Question about Video Game Consoles & Games
Mpu5 error codes barcrest
Hey ive got a alarm on frut machine and the code is 52-36 no characteriser and no id chip just wondering what the problem is ?
  • 135 Answers
SOURCE: error code 0102
If you're comfortable enough opening your 360, you can try this tutorial, which has worked for many people.
Posted on Jan 07, 2008
Riztech
  • 731 Answers
SOURCE: Fax Error codes
I have mentioned the Description for the error codes.388 and 421 error codes means the same and suggestion to resolve the problem.
282 - Retry the transmission.
388 - Reattempt the fax reception at a different time when telephone line conditions have improved.
421 - Reattempt the fax reception at a different time when telephone line conditions have improved.
233 - A communication failure has occurred between the two machines (OR) The user at the remote machine might have pressed the Stop button. (OR) Sometime Call waiting service might cause this error code.
  • Turn OFF the Error Correction mode(ECM).Steps to do. Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to Error Correction mode(ECM) and highlight -> press ok/Enter->Select turn OFF-> press ok/Enter.At Last Press Cancel to quit the menu.
  • Decrease the Fax speed.Steps to do.Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to" Fax speed"-> press ok/Enter-> Choose "Medium speed or slow speed ->press ok/Enter. At Last Press Cancel to quit the menu.
Thank You
Posted on Feb 09, 2008
pemring
  • 53 Answers
SOURCE: Get a C:31:30 Error Code
C 31:30 IS FG fault when starting capstan.
Posted on Jan 14, 2009
petraman7
  • 1175 Answers
SOURCE: Error code from my xbox 360
http://llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Posted on Jan 18, 2009
  • 126 Answers
SOURCE: Error Code F1-87 Finisher Trouble on Sharp AR-M350U+
It is a stapler rotation error. The stapling tray pressure arms become dull at the tips, so when the stapler attempts to move into position to make the staple it cannot move the guides out of the way.
First choice) Replace the (4) stapling tray pressure arms (LSTPP0357FCZZ). After you replace them you'll see that the tips get worn down, and wedge into place so that the black support plates cannot move out of the way of the stapler. The black plates look warped, but they aren't (I should say they always look like that).
They are fairly easy to get to. You do have to remove the finisher from the copier. Remove the front and rear covers. Open the right door. Pull the pins that retain the door. From there you'll see the arms. They can be changed with a little maneuvering.
2nd Choice) Clip overtight wire ties to the stapler rotation home position sensor.
3rd Choice) Shake down the stapler to its bottommost position (wherever it settles is fine). Adjust the flag that triggers the stapler home position sensor. If I remember correctly its the narrow **** in the flag.
Posted on Jan 28, 2009
I have a cash beast machine, whenthe unit is powerd up, nothing happens, the mpu5 had got the -12v and the 34v leds on but nothign else, i have looked over the board to check the various status leds and as far as i cansee all of them are on, could this be a power supply problem, or is the card dead, does anyone know what/where i could look to see if i can find the fault, i do have 2 power supplies,. and both leave in the same state, i am tempted to say its not the PSU.
Read More.. HP Printer Support
Thanks,
Aug 18, 2014 | Office Equipment & Supplies
My machine model AR5618s error code 2 and F than
f2 mean toner chip disable.You should buy new one cartridge.There are easy to get only chip,please buy new chip and assemble this chip
Oct 20, 2013 | Office Equipment & Supplies
I need activation code for corel draw x5
Fixya will not give out any serial numbers, Activation Codes,
or Key Codes. It is illegal to pirate software
Oct 14, 2012 | Computers & Internet
I have a Rheem paloma Tankless WH Model PTG-53PVN. I am getting error 05 and then error 13 and it shuts down. I have run through all the cleaning etc. - no help. Lat year I received a replacement board and...
http://globalimageserver.com/FetchDocument.aspx?ID=1371e2e6-22f2-45d6-a712-d2679eac9e0c
is common error codes for The Rheem tankless water heaters and has recommend actions. It says that error code is imperfect combustion alarm, which basically tells you that the system is not getting enough air for some reason.
Error 13 is also an air flow problem. http://www.plumbersurplus.com/pdf/05223.pdf?SSAID=389818 So I doubt that reprogramming will do any good.
Rheem products are air flow sensitive and something as simple as storing something against or close to a Rheem will cause trouble.
http://waterheatertimer.org/pdf/Rheem-TanklessParts-Accessories.pdf If you look at Page 10 of that manual you will see that the RTG20074FK is the natural gas chip for sea level. Basically it lets the unit make adjustments for different altitudes. It is NOT programmable! It should be installed on the control board IF you live at sea level.
Jun 20, 2011 | Rheem Water Heaters
Alarm says 17-83 opto blocked tamper
Hi did you every solve this problem? i have the same problem currently
Jul 19, 2009 | Kitchen Appliances - Others
Diagnostic code list for a 1997 *Australian* Toyota Celica
You could try troublecodes.net. Not sure if they have listings for AU vehicles tho. Can't a local Toyota mechanic print them for you? Or try a library if you have access.
Mar 29, 2009 | 1997 Toyota Celica
Error code 0102
Jan 07, 2008 | Microsoft Xbox 360 Console
Restriction code for 3220
hey ive got the same probly with my nokia 3220
my imei # 357623007557471
if you can help my out email me at
wandione97@yahoo.co.id
Dec 28, 2007 | Nokia 3220
Ive forgot my unlocking code for motorola phone
well let's hope that you did not change the security code, tell the person to press the menu key and when the screen ask for the security code tell them to put in the 000000....that should help
Dec 21, 2007 | Motorola Mobility RAZR V3
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
