Question about Air Tools & Compressors
Ptc reley p330mc - Air Tools & Compressors
Problem with a APC Back-UPS BR800I with AVR The
Hi Petkov,
It seems that Schneider / APC has a remedy for this on their forum:
http://forums.apc.com/message/35667
Reply or call if you need more assistance with this -- 407.380.9200
Oct 08, 2013 | Computers & Internet
1990 4runner turn signal dont work.worked b4 not now. where is the fuse box
there is a flasher reley it is likely burned out put on the 4 ways and folow the noise the other reley for turn signals should be close and look identical switch them and see if thet fixes it if it does remove bad flasher reley and replace with new 1 for 10 bucks
Jan 22, 2010 | 1990 Toyota 4Runner
The blower on my heater will not cut off. I have no working controls
sounds like a bad switch or a stuck reley call dealer ask if there is a reley and where it is located if easily accessable go to salvage grab a reley for 2-5 bucks and replace yours
if this doesnt work then you likely need a switch but reley is likely culprit
Jan 16, 2010 | 2004 Chevrolet Malibu
My switch on air flow speed in my 1988 camry has stopped working, not even the fans turn, air con would go on and off for a few days and now has given up, so I can't even blow hot air at myself is this a...
might try replacing the reley it might be just a reley and you can get them from scrap and if you ask the dealer they will tell you where to locate the reley and even show you a pic usually or just point it out
releys cost usually 5 bucks each and it never hurts to have a spare in the pocket when you check out
Jan 08, 2010 | 1998 Toyota Camry
Horn does not work
is it the fuse or the reley look at the salvage yard and find manule buy it for 5 bucks and locate the fuse if not fuse ask dealer for reley and location of reley
Jan 08, 2010 | 1983 Chevrolet Caprice
2004 Toyota Sienna - keyless remote will unlock the van fine, and beeps twice, but hit the lock button, and only the driver's door will lock, no beeps. Any thoughts?
sounds like a bad reley
there are usualy 2 releys 1 for open and 1 for close but the drivers door is for some reason on a private circut without reley or reley is locked in
Dec 31, 2009 | Toyota Sienna Cars & Trucks
Keyless entry is not working
check the releys under the hood play musical releys and find the problem child
munber all the releys 1 - 10 then start playing musical releys
Dec 12, 2009 | Hyundai Motor 2002 Elantra
I am looking for a diagram of a 9 volt wig wag circuit, for a pair of n-scale train crossing lights, can anyone help me out.
if you just want the light to blink use a flasher reley and a circut cut reley if you wire it properly it will flash
it is simple to wire it
there are 2 output wires and 2 input wires on the power reley just hook the flasher reley to the power wire and conect the lights up to eithor wire coming from the reley
remember the reley will require power and ground the litess are hooked positive side to the reley and neg to the neg wires of power supply
Sep 16, 2009 | Kitchen Appliances - Others
91 chrysler newyorker
sounds like a reley
change the high low releys arround
also look to see if you have 2 different flip releys
Jan 15, 2009 | 1991 Chrysler New Yorker
Air Tools & Compressors Logo
174 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
