Question about De Dietrich Microwave Ovens
Locked can't start
I have a whirlpool microwave WM1107ADWC and I want to turn off the Child lock. How can I do it? I don't have kids and i want to save time when I use my microwave. Thanks
Child locks on microwaves act as a safety feature to prevent children from getting harmed or from causing other possible damage. The child safety lock does not lock access to the microwave; it simply prevents the microwave from being operated. To remove the child lock press the Stop button three times.
Lock the microwaveIf you wish to re-lock the microwave, perform a similar procedure. Instead of pressing the Stop button you need to press the Start button. Press the Start button three consecutive times to lock the microwave. This enables the child lock once again and prevents the microwave from being operated.
check this video also. Many Whirlpool microwaves are made by LG. between these two you should get it.
How do you remove the child lock on microwave
Jun 12, 2017 | Whirlpool Microwave Ovens
LOCKED
Sounds like the child lock is on. Try holding the start button down for several seconds.
Jun 27, 2012 | Whirlpool MH7140XF Microwave Oven
Goldstar microwave GMV 1540TW locked
From the handy owner's manual here:
To set child lock:
1. Press STOP/CLEAR.
2. Touch and hold START more than 4 seconds.
"LOCKED" will appear in the display window with two beeps.
To cancel child lock:
1. Touch and hold START more than 4 seconds.
"LOCKED" will disappear in the display window with two beeps.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Oct 06, 2011 | Goldstar MV-1526 Microwave Oven
Locked keyboard on a 1540tw
I guess your model number is GMV1540TW?
I think I answered this or a duplicate post already, but here goes:
The owner's manual covers that, but if for some reason you don't have yours, you can get it here.
To set child lock:
Oct 06, 2011 | Goldstar MV-1502 Microwave Oven
My Jenn-aire microwave says locked and has a picture of a padlock. I was microwaving bacon and had just put it some to cook ( my second batch per se) and everything was locked up. I tried pushing options...
Most likely you set a child lock (front panel lock) by holding a button too long (3 seconds). Without a model number, I can't be absolutely sure of the keypad lock for your Jenn-Aire microwave. Usually, the key will have a small padlock icon on it. Press and hold this key. On my microwave you press and hold Start to toggle the lock off.
On a Jenn-Aire JMW2430 and similar models, the Button Lock is activated by a several step process (More and Button Lock). However, pressing and holding the Start button will deactivate it.
I hope this helps.
Apr 19, 2011 | Jenn-Air Microwave Ovens
How to unlock digitals butons?
It sounds like you've activated the child-lock - this would disable all of the digital buttons.
To switch the child-lock OFF, simply press and hold the START button for about 4-5 seconds until "LOCKED" disappears from the display.
To switch the child-lock ON, press "STOP/CLEAR" button once, then press and hold the START button for about 4-5 seconds until "LOCKED" illiminates on the display.
If the buttons aren't working and "LOCKED" is not displayed, then you may have a defective touch control pad.
Hope this helps - please let me know if you need further assistance.
Regards,
BElectric
Feb 15, 2011 | Kenmore 63252 Microwave Oven
Lock function reset for model JMV8208BAS
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
The owner's manual is online here and it covers the child lock:
To set the child lock.
Touch and hold
ENTER/START
pad more than 3
seconds. CHILD
LOCK ON will
window with two
beeps.
To cancel the child
lock.
Touch and hold
ENTER/START
pad more than 3
seconds. LOCKED
will disappear and
you hear two beeps.
Aug 18, 2010 | Jenn-Air JMV8208BAS Microwave Oven
I need to know how to unlock it
The Child Lock is on.
Your owner's manual covers it. If for some reason you don't have yours, you can download it free here.
CHILD LOCK
You may lock the control panel to prevent the microwave from being accidentally started or used by children.
Example: To set the child lock.
1. Touch STOP/CLEAR.
2. Touch and hold START more than 4 seconds. LOCKED will appear in the display window with two beeps.
Example: To cancel the child lock.
1. Touch and hold START more than 4 seconds. LOCKED will disappear and you hear two beeps. At this time the oven is ready.
Dec 13, 2009 | Goldstar MV-1501 Microwave Oven
Child sign in window of microwave ,cant start it panasonic
On my NN-L738BA there is a Child Lock feature.
You set the child lock by pressing the Start button 3 times.
If the Child Lock is enabled it displays the word :CHILD".
To disable this feature on my microwave the manual says to
press the Stop/Reset 3 times.
Check your manual for the Child Lock.
Mar 06, 2009 | Panasonic NN-S541 Microwave Oven
Panasonic microwave
the child lock feature is activated.
if you can look at your manual, it would be stated there how to activate and deactivate your child lock option.
tnx 4 using fixya
drcool
Sep 01, 2008 | Panasonic NN-S254BF Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top De Dietrich Microwave Ovens Experts
William Miller
William Miller
ray gallant
Tom Chichester
Are you a De Dietrich Microwave Oven Expert? Answer questions, earn points and help others
