Question about Proview PS 720F-1s (Silver, Steel Blue) 17 in.CRT Conventional Monitor
No display monitor,no display,power indicator lights
  • 3 more comments
  • CompMomGA Nov 19, 2007
    I thought my monitor was completely dead but when I plugged it in today the led power light blinked a few times but the monitor still didn't come on. I make sure it is plugged into a working outlet and it is not plugged into a computer.
    Any ideas?
  • Crash Bash Nov 25, 2007
    I have a Gateway FPD1975W 19-inch. The power light will flicker on when I power it up then the monitor won't come on. The warranty just expired and Gateway won't service the monitor. Any suggestions on how to fix it or get it repaired.
  • eduardoh Jan 29, 2008
    I have the same problem : NEC Multisync LCD 19080 Sxi Power on and even with the cable disconnected the led is green, blinking with a very low frequency .
    Usually when the cable is disconnected the led is yellow . Tried to connect to another computer and the result is the same.
  • traggio Sep 07, 2008
    II have an X2Gen MG19VT 19" LCD
    onitor purchased 1/30/06. Problem: The monitor does not go on9the screen is black). The AV adaptor shows a flickering light however no current is going thru to the monitor. The AC adaptor is made by Powertron Electronics Corp(PEC). Model # AD1250B. Input:100-240v-1.28 amps -61050Hz Ouput: 12v-4.17amps-50w max.
    I have diconnected from computer given it a rest and the reconnected with no results. All wiring and adaptor checked for correct attachment.
    [email protected]
  • Tom1119 Oct 23, 2008
    I have 2 X2Gen V19 monitors. One of hte monitors has periodically gone out, but i could fix it by simply unplugging and plugging it back in. Today, it went out and the normal fix doesn't work. However, when i plug the monitor into my other adapter, it works, which suggests an adapter problem, not a monitor problem.
Hi, My picture just collapsed and the power light went out. The mains lead and the surge fuse on the main board are both ok, there are no visual signs of damage but there is a ticking sound which only stops when the mains lead is pulled out no matter which position the on/off switch is in. The CRT cathode heaters are NOT lit, so could this be a Low Tension problem?
Posted on Apr 02, 2008
  • 91 Answers
Check the power cable, whether pluged well or not remove the monitor cable which is connected to your CPU only pluged the power cable and watch the LED status and let me know
Posted on Oct 10, 2007
SOURCE:
Blinking light on 20 inch apple display
Blinking light on Apple cinema display usually indicates insufficient power from the power supply. Test it with another power supply from ANY cinema display (23" and 27" power supplies are ok to test with).
Feb 03, 2014 | Apple Cinema HD 30" LCD Monitor
Sudden failure - working fine then next time switched on no apparent power (no indicator light on), no display
You could have a power supply problem in the LCD monitor.
First check the power lead, make sure it is firmly inserted into the mains socket and into the monitor.
Try inserting it into a different main socket that is operating, to see if the power indicator LED lights up.
If you have determined it is the LCD monitor is faulty, then it requires repairing.
Jan 25, 2011 | Acer AL1717 17" LCD Monitor
MY SCREEN IS BLACK IS THERE ANY WAY TO FIX IT
if there is no power getting to the monitor ( indicator light ), test the fuse in the power lead first.Ensure it is inserted tightly.
If there is power to the monitor, the green indicator light should be steady, if it is flashing there is a problem with the display
Test the monitor in another computer or laptop.
If t stays black , I'd supect a faulty backlight or more probably a blown power capacitor whih will need checking and replacing
Dec 30, 2010 | HP L1955 19" LCD Monitor
The Dell AS 501 monitor display comes and goes off in seconds. If I switch off and on again, the display comes back and goes off again in less than a second. I repeat this as many times the same monitor...
This sounds like the power inverter is failed.. It's what pumps up the power for the light in the monitor.
You could try unplug the sound bar from the back of monitor if you have the sound bar installed. Just a maybe..
To fix the inverter (replace) is usually better to buy newmonitor unless you do it your self.
The defective LCD Backlight inverter will cause the following symptoms:
  • No Display, but Power Indicate light stay on green (Or Blue).
  • Screen flash on and off and the power indicate light stays on green (or Blue).
  • Dim Display
Go here to start looking if you want to try yourself. http://www.lcdparts.net/DI3D.aspx
Dec 27, 2010 | Dell Computers & Internet
Power light on but there is no display.
I have the same problem with my acer al1617b if you get any suggestions please let me know
thanks
Nov 11, 2009 | Gateway FPD2275W LCD Monitor
Viewsonic Va912b monitor
it seems that there is a problem in the lcd back light or may be in power supply section
Sep 12, 2009 | ViewSonic VA1912wb 19" LCD Monitor
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
X2 gen 17" lcd monitor, no display
This indicates either a problem with the monitor cable(ie shorted) or the display adapter. Try plugging the monitor into a different computer and if it works you will need to install a new display adapter in your computer. If it doewn't work on the new one either you can try a different monitor cable if yours isn't permanently connected. Hope this helps
Mar 29, 2009 | X2 MG17R 17" LCD Monitor
No display
if your monitor is not connected to a pc, then it cannot find a vga signal input and therefore go into power saving mode, which is indicated by the orange light, but as soon as you connect to the pc and power on the light will go green and the monitor will power up.
May 07, 2007 | BenQ T701 TFT 17" LCD Monitor
Proview PS 720F-1s (Silver, Steel Blue) 17 in.CRT Conventional Monitor Logo
355 people viewed this question
Top Proview Computers & Internet Experts
 Mike M
Mike M
Siul Oyaratgam
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
