Question about Acer H7531D Projector
Vertical black bars on H7531D acer projector - Acer H7531D Projector
2 Suggested Answers
Fix-4U
  • 293 Answers
SOURCE: acer 2410 display having 3inches wide black vertical line at the right end
Hi...there,
The problems.. your panel are damaged. Don't bother to replaced...will cost you a lots of $$$.... It's time for retired...
Posted on Oct 14, 2008
Aaer p1101 dlp projector has vertical lines during projection
1,the color starts to go out, it become the white and black,the color is disappear.
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as 3 sesame seeds
Oct 03, 2013 | Acer P1101 Compatible Projector Lamp
Does anyone know the part number for DMD chip in Acer X1260 projector?
Hello i got issue with white and black dots on ACER X1260.
The orignal parts was a 1079-6319W...
I tryed to put on a 1079-6329W supposed to be compatible.
I got white vertical lines on screen and no more pixel dead, this reference seems not compatible ( i think its 18W->19W ; 28W ->29W only).
I tryed to clean up with KF special contact F2, chip pins, socket, cards connectors, but nothing worked, still vertical white lines with 1079-6329W chip ( instead of 1079-6319W).
I hope this can help everyone in trouble with Acer X1260 and other.
DMD chips are not so compatible !!!
Sep 07, 2013 | Acer X1261 DLP PROJ SXGA 37001 Multimedia...
Just bought a acer h7531d dlp projector. From the first run, it shows vertical white lines even without a video source and these lines seem to drop a shadow on the video. Is this a serious issue? Didnt...
I have found that it has something to do with the ribbon between the controls and the motherboard. I had white lines which I can make come and go by adjusting the ribbon. I still have fine black line.
I just unhooked the motherboard and reseated it. Now the projector is working 100% correctly. I have not closed the case yet. It'll probably glitch on me when I do. So in my estimation it isn't that any one part is bad but rather that there are faulty connections. Getting all cable seated properly should be the fix.
It is all together and working perfectly.
Jan 21, 2012 | Televison & Video
7 wide black vertical interference bars on all screens. Equally spaced with normal looking segments. Like the stripes on a flag. On both maintenance screens and program screens, too. The bars are "fizzzy"...
if these lines are pulsating, it sounds like the connection at back of the engine where it connects to the main board. you can try to reseat it and see if that fixes it. otherwise it could be one or the other. really hard to tell without a test fixture. if the bars are fuzzy like they look like they may be underwater then that would be a bad light tunnel.
May 11, 2010 | InFocus ScreenPlay 4805 Multimedia...
Sanyo Z3 Blue Color Problem
the LCD Module of your projector in blue panel is burn so that you can it larger and larger. replace your lcd blue panel. and also the mirror inside your optics.
Oct 08, 2009 | Sanyo PLV-Z3 Multimedia Projector
Acer 2410 display having 3inches wide black vertical line at the right end
Hi...there,
Oct 14, 2008 | Acer Refurbished 11 3 STN LCD DISPLAY **...
White vertical lines in image w/ 2 inch black bar horizontal.
the black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
Nov 12, 2007 | InFocus ScreenPlay 7205 Multimedia...
Acer H7531D Projector Logo
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
