Question about Building Materials
Coromaster garage door motors limits
I found a gear for my Coromaster door opener. It is the larger of te two gears the one that is running horizontally. Where can i find a manual how to replace it myself or is this a job for a expert?
    Genius:
  • 1,198 Answers
When in doubt, Google it. If this gear attaches to a chain, it gets a little difficult to keep the chain in control. Usually parts like this are held in place by a set screw, requiring the correct allen wrench. Working this stuff up on a ladder is no fun.
Posted on Nov 24, 2013
How do we reprogram the limits of a Coromaster 2000 Garage Door. @CutOnTheNet answer is cryptical.
Posted on Dec 20, 2014
3 Suggested Answers
CutOnTheNet
  • 14 Answers
SOURCE: How do I reset my garage door opener. It is a
The Coromaster 2000 does not operate off limit switches. It has a quarter-revolution optical pulse counter. To re-program the open and close limits do the following: Ensure that the door is open at least a couple of feet. Press the reset button once or twice Short out pushbutton and common and hold until close limit and then release. Door should stop at your new close limit. Wait 5 seconds. Short out pushbutton and common and door will open. Hold the short until open limit and then release. Limits should now be set.
Posted on Nov 09, 2010
  • 3197 Answers
SOURCE: I have a Coromaster Mach2
This appears to be something made in Africa. I suggest you call around locally. We don't seem to have any around here.
Posted on Jan 10, 2011
Drum motor noise
Need to open the entire printer, don't feelbad if you are capable you start to open other pl don't open it,its major issue..While printing main motor driving entire printer except fuser assm, entire printer load on Main motor assembly, in main motor assembly contains motor and gears, pl see the marked gear in snap I experienced this gear found warn out, this is suits hplj 5200 main motor gear, you can choose this gear and its easily available.. replace this gear, but opening the printer is difficulty.. thanks..
Feb 04, 2012 | HP® LaserJet M5035 MFP Laser...
Motor hums but door doesn't move. If I disconnect door and give chain a horizontal poke, it will move. When I reconnect door it returns to humming, without movement.
Remove the cover from the motor unit and you will find the drive gear has stripped. White sawdust all over. The part number for the gear kit is 41A2817 and it comes with instructions. It is available at any good door opener service company.
Feb 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do I reset my garage door opener. It is a Coromaster 2000 motor. The closing and opening setting are out and the motor only stops due to resistance.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Stripping plastic drive gear in Chamberlain opener: Won't lift
If you are a do it yourselfer you can do it. The new part can be bought at any good door opener company and they will most certainly have them on the shelf. The part should come with a set of instructions. Don't let them sell you a part without the instructions. The part number is 41A2817 Drive Gear. If you do find the job is to much for you they will gladly install it for you for the labor costs. One plus is that they will also check and service the door for you. Door maintenance gets overlooked most of the time.
Aug 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
TE-72 sporadic hammer
You should have no more than 70cc of oil in the housing. AW46 Hydraulic fluid will work.
Aug 12, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Garage door opens about one foot and remains there.
Check the door springs. You could have a broken spring. Also remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It is possibly stripped. This is a good time to release the door from the opener and operate it by hand to see just how heavy it has become.
Jun 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
GARAGE DOOR OPENER
Remove the cover and I am sure you will find the gear is stripped. The part number for the gear is 41A2817 and is available at Sears or any garage door service company. It comes with instructions.
Apr 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Phaser Imaging Unit install error
Worked like a charm! Thank you for the detailed information. The step by step instructions were right on target.
Feb 24, 2007 | Xerox Phaser 6250DP Laser Printer
Building Materials Logo
580 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
