Question about Sugden Audio Players & Recorders
Flashing LCD The display on my Sugden CD21 flashes in a wavering style whereas it used to be static.
4 Suggested Answers
pnevai
  • 48 Answers
SOURCE: LCD Display keeps flashing "INITIALIZING"
It needs to be plugged into a properly configured Avaya Definity digital port / wall jack. (NOT a regular telephone line as this can damage the polycom!!!) Does another Avaya digital phone work in that jack? If it does then call polycom for a RMA and eturn the phone under warrenty. If another Avaya digital phone does also does not work you need to check the PBX configuration or there is a wiring error at the jack or the PBX.
Posted on Jul 14, 2007
mplacchetti
  • 3 Answers
SOURCE: LCD monitor no display - flashing power button
Hate to criticize and then not help out. I have this exact same problem with one of my E152 Dell Displays. I have read around and this whole line of displays seemed to have trouble. I found many issues like this and no solutions.
So, I like to tinker and tinker i did. I opened the case, removed the screen and went straight to the power supply board where I found two burned out capacitors.
RATED:
Value Voltage Diameter Height
1000uF 16v 10mm 16mm
Found a great source for replacement parts and instruction to replace the caps at BadCaps.net
Let you know how it goes.
Posted on Apr 29, 2009
richroth
  • 9472 Answers
SOURCE: lcd screen flashing on ge pss26pswass model
Unplug it for 30 mins then plug it back in.
Posted on Dec 03, 2012
Lcd display flashing in out
Display components such as LCDs have limited age and years of service. Flashing and fading are two symptomps usually associated with dying LCDs. How old is your display/radio?
es
May 30, 2013 | Radio Communications
Tv is stuck in stand by mode.
sounds like electrolytic capacitors in power supply examine for swollen or split cases replace with same capacity but higher voltage rating if possible they are only cheap so you could change them all dont forget to observe the polarity
Aug 11, 2012 | Daewoo LCD37INT 37 in. LCD Television
Fridge section has a flashing 4C temperature on the display
Have you checked compressor running, fans working, condenser clean etc?
Apr 28, 2012 | Samsung Refrigerators
LCD TV Wii only displays black and white - no colour no sound
You have to option in LCD Source In-Put.All LCD Have this In-Put
Com posit-Yellow/Red/White (AV)
In LCD Select AV Mode After That Connect Yellow /Red/White as per color pin given in your LCD.
Component-Green/Blue/Red
If you have Component in put in your LCD than select from source component mode for Red/Blue/Green.
Dec 26, 2009 | LG 32LG30 32 in. LCD HDTV
Screen flashes - samsung 215tw LCD monitor
walkstex, I will answer the last ? first. All LCD monitors WILL NEED to have their "cold-cathode-fluorescent-tubes" replaced!!! As long as your display had a Bright, Crisp image displayed on it before this "FLASHING" symptom occured, then you don't need new CCF tubes. Your problem seems to be occuring in the electronic ballast circuit called an INVERTER. It Takes 12-15v DC and turns it into 800-1200v ac to light up the CCF tubes. This is the same technology used in the new style curlieQ screw-in light bulbs called CFL's. Only difference is they use what is known as a CONVERTER circuit----AC to AC!!!! And the tubes hung horizontally on the rear of your LCD panel are thin and straight. So, to answer your first ? Yes, it is an issue of getting the CCF tubes to light up. (backlighting) Now, I should also mention that there could possibly be a problem with the main power supply in the monitor. It is called a "switch-mode-power-supply" (smps) that supplies DC for the digital signal processing board (typ +5v) and 12-15v for the inverter. Well, This typical type of symptom could be as simple as a thermally fractured solder joint on the power supply board or some bad Filter capacitors could also need replacing. I suggest that you search web to find out more about the things I have mentioned in the above text. Do search for things like "swollen capacitors", "Bulging Capacitors" and checkout www.badcaps.net for some pictures of typical failures. Get back to me if you want to carry this any further on your own. Bye for now. I'm louie12fix on fixya or lmistyrel @aol.com
Sep 23, 2009 | Samsung SyncMaster 215TW 21" LCD Monitor
LCD Monitor Blank/Non-Responsive - Dell E173FPC
Next thing I would check is the VGA cable between PC and monitor.
Make sure is in at both ends and if possible try another one.
Do the Dell Menus come up with no VGA cable plugged in? Is the light amber? Flashing or static?
Mar 18, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Monitor works you can see but no light
Check signal cable display is flickering or
flashing. No display over screen it is flashing
even windows desktop also showing but flashing only
Nov 24, 2008 | Computers & Internet
LCD DISPLAY FLASHING
THE REASON THE LCD IS FLASHING IS THIS . yOU HAVE LOST THE PROGRAMING ON YOUR MAIN CPU . WHEN THE CHIP IS REPROGRAMED THEN IT WILL WORK .
Aug 26, 2008 | Nikon Speedlight SB-600 TTL Flash
47 people viewed this question
Top Sugden Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sugden Audio Player and Recorder Expert? Answer questions, earn points and help others
