What are comunication barriers? - Computers & Internet
    Champion:
  • 219 Answers
Not able to translate
Posted on Nov 27, 2013
Need to know the type of vapor barrier needed for a second floor unfinished ceiling with insulation and a metal roof..
It depends on your local code. Contact your building department, get a permit and ask the inspector, he will help you and if you follow is instructions you will pass the inspection.
Sep 19, 2014 | NTSupply NT-1200 Heavy Duty Vapor Barrier...
Cargo barrier
try the barrier manufacturers on line --- Check ARB or TJM to see if they can help you out as they sell the barriers as well.
Feb 09, 2014 | Holden Astra Cars & Trucks
The inflammatory response involves chemical and physical barriers that help protect the body from harmful substances
An individual was exposed to a contagious disease but did not become infected. The agent was unable to enter the body and grow because it was stopped by the person's skin. This is an example of how a __________ can prevent disease.
A. chemical barrier B. physical barrier C. protective behavior D. medication
May 04, 2013 | Audio Players & Recorders
Aperture sticky
I'm not sure if you mean the lens barrier on the out side of the camera, the shutter that takes the picture or the high speed shutter.
If the outside barrier is sticky, it may have water soluble stuff on it like jam or syrup.
I clean this area very carefully with a Q-tip moistened with ONE drop of lens cleaner. Carefully clean by pushing the barrier back into the lens sideways, gently, and cleaning under the edge of the lens cover slightly. This is easier to do if you remove the batteries from the camera with the lens out.
Caution - you CAN jam the lens barriers. You can pop out the barriers. I suggest getting a shop to look at it.
Apr 02, 2010 | Cameras
Error communicating with kernel
try to instal the antivirus again there is some files corrupted
ok ;)
May 28, 2009 | Encore Computers & Internet
I've packed gravel and sand on the basement floor, the edges have been trimmed with 3'' foamboard, before I lay the entire floor with 3'' foamboard I am caught between using a vapor barrier between the...
I would use the vapor barrier Unless you plan on taping all the seams and using care to not open them during the pour the foam will not act as a vapor barrier. I feel vapor barrier is critical an code in some areas.
Apr 20, 2009 | Hardware & Accessories
Lens cover opens only a **** on Sony DSC-W80
Please read carefully below procedure how to remove "Barrier Block" (what you call Lens Cover)..
Turn camera power ON so Lens will extend.
Take out battery so lens will remain extended.
First silver ring needs to be removed with help of tweezers as shown in below image..
Now you will see 2 screws at front of lens, unscrew to remove barrier block (lens cover) as shown in below image..
You need to have new barrier block with following part number..
A-1205-001-A BARRIER BLOCK ASSY
Subject part is available in Part Store
Install new barrier block as shown following image..
Insert battery and power up camera to check does barrier block works fine.
Need further info, let me know.
Good luck.
Feb 10, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Error 230 en Escaner NCR 7875
You need disable the scale scannig the bar codes for programing
Program mode
304
save and reset
301lbs to kg
302kg to lbs
303enable scale
304disable scale
305 Protocol comunication
306 Protocol comunication
307 Protocol comunication
Oct 08, 2008 | NCR 7875
Shutter
Do you really mean the shutter? Or do you mean the lens barrier? The lens barrier opens in front of the lens when you go to take a photo.
Assuming it is the lens barrier which is stuck open, the cause is usually dust/grit. A series of "puffs" with a large bulbed blower, e.g.a Giotto, should help clear it.
If it's been caused by liquid ("coke" is a favourite!) then the sugar is holding it open. A little (very little) ethyl alcohol dropped on the lens and allowed to percolate around the barrier area should sort it.
If it is the shutter you mean, then that is a workshop job.
Apr 05, 2008 | Panasonic Lumix DMC-FX8 Digital Camera
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
