Question about Fujitsu Fujistu Siemens Esprimo Mobile Ms2216 V5505 Laptop Notebook Pc Computer Usb
Display problem when it starts, it shows horizontal lines. but by pressing or tilting the lcd, it become good but after moving lcd lines come again
  • 30 Answers
I had a laptop that did this. for me it was a broken ribbon cable. after a while the cable degrades and becomes brittle and with enough movement the cords break and separate very little and when moved in a little it would close the gap
Posted on Nov 24, 2013
How to fix LG TV Vertical lines.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 30, 2015 | LG 47LA6200 47" 1080p 3D Smart TV 120Hz...
Dell laptop display
This can be one of two things. The first is unlikely, the display cable has become loose. The second is more possible, the screen has gone bad and needs to be replaced.
Aug 17, 2015 | Dell Computers & Internet
Vertical strip of flashing horizontal lines on Acer Aspire 7551G screen
More than likely it's the lcd screen and will have to be replaced. I could be the video card, but most likely the lcd screen especially when you can put pressure on the screen and cause changes. To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok, then the problem is with your lcd screen and the video card is ok. If the Borrowed monitor displays the same as your lcd screen then the problem is with your video card inside the computer.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Once you narrow it down to the lcd screen as being the problem you might try taking the lcd screen apart to reseat the lcd cable on the back at the top of the lcd. Just unplug it and plug it back into the connector. You can also try doing the same where the lcd cable plugs into the motherboard. Just pull it out and put it back.
May 31, 2012 | Computers & Internet
Compaq C700 laptop screen shows horizontal lines and the screen seems to be split into several sections
The LCD screen is faulty and will need to be replaced, go to www.ebay.com Type: make and model refine search to screen, first! hook a spare monitor to the video output usually on the back, if picture okay! the above mentioned needs to be changed, but! if both show the same symptom it is the video graphics card that is part of the motherboard.
Apr 19, 2012 | Computers & Internet
The screen on my lap top has had 3 very thin lines across the screen but if you tilt it they go now sometimes they screen fades away and i have to move the screen again this is getting worse could it be...
I'm a laptop repair technician, and in my experience the very thin horizontal or vertical lines are usually caused by malfunction in the display panel and the entire screen has to be replaced. If might be worth a shot for you to try and reseat the LCD cable though, but I doubt that it will work.
Sep 23, 2011 | Packard Bell EASYNOTE R1004 COMPATIBLE...
Hi, I have a thinkpad R-51 and accidentally hit the lower part of it with door. When I press the power on button, the display comes up once in 5-6 times and it's as though it was turned off. Now the...
We might be having issues with the video card or the LCD
For us to isolate where the problem is coming from
1. Tried accessing the BIOS see if the horizontal lines are present
2. If there are horizontal lines on BIOS definitely the problem is LCD and we to replace it
3. So if we see horizontal lines inside Windows we might have issues with Video Card itself or Video Card driver
4. Try uninstalling the video driver and install a fresh copy of video driver. Else we need to replace the video card
5. Usually laptops have integrated video. So we need to replace Motherboard
Jun 02, 2011 | IBM Computers & Internet
My become like horzantal lines+become not
Disconnect the Monitor from the PC, and keep it still powered on. If it displays horizontal lines, it means monitor has gone bad. If not then go to PC's BIOS, if it shows lines there then your graphics card/chipset has gone bad. Else its your graphics driver/operating system. Can try an update/reinstallation of driver.
Regards,
Shrey
Oct 09, 2009 | Dell UltraSharp 2000FP 20.1" Flat Panel...
Display Problem Black turns Red
the is some loos connection in the staip comming from lcd to motherboard.
check it.
Nov 24, 2008 | Computers & Internet
Display Problem in my SGH - U600 mobile phone
Could be the ribbon that connects screen to keypad common problem on this model video of how to fix on u tube
Aug 25, 2008 | Samsung SGH-U600
Fujitsu Fujistu Siemens Esprimo Mobile Ms2216 V5505 Laptop Notebook Pc Computer Usb Logo
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
