Question about Elite Sl 3000 Ul Sliding Gate Operator
My DoorKing Microplus8069 Gate remote will not work
Remote control reprogram
2 Suggested Answers
  • 5603 Answers
SOURCE: Gate opens randomly in the afternoon without known
Disable the telephone control to isolate that much of the system. You should be able to just disconnect the telephone line into the unit. Do without for a day or so to find if it might be the telephone control. IF IT IS get the telephone company to log the origination of the calls. If it still does it without the telephone, change the codes as it is likely some other nearby person has the same system and his codes are the same as yours. The unit is saying it is getting a valid command... so it has to be coming from someplace. There is a chance one of the remotes in your vehicle is sending this. You might, although it is inconvenient, keep one of the vehicles at a time say several blocks away to see if problem stops. Moisture in the button could cause one of the remotes to be sending the commands.
Posted on Jun 20, 2011
New FM502 Dual gate opener pressed remote which starts the second gate opening then the master moves a few inches stops. Hear 3 beeps 2 seconds 3-. .Conections are good to circuit board! What up!
reprogram the opening sequence in the control box
it should that the first gate opens then the second gate opens a few seconds behind it
closing is the reverse
you can program that only one gate opens
you can also program that one gate is a entrance gate where it opens until you stop it , then when you have passed through , press it again and it closes
read the operating instructions and follow the programming procedures closely
Oct 24, 2016 | Miscellaneous
Gate will open pushing open button but cant use remote
General answers only, sorry. Look for loose or corroded connections, especially where wire nuts were used. Reprogram the remote receiver. Disconnect power to the receiver for a short time. Reconnect and reprogram. I hopes that any of this helps. I have operators to the much like witch craft, a black science!
May 10, 2016 | Elite Gate Opener Sl3000 Slide Gate...
What is wring.?
The programming on your remote buttons probably got overridden. Just reprogram your remote's buttons for the alarm and gate .
Mar 29, 2015 | Building Materials
MY ELITE SL 3000 UL WILL NOT WORK WITH REMOTE. IT WILL WORK WITH THE LOOP. PROBLEM WITH BATTERY OR NEED TO REPROGRAM THE REMOTE, IF SO WHERE IS THE LEARN XMITTER LOCATED PLEASE HELP
Hi Mary, do you have more than one remote for the gate? Your remote needs to be paired with the gate receiver. Normally you need to push a certain button on the control panel to enable learning mode then you press the remote button you want to use. You will have to follow this learning process for your device. Please keep in mind that just any remote will not work with your gate, it needs to be on the same frequency and use the same modulation mode.
Hope this helps.
Oct 28, 2014 | Elite Sl3000 1hp Slide Gate Motor,...
How to program a universal gate remote ?
If you still have the remote that came with the gate controller then you simply match switch positions on both remotes. If that isn't possible then you must open the gate actuator to expose the receiver in it to see what position the switxhes are in then set the universal to match. Be aware that all universal remotes may not have enough code combinations to work. If that's the case then you'll have to get the correct remote for the gate actuator.
Jun 06, 2014 | Multicode Stanley One Button Gate Remote...
I got my centurion gate motor D3. the problem is when i press the remote an LED lights but the gate does not open, i opened the motor cover and there is no light nor sound from the motor. the gate can be...
Try to reprogram your remotes.... or replace the batteries even if the l.e.d. still works (it only takes half a volt to make the l.e.d. work but almost the full charge of the batteries are needed to send a working signal.
Oct 18, 2013 | Televison & Video
How to programme a nova 4 button remote on a gemini gate motor
It's important to know that the Nova remote controls are not compatible with the Gemini gate motor. In order to get these remote controls to work with your Gemini gate motor, you'll need to install a Centurion receiver first (see http://www.centsys.co.za/upload/product_link_files/CS37_Nova_Receiver_Instructions_1031.D.05.0012_4.pdf). Once the Centurion receiver has been installed on your Gemini gate motor, follow the programming instructions as per the leaflet that accompanied your brand new Nova remote control, or download the instructions from http://www.centsys.co.za/upload/product_link_files/English_Transmitter_InsertCS37_1031.D.02.0027_1_Nova.pdf
Feb 22, 2012 | Televison & Video
Hello... I have a motorized gate. The receiver and remote for the gate are from the brand MultiCode from Linear. Been having this very annoying problem. The gate doesn't open when using the remote...
I have heard of this problem before with remote controls for gates and car alarms.
If this only happens in these certain times, it is most likely that you live near a high powered TV or Radio transmitter which can effect the transmission of your remote control.
If this is so you made need to get a technician out from the company that supplies the motorized gate to re tune your remote and receiver in the gate to a lower or higher frequency, so it doesn't interfere.
I hope this helps
MobileJB
Jul 15, 2011 | Multicode 1090 Receiver + Multi Code 3089...
My 3x PI remote cotrol lost the programe and will not open my eletric gate,i need to reprograme them how do i go about
On the gate motor or electronics there is an internal or external receiver with a button on it that can be pressed. Press this button and then press the button on the remote. This should do it. If it does not work you may need a new battery or remote. Thanks BB
Sep 19, 2010 | Garden
Elite Sl 3000 Ul Sliding Gate Operator Logo
Top Elite Home Security Experts
ray gallant
Pierre Legault
Tom Chichester
Are you an Elite Home Security Expert? Answer questions, earn points and help others
