Nc6400 screen screen starts with lines but when it is pressed it works correct, after some it becomes faulty again
  • 46 Answers
WOW, Mushrafrd, you may need to replace the screen, have you ever dropped it? IF you use an external monitor, does that monitor look OK?
Hope this helps.
Posted on Dec 11, 2013
Nc6400 lines on screen after pressing screen it becomes ok
Bad connection to the screen. Re dressing the cable loom may cure it.
Nov 24, 2013 | Computers & Internet
Screen won't turn on
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Dec 06, 2012 | HP Compaq nc6400 Notebook
I wan to reset jumper on hp compaq nc6400 laptop
refer to manufacturers site for correct positioning.
Jun 20, 2012 | HP Compaq nc6400 Notebook
I bought Nokia E6500 from Softlogic Office in Srilanka. Now after using it for nearly two years I find two black lined (thick) on the display, where the dimensions of these black lines getting...
My dear, what really happend was that, the screen is becoming faulty. This should maybe become as a result of the phone screen being pressed hardly against somethig (maybe unknowingly). So the only solution that problem is to change the screen. HOPE THAT ANSWERS YOUR QUESTION AND HELPS
Jul 21, 2011 | Nokia 6500 Slide Cellular Phone
Red line on comp screen reset driver dont work
This is, unfortunately, the screen starting to deteriorate, it will probably get worse and worse. It is a common thing, and is usually caused by the "Driver" "Chips" becoming faulty. There is no real "Fix" other than "Replacement"
Feb 12, 2010 | Acer Aspire 5500 5570-2609 Laptop
My Fujitsu LIFEBOOK N3430 Notebook does not boot up the screen is blank
Remove the battery for 5 minutes, press and hold the power button for 3 seconds, wait 5 more minutes, put battery back in and see if everything works now. It should. This usually works.
If it doesn't, you may have a faulty memory chip causing you the black screen.
You can try removing one at a time to see if it corrects the problem.
Lastly, the ribbon cable from screen to motherboard can become piched and non responsive.
Nov 25, 2009 | Fujitsu LifeBook N3410 Notebook
I have an HP nc6400 laptop that the screen went very dim and I can only see it faintly I tried the fn f10 but nothing changes. Is there any other setting that might need changed?
this happens when the cable that gives diplay to the screen become loose or start malfunctioning, just take your laptop to the techician and get it done by him
Sep 25, 2009 | HP Compaq nc6400 Notebook
Lost password
Become the system admin to get a new one or create a new one with a reset which is under users in the control panel depending on your OS.
Sep 19, 2009 | HP Compaq nc6400 Notebook
I forgot my power-on password for my nc6400
Reboot the computer press F8 select safe mode. once logon screen shows up hit enter. go into command prompt type net user username *<-what ever your username is replace user name then type your pass word and hit enter then repeat the password once again. you can not se the text you type so.....
That should fix your problem
Nosirrom.net
May 02, 2009 | HP Compaq nc6400 Notebook
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
