Question about Endurance Exercise & Fitness
Kettler boston xl treadmil
Require user manual
5 Suggested Answers
  • 3 Answers
SOURCE: Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
Posted on Aug 30, 2009
ercupa190
  • 12223 Answers
SOURCE: I need a user manual for Avanti AT380 Treadmill
http://www.manualsnguides.com/results.php
www.iconservices.com
http://fitness.manulsonline.com
http://manualsfactory.com
since this place you must not find the exactly model, you must pay in some of them, and download something similar.
The problem is the factory is coming in australia, and there are not service in USA, and support. sincerely.
Do not waste your time searching in the WEB.!
E.CUADRA
MANAGUA NICARAGUA
Posted on Dec 01, 2011
ercupa190
  • 12223 Answers
SOURCE: Sil on Display
1) clean with water and cotton.
2) see if there are result o.k
3) try to clean with little alcohol, and see if there are best result.
4) Otherwise you must contact your supplier manufacturer.
God bless you
Posted on Jun 29, 2012
buckinsand
SOURCE: kettler alpha xl treadmill
Likely too much heat build up from friction between belt and rollers / housing..The "sil" may be in reference to the need for a "silicone treatment on the inner side of the belt.
Posted on Nov 30, 2012
Treadmill KETTLER PACER - dc6 system fault, what I
Check if the drive motor is working
Power cycle...if still do not function calibrate or call 877-805-1030
Aug 10, 2013 | Kettler Exercise & Fitness
Kettler alpha xl treadmill
Kettler alpha xl laufband typ 7894-600 err3
/uploads/images/kettler-alpha-xl-treadmill-34874487-1-1.jpg
Aug 01, 2012 | Exercise & Fitness
Sil on Display
God bless you
Jun 28, 2012 | Exercise & Fitness
What type of oil is required for kettler xl treadmill
It depends where you want to use it, if you want to use it under the belt to reduce the friction then a silicon based lube is best.
Sep 15, 2011 | Sport & Outdoor - Others
My friend gave me a Kettler Boston XL Treadmill (Germany) a month ago I only realize i m missing some info. Can you let me know what is the voltage for this brand. Fyi this unit was used on vessel and i hv...
there should be a model tag on the machine , probably down near the belt , that will have the voltage details for the motor
if not the plate on the motor will have the voltage , rpms, watts and cycles plate on it
Nov 24, 2010 | Kettler Exercise & Fitness
The +/- speed buttons and the red stop button do not function
Sounds like the function keypad has failed or worn out from excessive use of those buttons Call Kettler's customer support
KETTLER International Inc.
P.O. Box 2747
Virginia Beach, VA 23450 USA Tel (757)427-2400 Fax (757)427-0183 Email info@kettlerusa.com or www.kettler.co.uk
Jul 17, 2010 | Kettler TX1 Treadmill with FREE INSIDE...
Hi Rendra,
Try this:
May 10, 2009 | Exercise & Fitness
Exercise & Fitness Logo
56 people viewed this question
Top Endurance Exercise & Fitness Experts
Howard
Howard
Tom Chichester
Techmotionusa.com
Techmotionusa.com
Are you an Endurance Exercise and Fitnes Expert? Answer questions, earn points and help others
