustic Solutions TV/DVD P1480 has stopped working
Doh me, daughter had accidently hit the standby button without realising, had a brainwave after posting above and tried that, everything working fine.
Oct 01, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
Acoustic Solutions 26'' HD TV cannot play PS3 blue ray films
I have recently brought the same TV and had the same problem but I've mangaed to find a soultion.
The automatic setting for Blu Ray on PS3 is Full HD (1080p) but the Acoustic Solutions TV is HD ready (720p). For PS3 games it will automattically change settings for you to 720p. This is why this works straight away but Blu Ray doesn't.
Solution
You need to plug in your PS3 using the scart contection, then on the ps3 menu go to settings > display settings > HDMI. You will then need to attach the HDMI cable and manually set up
HDMI by checking the 720p option and deselect 1080p.
That should then play Blu Rays too. You don't lose too much quality as 720p works nearly as well as 1080p on smaller TVs.
Rich
Feb 18, 2009 | Televison & Video
 Grubhead
Grubhead
