Question about Ovens
Thermador SCD272 upper oven will not preheat. New element and new control board installed.
Replaced element and control board 702451
catriver
  • 878 Answers
SOURCE: Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Posted on Dec 27, 2006
SOURCE: Thermador sm272zs microwave/oven combo
Woke up this morning and heard my smw272 built-in oven beeping. Oh no! First the display (but at least the oven worked) now the oven is beeping (fault signal according to manual) and the thing is dead except for the microwave and warming bin. The only way to turn off the incessant beeping--which was driving me crazy--was to go outside to the fuse box and turn off the circuit to the oven. Yeah, I stopped the beeping but now I'm at the mercy of the unscrupulous service repairman--was quoted a flat fee to drive out and a hefty hourly rate (i.e., "value added" service charge). OUCH! Hey folks, please follow my simple advice if you want to avoid making a big mistake: NO MORE THERMADORS. RUN--DON'T WALK AWAY FROM THIS BRAND!!!
Pruneau
Posted on Dec 30, 2007
SOURCE: THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Posted on Dec 08, 2008
  • 71 Answers
SOURCE: Oven will not heat - Thermador SMW272 Electric Oven
since you said the broiler does work , take the wires off the broiler element and put on the bake . then when you put on the broiler the bake should work . the light bulb principle, just remember to wrap all loose wire with electrical tape and disconnect from wall while working.
Posted on Dec 12, 2008
MNTECH
  • 1543 Answers
SOURCE: GE J BP27G R1AD Oven Not Heating Fully
Hi Jeff. You should have a wiring diagram with the range. Check for an envelope on the back of the range, inside the back splash, or taped to the inside side wall of the range if you remove the lower drawer. That all being said, first check to see if the start or stop time knobs on the timer have been pushed in (and possibly turned). If the clock runs, it will clear this out within 12 hours, but on these old ranges often times the clock no longer runs. Make sure these knobs are turned until they have "popped" out or you won't get the necessary voltage where you need it. Secondly, when a bake element burns out, it can cause damage to the electrical contacts in the oven selector switch (part number WB22X5122 ) which can be tested with an ohm meter if you can find the electrical diagram. Also, the oven thermostat (part number WB21X5320 ) can be damaged in the same way. Unfortunately, these parts for these old units are not very cheap.
The little bit of heat you are getting in your oven now is most likely only from the 120 volts going to the broiler element when in Bake. During Bake, your bake element should get 240 volts (until thermostat is satisfied). Setting to Broil should give 240 to the broil element.
Posted on Dec 14, 2008
Dos wo-227 upper oven relay board
I would look on the internet for places that fix boards they usually charge around 120 dolars there is one in texas just type control board repair. Bye
Feb 27, 2016 | Ovens
Thermador CM302us- lower oven will NOT heat up.
Check for power at the lower burner element. If you have power, the lower burner element is defective.
Sep 04, 2015 | Thermador Ovens
Thermador smw 272 not heating via bake or convection. Light and fan work as well as broil and clean (microwave fine too). If I switch from broil and then to bake after heated, it will hit right temp and...
see if there is a bad solder connection on the bottom (underside) of the board just below one or more of the small black relay boxes. re-solder if you can or replace the whole board.
Jan 04, 2015 | Thermador Ovens
THERMADOR OVEN SCD302T BOWS CONTROL BOARD
may be a shorted element, but could be almost ANY shorted item. Look at the board for a better idea of exactly which relay is blowing and trace it back. Otherwise a complete disassembly and testing of all components will be needed.
Oct 11, 2012 | Thermador SC302T Electric Double Oven
I am getting an F64 on my thermador electric double wall oven after a few minutes of preheating my upper oven, and the oven turns off. What des this mean?
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Jan 05, 2011 | Thermador SEC302 Electric Double Oven
The upper oven works fine. The lower oven won't
Make sure you hit the reset switch first... on top of the lower over... behind the panel...they trip easy and "kill" the oven.
Nov 27, 2009 | Thermador SC302T Electric Double Oven
Thermador SCD272 Panel Dimm Problem
a phone call to thermadore is definatly an option open to you, im sure they will handle you situation as do all manufactures on a case by case basis, at only 2 yrs old you may even fall under a part warr from them,not to mention as you explain to them how you see the amount of others with hte same issue, is quite possible they offer you a concession, worth the 800 number call and the 20min time to do it
Nov 03, 2008 | Thermador SMW272 Electric Double Oven
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
Replaced the displace board and oven is now not working
I just had a repair company replace the display, control board and wiring harness on SCD272 double oven to correct a dim display (kit part # 492071). Instructions on kit say that all three pieces must be used together for proper operation.
Mar 08, 2008 | Thermador SC272T Electric Double Oven
Ovens Logo
32 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
