My speakers haven't been working properly for a while and I was wondering how to fix this. They sometimes work (very rarely) but then they just cut off, the music will still be playing but I won't be
For example this morning I turned my laptop on the start up sound worked and I played one song, during the next song I couldn't hear anything. If I put headphones then its fine and the sound works. Help?
  • 27 Answers
If it always works with headphone - without fail - then it is likely the fault is within the headphone socket. You'll appreciate that when you plug in headphone, the speakers in the laptop are cut off - which is a mechanical break in connection caused by the plug. Sadly, it sounds like it is staying disconnected.
Posted on Nov 24, 2013
5 Suggested Answers
clokker
  • 253 Answers
SOURCE: Audio Jack not working on my notebook
Install the sound driver from your computer.You can find it on the homepage from your pc.Re-install it.If this not helps install the ac97 driver...
Posted on Jan 16, 2009
SOURCE: headphone socket on my laptop is not working
hey man just try to see if any thing is in there it can block your electrial current if there is make sure you turn your laptop off before using twezers to pull it out other wise it could fry your motherboard
Posted on Mar 17, 2009
garputo22
  • 127 Answers
SOURCE: My Headphone Wont work on my laptop
Try a different set of head phones.
Posted on Jun 05, 2009
9339009664
  • 70 Answers
SOURCE: Sound (Speakers problem)
there r some loose connection on the motherboard
Posted on Aug 23, 2009
Rear Speakers cutting out
You Need to Change Wire Connected to Speakers. it's may be damaged internally.
Mar 15, 2014 | Panasonic Audio Players & Recorders
Only subwoofer works at high volumes
It could be your receiver but you can try seeing if the Woofer has a input knob at the back, maybe this down, or maybe.if possible turn down the amount going to the woofer with your receiver.
Dec 27, 2007 | Kicker 02S10L74 Car Subwoofer
How do I fix the speaker sound on my iphone 4s?
there is probaby something stuck inside the speakers. take it to a phone repair shop and they can fix it for you
Apr 23, 2013 | Apple iPhone 4 Black Smartphone
I have a packard bell nav50/DOT S2. I wont boot properly. Most of the time it turns on, the possessor kicks in for a bit then stop, nothing on the screen at all. Sometimes it boots with the PB BIOS...
Download and burn a copy of memtest86+ to CD and then boot from that CD and it should automatically start the test program. If you have a bad memory it will be immediately obvious on the screen.
Jul 23, 2011 | Computers & Internet
I can not hear videos on my youtube. How can i fix this problem?
Check to see if any other programs are running that use sound...sometimes they can block YouTube's audio since the program may have a "Hierarchy" over the browser. Check the simple stuff too including speakers and wires and buttons and so on. Check options on your profile just in case, it may work. But if you haven't already, sometimes just a simple restart of the computer works.
Hope that helps ^_^
Jul 18, 2011 | YouTube Videos
Hi the left channel of the surround speakers both A&B is not working. I wondered if there is a fuse inside the amp that is easily replaced . All other channels are working. thanks Andrew
A and B are front speakers.
Individual channels are not customarily fused. Amp self-protection usually cuts in if necessary.
Is it on all audio sources or only certain ones? Have you swapped the speakers Left-to-Right to isolate the speaker from the signal chain as a cause?
If it's only an analog source doing it I would suspect a bad audio cable or a switch somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Feb 10, 2011 | Denon AVR-3802 Receiver
Speaker comes in and out... woofer blown im guessing.. what can i do to fix it before i end up sending it to m audio to be repaired
Does the tweeter keep playing when the woofer cuts out?
It is rare for a speaker to cut in and out, check all wiring connections and if possible connect it to a different amp to test, the amp can cut in and out just like a speaker. Try switching it with another speaker and see if it cuts out aswell.
Hope this helps!
Thanks
Jan 22, 2010 | M-Audio Studiophile BX8a Speaker
Acer Aspire 1406 no sound issue
So sometimes laptops play up when the headphone socket gets a bit worn. If you wiggle a headphone jack in the socket (put it in at different angles, and rub around) sometimes the sound will come back.
There are two prongs that "detect" the headphones, and cut the speakers... and if they don't "un-contact" when the headphones are removed, the speakers stay off.
You'd need someone to solder a new headphone socket on the mainboard to properly fix it, but if you wiggle and get the speakers back, they should stay back until you use the headphone socket again.
Apr 20, 2009 | Acer Aspire 1406LC Notebook
Sony subwoofer PCVA Sb1 doesn't work most of the time.
check the cables- sharp sound b4 disconnect is mainly due to power cut or cabling problem
Feb 04, 2009 | Sony 182556522 1-825-565-22 SUB WOOFER...
Durabrand DB1215 car radio
I have a db 1210 and i need the wireing plug for the speakers can you help
Jun 04, 2008 | Durabrand DB1200 CD Player
Computers & Internet Logo
David Payne
David Payne
