Question about Vacuums
Rowenta brush activ
The engyn dose not start
Belts aren't broke roller still won't roll
Belt dosent have to be broke it may be stretched. It needs around 30lbs of pressure to roll the brush on carpet.
If it dose not roll off carpet at all the brush bearing are locked up. You may be able to remove the roller and check theme. Most likely you wil need a new roller brush.
Aug 08, 2014 | Bissell 8910 ProHeat Clear View Upright...
Need a filter for rowenta infinium vacuum cleaner
Although it sounds to me like you have a clog in your hose (remove hose and try slipping a heavy butter knife through it, end to end) here is a link to Rowenta manual..lists part numbers for replacement parts.
http://www.rowenta.com/NR/rdonlyres/9A747036-B60E-4F70-96BF-3370EDADAB54/0/Canistervacummcleaners_InfiniumGB.pdf
www.rowenta.com
Sep 13, 2009 | Rowenta RO7011 Bagless Canister Vacuum
The vacumn runs but brush dose not turn belt is good. It's a dyson 110 us c 10417
Now is it air driven or belt driven? It could be the belt that's not turning the brush. Check if the belt is loose or is broken. If it's air driven, then check and see how the condition of the bearings are. If it doesn't roll smoothly then you need to replace the brush roller. If it does roll smoothly then check if there's a blockage in the line.
Jul 28, 2009 | Vacuums
Bissell Healthy Home Vacuum Cleaner
sounds like you need a new belt for your agitator(brush)
Jan 26, 2009 | Vacuums
I have a steam cleaner and i can not get the black arm brush to keep one side up and when you trun on the steam cleaner the brush dose not spin when you start to clean the floor but it will spin when you...
Sounds like you could have an elevator broken (part #2000010). You will have to take the top off to replace them or to check to see if one of them is broke. There is one on each side so when the handle is in the upright, they push againsy the brush roll to lift it up. As for not spinning, chack the cogged belt as well as the cogged pulley on the pump, if it is bad, you will have to replace the pump.
Jul 02, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
