Question about Gaggia Classic Espresso Machine
Trips fuses machine trips fuse box accasionally
  • neil cameron
    neil cameron Nov 26, 2013
    I amin a new house and find the circuit kept breaking when I used it.Not all the time but often enough that I have stopped using it. Any help would be appreciated.
    Problem Solver:
  • 6 Answers
Disconnect from mains. 1/ Set multimeter for 200k or 1meg. 2/ on plug top connect between earth and one other pin. 3/ If meter shows anything but infinity, disconnect heater first then any solenoid valves, this should change the reading to infinity and indicate leaky part. If no success borrow wifes hair dryer and drive out ant dampness in wiring especially insulation in intimate contact with machine frame. Franko
Posted on Jan 03, 2014
The tumble drier operates correctly but after a short time (eg 5 minutes) it trips out the fuse box and cuts out ?
you obviously have a short somewhere in the machine, Or its overheating due to bad venting, bad blower flow etc, it should not blow or trip ur breaker box though? has anyone bypassed any of the thermal fuses? I suspect u may have a short in the heater element broken wires touching metal and causing the fuse to trip
Mar 18, 2015 | Dryers
Bosch SRS53C02GB/27 tripped circuit fuse, Changed plug fuse still no sign of life
Has the circuit breaker / fuse in the meter box tripped or blown as well? If the machine tripped or blew a fuse, it is common for the heater element to be the cause or you have a water leak internally and its shorted something.
Mar 01, 2015 | Bosch Dishwashers
TRIPS FUSE IN MAIN HOUSE BOX
you may have to add a different fuse line in your box....PLEASE DONT ADD IT TO EXISTING FUSE LINE
Sep 23, 2014 | Zanussi Washing Machines
Why is my washing machine tripping my main fuse box even when I change the plug socket
by "tripping main fuse" do you mean the high amp (eg 60 amp or 100 amp) fuse that feeds the whole fuse box? if that is the case, there is too much stuff on in your house that's drawing power. The fuse box is too small to power all the stuff you have plugged in and running. Suggest turning off other high draw appliances in the house, like large TVs or microwaves or air conditioners, when running the washing machine.
Nov 18, 2013 | Washing Machines
Why is my bosch maxx classic frontloader washer tripping the safety switch in fuse box
hi rachel, there's a bad earth in the machine some where,things to check wiring to the motor, check the wiring it's self, any circuit boards, if they are all ok the programmer could be shorting out hope it helps
regards
shaun
May 17, 2012 | Washing Machines
My washing machine kkeps tripping my fuse box
This is related to a fault in the main control panel, it is possible there is a short if the fuse keeps tripping off. You need to remove plug and pull out the panel to check for short in the power supply to the main control panel usually a SMPS unit. Use a multimeter to check for short, if so this must be replaced.
check for tips from the link below:
http://www.espares.co.uk/advice/washing-machines/a/7/1298/how-to-replace-washing-machine-controls-hotpo.html
Apr 30, 2012 | Hoover Nextra HNF 3157 Front Load Washer
Machine keeps tripping the fuse at the fuse box - WD61 Aquarius Hotpoint
I believe the problem is in the fus(breaker). I would say that it is the thermal fuse in the machine but it usually goes out before the breaker does. The breaker has gotten weak over the years. You have a hi limit on the machine as well but I doubt this is it. Let me know how you do.
Feb 07, 2009 | Hotpoint Dryers
Gaggia Classic Espresso Machine Logo
66 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
