Question about Miracle MJ1000 Juicer
National Juicer Blender MJ176NR...Need the plastic part with blade and bearing that is fixed below the jar and is turn kept on the motor for using the mixer.
    Top Expert:
  • 12,223 Answers
Go to www. repairclinic.com and get it.
God bless you
Posted on Nov 24, 2013
2 Suggested Answers
SOURCE: I need a new blade assembly for the blender
The entire blender/smoothie attachment is available as part number MJ1000BL from a number of sources.
Posted on Jan 24, 2010
How do I remove top plastic round part from the rotor of the motor?
The manufacturer warrants that your Jack LaLanne Power Juicer is free of defects in materials and workmanship and will, at its option, repair or replace any defective juicer that is returned. The Jack LaLanne Power Juicer's motor is warranted for the lifetime of the original purchaser, and all other parts and components are warranted for 60 days from the original date of purchase. This warranty is valid only in accordance with the conditions set forth below:
1. Normal wear and tear are not covered by this warranty. This warranty applies to consumer use only, and is void when the product is used in a commercial or institutional setting.
2. The warranty extends only to the original consumer purchaser and is not transferable. In addition, proof of purchase must be demonstrated. This warranty is void if the product has been subject to accident, misuse, abuse, improper maintenance or repair, or unauthorized modification.
3. This limited warranty is the only written or express warranty given by the manufacturer. Any implied warranty of merchantability or fitness for a particular purpose on this product is limited in duration to the duration of this warranty. Some states do not allow limitations on how long an implied warranty lasts, so the above limitation may not apply to you.
4. Repair or replacement of the product (or, if repair or replacement is not feasible, a refund of the purchase price) is the exclusive remedy of the consumer under this warranty. The manufacturer shall not be liable for any incidental or consequential damages for breach of this warranty or any implied warranty on this product. Some states do not allow the exclusion or limitation of incidental or consequential damages, so the above limitation or exclusion may not apply to you.
5. This warranty gives you specific legal rights, and you may also have other rights which vary from state to state.
If you want to order or have questions about specific parts or accessories, feel free to call us at our customer care department:
Phone: 1 (973) 287-5150
Procedure for Warranty Repairs or Replacement
If warranty service is necessary, the original purchaser must pack the product securely and send it postage paid with a description of the defect, proof of purchase, and a check or money order for $29.99 to cover return postage and handling to the following address:
Tristar Products, 500 Returns Road, Wallingford, CT 06495.
Sep 27, 2014 | Jack Lalanne Power Juicer 250 Watts
Jack Lalanne Power Juicer250
the power is not properly supplied to blade .....just check whether the connections are proper ....
Aug 09, 2008 | Jack Lalanne Power Juicer 250 Watts
Acme juicer vibrating so much.
I've had one for 21 years and when I replaced the blade the same thing happened.
The blade is not supposed to be held firmly in place so it can slip intentionally to
minimize vibration. If you bought the juicer new, think back, and I believe you will
remember the vibration problem. I seems with a worn blade they vibrate less. The
motor is very durable and uses roller bearings like on a skate board. I went back
to the old blade, which I sharpen with a drill using a small bit.
Jan 11, 2010 | Acme 6001 Juice Extractor
Broken plastic screw from motor shaft
According to Jack Lallanes Support you need to buy a new motor! No replacement part for that specific part!
I have the same problem and also do not want to buy a new motor! Scam!
Dennis
Nov 21, 2009 | Jack Lalanne Power Juicer 250 Watts
The plastic screw, which the grater is screwed onto (looks like part of the motor) is broken.
I had the juicer for exactly two weeks and the same piece broke. The little plastic part in which the blade screws onto. Called the company and they were actually no help at all. Please don't waste your money!
Nov 14, 2009 | Jack Lalanne Power Juicer 250 Watts
Acme juicer #6001, has a new blade, becomes unbalanced...
Hello, First, make sure the screw on clamp that holds the blade down is centering the blade correctly. Also make sure it tightens down firmly against the blade. Wiggle the blade to ensure it is mounted securely. If this doesn' fix it try your old blade again. If your old blade works you may have a bad, unbalance blade but I would suspect he screw on clamp knob may be somewhat worn and not securing the blade causing it to run "out of round" when a piece of vegetable pushes on it. If everything looks good with both blades and the blade securing knob it could be a worn bearing on the juicer. Try wiggling the motor shaft and see if there is any play in it. I have an ACME 6001 that is quite old so I wouldn't suspect the bearings are going. One other thing, does the bowl take 3 to 5 minutes to stop spinning when you shut off the motor? If it does then the shaft and bearing are probalby ok
Good luck with it...gary
Jan 05, 2009 | Acme 6001 Juice Extractor
Jack LaLanne Juicer
Try this site for a manual
http://www.powerjuicer.com/pdf/classic.pdf
Dec 07, 2008 | Jack Lalanne Power Juicer 250 Watts
Jack lalane juicer thread goes bad killing the juicer
DO NOT BUY THIS PRODUCT!!!! unless the plastic drive srew is replaced with a metal one.
Nov 24, 2008 | Jack Lalanne Power Juicer (Stainless...
Miracle MJ1000 Juicer Logo
177 people viewed this question
Top Miracle Juicers Experts
Tom Chichester
David Payne
David Payne
Are you a Miracle Juicer Expert? Answer questions, earn points and help others
