Question about Intel D945GCCR Motherboard
Aad97184 105 i need bios file to update
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Intel Master
  • 2,226 Answers
Http://www.intel.com/p/en_US/support/highlights/dsktpboards/d945gccr
Posted on May 18, 2014
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Feb 05, 2013 | ASUS Eee PC 900 Notebook
Update bios
Visit the HP support site. Use the automatic detection of your computer and download the BIOS update utility. It should update the BIOS from inside Windows. You need no Iso image file.
Jan 19, 2012 | Intel Pavilion dv6375us PC Notebook
Cerna obrazovka nemam disketu bios
Hi, you can download the bios here:
http://www.asus.com/Motherboards/AMD_Socket_A/A7V600X/#download
Download the asus update utility from here:
http://www.softpedia.com/get/Tweak/System-Tweak/ASUS-Update-Utility.shtml
The asus Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows environment.
The Asus Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
Aug 25, 2011 | ASUS A7V600-X (90M7A820G0EAYZ) Motherboard
Cmos bios bad asus p5ld2-x/1333 i945gc. how i fix?
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS Update Utility - an utility that allows you to save, manage and update the motherboard BIOS
The ASUS Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows® environment.
The ASUS Update utility allows you to:
You need an Asus motherboard in your system.
Rules for Safe BIOS update:
1. For safety reasons, always use the most updated BIOS utility!
2. Do not overclock the system/CPU during BIOS update!
3. Load "Setup Default" in BIOS menu before BIOS Update.
4. Make sure you have "Administator" privilege on your Windows system (WinNT4/2000/XP).
5. Close all application programs under Windows.
6. Disable any existing Anti-Virus applications in the system.
7. Reboot the PC after the BIOS update is complete.
8. Switch on the PC and load "Setup Default" in BIOS again.
Hope this helps
May 23, 2011 | ASUS P5LD2-X/1333 - motherboard - ATX -...
D946gzis bios.bin file i need pls help
You need to update your bios interface and to do so, CLICK HERE. It's a PDF file and all you need to do is to click on the 3rd topic which is for the BIOS Update and what you need to do are as follows:
Updating the BIOS with the Intel® Express
BIOS Update Utility
With the Intel Express BIOS Update utility you can update the system BIOS while in
the Windows environment. The BIOS file is included in an automated update utility
that combines the functionality of the Intel® Flash Memory Update Utility and the ease
of use of Windows-based installation wizards.
To update the BIOS with the Intel Express BIOS Update utility:
1. Go to the Intel World Wide Web site:
http://support.intel.com/support/motherboards/desktop/
2. Navigate to the D946GZIS page, click "[view] Latest BIOS updates," and select the
Express BIOS Update utility file.
3. Download the file to your hard drive. (You can also save this file to a removable
USB device. This is useful if you are updating the BIOS for multiple identical
systems.)
4. Close all other applications. This step is required. Your system will be rebooted at
the last Express BIOS Update window.
5. Double-click the executable file from the location on your hard drive where it was
saved. This runs the update program.
6. Follow the instructions provided in the dialog boxes to complete the BIOS update.
Feb 16, 2011 | Intel D946GZIS Motherboard
I have an asus pn5sli mobo with 8 gig ram, nvidia 9800gt gpu,running windows 7 and am having crash issues.can you update bios using a usb as I have no 1.44 floppy installed and can you increase ram voltage...
Hello download your files here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5NSLI/#download
Download asus update in the utility for 64 bit system
Next download the latest bios
Please unzip the files before you install.
Install asus update and select update bios from file.
This can be done while the system is running.
Select the bios file you have downloaded
and the program does the rest.
Remember to download the right bios.Flashing the bios with a wrong file will damage the mainboard !!!!!!!!!!!!
And you need to set up bios when the job is done (the boot sequence)
Good luck
Dec 17, 2010 | ASUS P5NSLI (0610839134670) Motherboard
I need to know how to bios update
That is the right procedure. The next step is to type the path of the BIOS file. Have you tried D:\(bios file name)?
Nov 06, 2009 | Computers & Internet
Motherboard
First reboot the computer and enter the bios screen. Disable the bios protect...
Then reboot back into the OS (Presumably windows) and download the bios update from the manufacturer website. It will probably be a zip file containg the bios and the flash utility. Unzip the file and you should have a windows and/or DOS flash utility. If not, the utility should be posted on the website. If the utility is Windows, simpy run the utility. It will ask for the location of your bios file. The update utility will do the rest for you. If the program is DOS, the procedure is similar. Move the utility and bios update into your root directory, reboot, and simpy run the program from the command line.
Nov 06, 2008 | Computers & Internet
How can i update bios of asrock 775vm800. i have downloaded latest file but can't find flash utility on asrock website. ?
before updating your bios make sure there's a valid reason for it... in other words?
1. have you tried other solutions to the problems you may be having
2. is there something in the updated bios that you currenlty need?
3. is there something actually working poorly on your corrent motherboard or built in controlers, sound, usb devices, network controller etc..
when updating the bios there's a rule of thumb that says "if it's not broken don't fix it".. as it may create real problems you may not be able to revert back.
as per installation.. the package with the bios update is an executable file (???.exe) that may come prepackaged in a compressed file (???.rar)... download the file and then use WINRAR or WINZIP a program to unpack the ???.rar file for you to access you exectable file (???.exe) inside the .rar file.
hope it works and good luck..
make sure to back up your data as who knows what may happen...
also.. make sure your computer is not shutdown while your updating/flashing the bios.. this may mess up the board completely!
Sep 21, 2008 | Computers & Internet
Updating BIOS
Different computers different files
You need two files to do the Job read instructions carefully
1 is for bios the other is the program that install it
Aug 30, 2008 | Intel Motherboard
Intel D945GCCR Motherboard Logo
57 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
