Question about Zebra P330i Card Printer
Zebra cardstudio 1.1v classic serial key
Zebra Cardstudio 1.1 version for classic.
  • Mohamed Ramzith
    Mohamed Ramzith Nov 24, 2013
    Please anybody give me the license number for my testing purpose
    Every i am struggles to print those data.
The cards I printed from this device are pixelated and I have no idea why. Is there any other way on how to print from this device?
Jpeg is a lossy file saving format so anything where the image can be lost to save space happens. Some fonts if a bit thin can do this in jpeg format. Can it also print from pdf? the one we have here is ok with pdf formats , just printing from the adobe reader works fine
Nov 06, 2014 | Zebra P110i ID Card Printer
Card studio invalid size
Check the queue of print jobs in the upper right corner of cardstudio (card studio) software. We had to clear the queue (with the "x") because apparently something was wrong with one of the queued print jobs.
Feb 05, 2014 | Zebra CardStudio Classic - P1031773-001
Zebra Designer Pro Key
Zebra Designer PRO is an additional charge that must be purchased separately.
Mar 06, 2010 | Zebra LP 2844 Thermal Printer
Zebra 105SL Prints fine through Zebra Setup Utility, but prints plain text when file copied to port. Win XP. The setup utility can never get Version Info from the printer, but Windows shows the printer...
possible fonts issue. try to change the font from the text, check setings from the driver.
try to print from the driver (test print)
Try to print from Word (need to ajust the page) with diferents text fonts.
you can check the correct firmware ( be ware with the information about the serial number) ATENTION!!! wrong firmware can cause PRINTER DEAD!!!
Install lates firmware to the printer.
Oct 12, 2009 | Zebra 105SL Thermal Label Printer
Unable to upgrade Zebra TLP 2844-Z printers firmware
What is the problem if this works?
May be there is a problem on the boot rom!
Jun 24, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra printers & MS Word
HI Les1810,
You should be printing faster with Zebra fonts.
Which driver are you using? Version?
I strongly recommend the Zebra Designer V1.3.08, available at Zebra.com
To isolate the problem, capture the output to a file.
Define a local port as C:\output.txt and set that as the port in driver properties.
Now print your document. The printer commands will be in C:\output.txt.
Send c:\output.txt directly to your printer.
For LPT1, use the DOS copy command to send the file. (Copy C:\output.txt LPT1)
For serial connections, use Hyperterm to send the file.
For network connections, use ftp.
No easy USB method is readily available.
Does this print faster than printing the original document from Word through the driver?
If yes, then update your driver.
If no, debug your communication to the printer (LPT1, serial, network, etc.)
Sep 24, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Serial Settings for the Zebra 105Se
here is manual
http://www.jnc-service.nl/assets/manuals/zebra/S-series.pdf
Apr 16, 2008 | Zebra 105Se Thermal Printer
No response from 105Se
if the data light comes on and nothing prints chances are that the serial settings are set improperly. all of my printers are 25 pin serial, not parallel. i don't have one in front of me but i believe the settings are 19200, 8, 1, none. hope this helps.
Mar 19, 2008 | Zebra 105Se Thermal Printer
Trying to print the data from a Mettler Toledo IND690 Weighing Terminal to a TLP2844 Zebra
This printer can be loaded into memory the design and receive the data from the weighing terminal for the desired layout.
Feb 21, 2008 | Zebra Printer 140-751-00000
Zebra P330i Card Printer Logo
610 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
