Dlink dwr116 The Router is connected and the firmware is up to date. There is no internet connection using a sierra 320U modem. Everything has been checked.
SOURCE: zhone linksys router
I had same problem but I think it's more of a simple solution. Linksys default IP it uses is 192.168.1.1, and guess what...so is the zhone router. I changed my linksys router to 192.168.10.1 and i am able to connect to the internet. Only problem I have left is some things are not working such as MSN messenger and https pages. I am wondering why...
Posted on Aug 27, 2008
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Posted on Aug 05, 2007
  • 14 Answers
SOURCE: D Link DIR 635 router conection internet
Normally, all ruters are hubs as well. if you want to connect it as a hub only; try connecting only the ports minus the WAN port that goes to the DSL modem. In this case the router will behave just like a hub.
Posted on Nov 12, 2007
kakee
  • 1269 Answers
SOURCE: I currently use a cable
No need to install the dlink on the imac. All you need to do is connect the modem first the dlink. (Modem connected to Internet or WAN port of the dlink). Now if they are connected, your imac should be plugged in to port 1 of dlink, and your PC to port 2. That should do it.
Posted on Dec 19, 2008
rahul26485
  • 611 Answers
SOURCE: how to connect ADSL 2 modem to Wireless Router
just change the ip address in the router and give the proper settings in the router
Posted on Apr 04, 2009
I cant get wifi and internet on my computer at the same time
Hi. Let's hava look at what you are doing.
I'm guessing that you have a cable modem a dlink router with wifi and a computer, right?
If you connect the cable modem to the computer you have internet. You shouild also have wfi but the wifi will not give you internet because it is disconnected from the modem.
The Dlink has to be connected to the modem but it will also need to be configured. To *** that you will need help from your cable company.
The connections should be. Modem connected to the outside world. Dlink connected to the Modem. Computer connected to the Dlink by either wifi or Ethernet.
Feb 28, 2012 | D-Link RangeBooster G WBR-2310 Wireless...
I am on Cox cable. I lost my connection to the internet several times this evening. Cox checked out my modem and said the problem was in the router. When I connect modem to computer, internet pops up...
Cox people are really correct that everything is working from them and from there modem and doing a firmware update is really a good thing to do to correct your problem. For that firmware update you just need to download it from your routers manufacturer like Linksys , Belkin , Dlink or Netgear just go to there web site and search the model of your router so you can download the latest firmware for it.
Feb 03, 2010 | Computers & Internet
D-link WBR-2310 wont set up. A long time ago when we first bought this router, we had it set up and working fine. We kept getting disconnections every now and then so we bought a new Belkin router, which...
The issue I see is that the lights all are lighting up. I'd bet it is caused by some type of short or like a power outage or surge (remember surge protectors basically do nothing at all). If I were to guess, that's it. Other than that, I would flash the firmware back to original if it lets me.
Nov 27, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
My internet service is working sporadically when it is connected to the D-Link router. Right now I have my computer directly connected to the cable modem and it works fine. When the computer is connected...
You need to update the firmware of your router. Download the latest firmware from Dlink website. You need to hard reset the router, load the firmware, then do another hard reset after you successfully updated the firmware.
Jun 25, 2009 | Computers & Internet
How to connect ADSL 2 modem to Wireless Router
Apr 03, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
I have an issue with my Dlink DIR-625 wireless and cable modem
it isn't syncing up with your modem, try a hard reboot, disconect everything, even the cable, after 5 minutes , first screw the coax cable back to the modem, that will re establish the cable connection, plug everything back in, and if that pc light still is still doesn't work, the router may be bad, look on the Dlink site and download the latest firmware, as a last resort, but also reset the router first before trying anything, there is a reset button on the router. Sometimes certain routers don't work with certain modems, if you try the reset, then the hard reboot, and the firmware, you have covered all the bases
Mar 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Need help in connecting to the internet using Dlink 704p router.....
it doesn't matter whether the other computer is set to static and the other one is set to dynamic as long as both computers are getting/using valid ip addresses.
if i got it right. 1 computer is connected to the LAN port of the router and the other computer is connected to the WAN port. if so, you need to connect both computer to the LAN ports and the WAN port of the router should be connected to the modem that you are using.
if the physical connection is correct, check how you are connecting to the internet through the modem. if you can access the internet from the modem without configuring anything, you just need to power cycle. turn off everything then turn on the modem first, wait for the lights on the modem to turn on properly before turning on the router then turn on the computers.
hope this'll help you but if not, just provide the following:
(1)ISP:
(2)brand/model of the modem:
so i can help you further.
Jun 04, 2008 | D-Link DI-704P Router
Wireless router
Yes, you can use wireless router with the modem. I guess the actiontech DSl router that you have is also Wireless one. If so, you can use just the DSL router for wireless connection. If you really want to use Dlink router with it, Connect the ( WAN port ) of the Dlink router to the ( LAN Port ) of the Action tech modem [ modem(LAN)-->Dlink(WAN) ]. Once you do this connection, better to do power cycle ( unplug the pwr to the dlink first, then, disconnect the pwr to action tech - wait 1min and plug the pwr to modem, wait for DSL light to be solid , then put the pwr back to dlink ). Make sure DSL light on the modem solid, internet light & WLAN light on the link glowing.
- Make Hardwire connection between the computer to Dlink and check the ip address on the computer whether it acquires the ip address from Dlink and then check the internet connection on the computer, it has to work. if computer not getting ip from dlink, try restarting computer.
- If hardwire connection on the dlink works fine and check the wireless connection.
For wireless configuration or assistance you may check this link:
http://www.portforward.com/help/wirelessxp.htm
please feel free to ask, if you have any more assistance.
- Laxman
Nov 22, 2007 | Actiontec (GS204AD9-02) Router...
D-link DIR-635 router
Hi, I am assuming that you can connect to your router's web based interface (192.168.0.1). On a PC LAN wired to the router, open a browser; Type "192.168.0.1"; Log-in username/admin and password/(blank); Go to Tools > Misc and the option to select the WAN speed (bottom); Lock the speed down on the WAN port of your router to 10Mbps (Some versions do not have this feature). Hope this works for you. If not pls post back with your modem brand/model. You may also want to log the IP settings (IP Add, Subnet Mask, Default Gateway, DNS Servers) of the PC that is directly connected to the modem when you can access the Internet when not using the router. Good luck and kind regards.
Oct 02, 2007 | D-Link / RangeBooster N 650 / DIR-635 /...
Computers & Internet Logo
224 people viewed this question
David Payne
David Payne
