Question about Samsung B2230 LCD Monitor
I have sycnmaster b2230hn blue power light is off ,although poer plug in ok
Fix my vizio
I have fixed a few tv's that were flat screens and the problem is almost always a capasitor. They use the cheepest from china, look for a bulge on one on the power side although they are not always noticable.
Jul 31, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
My LG TV red light won't turn on. although the plug fuse and the remote OK
Try manually pressing the power/standby button on the tv (side or bottom) the red light should appear, most modern tv's will turn on simply by pressing the channel up or down on the tv itself.. But unfortunately in most cases, this seems to be an internal surge and needs a professional to inspect..
May 14, 2012 | LG 42PG20 42 in. Plasma HDTV
Power cord plugged in no green light
Hello
Check the power cord first, for its conductor continuity using a multmenter. It the cord is OK, the fault is with its built in power suppy regulator board. You should have through knoledge in electronics, all tools to disassembe it, enough experence in serivcing Switch Mode Type poer supply circuit boards.
If you have all of these, download its service manual from any site, and do the work by yourself. If you are not well experienced to do this work, get the set repaired either by any experienced service technician, or by the Atuthorised Service Center for Audiovox at your town. OK.
Feb 02, 2012 | Audiovox PVS33116 Player
We have just purchase an acer aspirre 5640G from Harvey Norman today. we have plugged the poer supply in, but cannot turn the on button on. it will not turn on. can you help please. we have had the...
I suggest you return it to Harvey norman for a replacement or repair. It is under warranty.
When you get a replacement, test it at their shop before you take it away.
Nov 27, 2010 | Acer Aspire One PC Notebook
Blue light comes on and then clicks off after a
it sounds like a virus or error on the mainframe although it could be your battery try taking your battery out and then plugging it into the mains. then turn it on without the battery in but still plugged in to the mains there may be sumthing wrong with ur batter
Mar 03, 2010 | Packard Bell Easy One Silver 2120 Notebook
Laptop won't turn on
If the lights are blinking after pressing the power button and num lock is responding then MB is ok.If not then might be the issue with motherboard.
I
Thnaks.
Jan 13, 2010 | Acer Aspire 1640Z Notebook
Powers on Immediately poers off
This could be a bad memory chip or slot problem. remove the memory and try one chip at a time in each slot. If this doesn't work then the problem will most likely be in the power management system on the motherboard. This will require professional diagnosing in order to track down the exact problem component.
Aug 27, 2008 | Dell Inspiron 5160 Notebook
Hp1903 blank screen
power shortage maybe...try to plug your monitor on the other power supply,,be sure that your monitor is compatible on the voltage it required..
Aug 04, 2008 | HP vs19 (Silver) 19" LCD Monitor
Asus A2500h laptop booting problem
YOUR THERMAL HEAT PAD, OR AN INTERNAL DEVICE COULD HAVE SHORTED CAUSING AND OVERLOAD PROTECTION CIRCUIT TO ACTIVATE, WAS THERE AN EVENT THAT OCCURED BEFORE THIS HAPPEN.CHECK WITH THE MANUFACTURE TO SEE IF THIS IS A COMMON PROBLEM WITH OTHER UNITS
Aug 02, 2008 | Intel Motherboard
Samsung B2230 LCD Monitor Logo
27 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
