Samsung air conditioner
Does not start.
    Top Expert:
  • Heating & Co... Master
  • 12,962 Answers
Do the fans also not work? If so then there is no power getting to unit because the chances of all motors and compressor going bad at same time is zilch. If all is dead check for the on/off switch or thermostat to make sure that power is going past this switch to the other components.
You might also check the obvious and see that the wall outlet is delivering electricity - circuit breaker pop?
Posted on Nov 24, 2013
Remote control signals not being received by Samsung air conditioner
Try a new set of batteries in the remote... If that doesnt work, look on the indoor unit , behind the filter screen or on the side for a "manual start or emergency start button or switch" If that works, it may be the remote is faulty. If not the remote, it will be the recveiver board on the indoor unit.
Jul 16, 2011 | Samsung AQ24 Air Conditioner
Ac offs as soon compressor starts functioning
Usually when that happens the unit is low on charge...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 26, 2010 | Samsung Heating & Cooling
Amana air conditioning unit
You either have a blower that is gone out,or the start capacitor is bad,it is most likely the blower motor.
Jul 18, 2010 | Samsung AW1203B Air Conditioner
Lights are blingking
thermostat command to out door unit not there . Check your PCB
Jul 14, 2010 | Samsung AS18A6RB Air Conditioner
Hi I have 1.5 ton samsung split ac. The problem is to solve the water leakage in the indoor unit. Kindly advise
the water comes from the coil, start there make sure there is no obstruction coming out to your condensate line and make sure its properly pitched.
May 19, 2010 | Samsung AS1293L Air Conditioner
Samsung AS09XLN air conditioner lights blinking
Sounds like a common problem I have found with Samsung mini split unit. When powering on, does the internal blower attempt to start, then the unit stops and lights blink? If so, on the circuit card there is a 1.2uf or 1.5uf (CBB61) that probably has gone bad. I have replaced several of these. Good luck.
May 08, 2010 | Samsung AS18A6RB Air Conditioner
I start my as 12 samsung ac with the remote or
If you look carefully at the remote there is a reset button, try resetting it and make sure you have new batteries.
Nov 16, 2009 | Samsung AS18A6RB Air Conditioner
Split system Samsung AC not cooling
The compressor is not compressing. Either the compressor isn't running or the freon has escaped.
Jul 26, 2008 | Samsung AS18A6RB Air Conditioner
Machine shuts off
your control board assembly is faulty relace with a new one from your local appliance parts store
Sep 09, 2007 | Samsung AW1293L Air Conditioner
Problem with samsung aw0503b
Found this on Samsungs site.Hope it helps a little, at least you know the problem now. If your air conditioner displays E1 in the display panel and won't turn on, it means that the Room Thermistor (a device connected to the thermostat that detects room temperature) is shorted or defective, and you need to have your air conditioner serviced. If it displays E2, E3, or any other E error, you also need to have your air conditioner serviced. To arrange for service, contact Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have the model number of your air conditioner on hand when you call.
Aug 02, 2007 | Samsung AW0503B Air Conditioner
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
