Question about Razor Dirt Quad Bike
I changed my battery to my quad and when it pluged up it looks fully charged but when its unpluged it like the battery is dead and the qaud wont move
Why wont it charge the battery when using the wall plug
Sir,
the charger must be tested, if it not giving the out put voltage, you have to change it, check the connecting point for possible loose contact or corrosion inside the jack.,clean it.
Dec 30, 2015 | Panasonic HC-V100M Digital Camcorder -...
2006 DODGE WINNEBAGO VIEW WON'T CHARGE BATTERIES OFF ENGINE ONLY CHARGE WHEN PLUGED INTO SHORE POWER
perhaps that is so the truck will not have dead batteries when needed to start the truck.
Mar 05, 2015 | Dodge Cars & Trucks
Blackberry 9720 suddenly went dead wont charge
Hi Michelle. I have the same phone and it happened to me a few times. On most phones the battery swells up when it reaches it's charging life end. In the 9720 the battery can still LOOK okay even though it might have reached its life-span. I eventually purchased a new battery, and wholaa, problem solved. A piece of additional advice is: Do not chat with you phone on the charger. Unplug the charger when battery is fully charged: We tend to charge the phone anytime and every time before we go to work or somewhere - you have to let the battery run flat on its own at least once a month, then start a fresh charge from fully flat to fully charged. This will prolong battery life. I a new battery does not solve the problem, have the charging pin checked out. Alternately if you know someone that has the same handset as you, ask them to stick your battery into their handset and visa versa. Hope this info help :)
Aug 26, 2014 | Blackberry 9720 Smartphone White, Factory...
Acer aspire wont turn on
Remove main battery, power up! no change, remove one stick of ram and power on, if same problem! remove second stick of ram and replace the first one back in, any change? if no! I recommend a professional at this time to assess possible motherboard issues.
Mar 11, 2012 | Acer Aspire 7736 Notebook
Problems with linhai 80cc quad
Battery or battery cable connections. After you get it running make sure the charging system is working. Maybe riding it ran the battery dead from it not charging properly.
Feb 11, 2012 | Linhai People 250 Motorcycles
My philips gogear 4g is pluged in and works but when i unplug it it says low battery and shuts off immediatly it has been left on for 4 hours now trying to fully charge it will not charge is the battery...
If the media player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 26, 2011 | Philips GoGear ViBE Digital Media Player
My Ipod 3rd gen. wont work other than when its pluged into the pc
Your battery is most likely dead to the point where it can no longer hold a charge, which is the reason that when you unplug it from the computer, it dies instanly. Batteries are pretty cheap going up to about as high as $25 and if you get it done at a ipod place, installation should not be that much.
Aug 05, 2009 | Apple iPod nano 8 GB Pink (3rd Generation)...
Nuvi 200 when charging never says charging complete .
HI, I have the same NUVI. Mine does the same. I haven't had any issues with it. It still charges fully when I unplug it.
Jul 25, 2009 | Garmin nuvi 200W GPS Receiver
Dead unit
My Quest2 has a short in it that drains the battery even when it is turned off. But the battery lasts normal 15 to 20 hours when fully charged and unit is on. Whenever the battery is completely dead, I have to place it on the charger for a hour or two before the unit will even start even though it is plugged plugged in. The battery can be replaced by the staff at batteries plus for under $60.00
Oct 12, 2008 | Garmin Quest GPS Receiver
IBM R32- battery light problem
usually when the charging light blinks and wont change to solid green it means the battery is dead.
solution is to buy a new battery
Dec 07, 2007 | IBM ThinkPad R32 2658 Notebook
Razor Dirt Quad Bike Logo
77 people viewed this question
Top Razor Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
RatanbssBD
Level 1 Expert
Are you a Razor Rock and Ice Climbing Expert? Answer questions, earn points and help others
