Question about Acer Aspire 5100 Notebook
USB Drivers must re-install every time when i plug in my USB Device
I use mostly an external usb hard-disk, a bluetooth device and a flash-disk on my usb ports. I never plug them off, because i need them everytime. And when i restart or turn on my notebook, i must re-install my usb drivers. I open my device manager and right click to the device. There is an exclamation mark on the driver. When i re-install it, works fine. What can be my problem. I used different os to solve it, but i want to use my XP Professional sp2 on my laptop.
  • 2 more comments
  • sevymli Oct 11, 2007
    Its doesn't work. I need really a solution for my problem. I try this one and i try to "disable selective suspend" for my usb controllers (This solution was from Microsoft) but nothing is happend. By the way i try to update my bios version, now i have another problem. I can't save my power settings. Its changed every time to close the monitor in 15min. and close the hdd's in 30min. When i change it and push to save button, its look like saved. But when i came back to my notebook after 30min. its in suspend mode...
  • Anonymous Apr 30, 2008
    usb ports not working
  • Anonymous Jun 26, 2008
    USB Driver not recognised
  • Anonymous Oct 16, 2008
    non riconosce nessun dispositivo
  • 82 Answers
Install by control panel add/remove hardware
Posted on Oct 10, 2007
2 Suggested Answers
  • 23 Answers
SOURCE: Sound driver problem in LG GS50-6EA2 laptop. OS:-Windows XP SP2
Dear Sshal88
In order to let your sound device work again You have to follow the below instruction:
Start - Right click on My Computer - Properties
You will see many tabs, You have to Click on "Hardware"
Now, Click "Device Manager"
You are in the Device Manager and you see a full list now, go down to find "Sound, video and game controllers" - on the one that mentions the yellow mark, right click and hit uninstall.
Now that the device is uninstalled successfully, you have to click up on the right hand "Scan for Hardware Changes", it will re-install the sound device automatically. You will see on the tray bar on your right hand-down, Your software is installed and ready for use.
Restart your computer, and here we go, it works :)
Posted on Aug 08, 2009
External hard disk drive does not appear
Rupert, You may need to install the drivers for that hard drive. Since you didn't mention the type of operating system you're trying to install the hard drive on (PC vs. Mac), make sure the external hard drive meets the operating system requirements.
If this is a USB external hard drive, make sure the USB controller is set to "enabled" in the BIOS
If the hard drive requires an external power source, make sure that its plugged in.
Check the "device manager" settings for any conflicts with the USB controller or with the disk drives- make sure the device is working properly and that it is enabled.
Mar 22, 2015 | Samsung Computers & Internet
Free usb reboot
You might want to boot from a USB device, like an external hard drive or a flash drive, for many different reasons.
When you boot from a USB device, what you're actually doing is running your computer with the operating system that's installed on the USB device. When you start your computer normally, you're running with the operating system installed on your hard drive - Windows, Linux, etc.
How To Boot From a USB Device
Change the BIOS boot order so the USB device option is listed first. The BIOS is rarely setup this way by default.
If the USB boot option is not first in the boot order, your PC will start "normally" (i.e. boot from your hard drive) without even looking at any boot information that might be on your USB device.
Tip: The BIOS on most computers list the USB boot option as USB or Removable Devices but some confusingly list it as a Hard Drive option, so be sure to dig around if you're having trouble finding the right one to choose.
Note: After setting your USB device as the first boot device, your computer will check it for boot information each time your PC starts. Leaving your computer configured this way shouldn't cause problems unless you plan on leaving the bootable USB device attached all the time.
Attach the USB device to your computer via any available USB port.
Note: Creating a bootable flash drive or configuring an external hard drive as bootable is a task in itself. Chances are you made it to my instructions here because you know whatever USB device you have should be bootable after properly configuring BIOS.
  • Restart your computer.
  • Watch for a Press any key to boot from external device... message.
  • On some bootable devices, you may be prompted with a message to press a key before the computer will boot to the flash drive or other USB device.
  • If you do nothing, your computer will check for boot information on the next boot device in the list in BIOS (see Step 1) which will probably be your hard drive.
Note: Most of the time when trying to boot to a USB device there is no key-press prompt. The USB boot process usually starts immediately.
  • Your computer should now boot from the flash drive or USB based external hard drive.
Jan 02, 2015 | Computers & Internet
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
Nov 07, 2012 | Computers & Internet
Flashing white lights on usb external hard drive
the lights flashing might be your external hrd drive trying to connect to your computer
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps you
Sep 26, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
When i plug in the u3 flash drive it says usb device not recognized
Hi ,dkjran,
If your computer affected by virus will not show in the pc .so you will install it to another pc,and format it .Flash drive can not recocknize,becayse there are some reason .
  • VIrus affected
  • Sometimes when a flash memory stick or USB external hard drive fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory USB hard drive device appears to malfunction it may be possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted then it will indicate that it is Healthy.
If this doesn't work then it is faulty.
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
hope it will help you
Dec 12, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I was given a seagate momentus 5400.3 hard drive and i want to use it as a external usb drive i bought an external case for it and plugged it into my laptop, it see it but in device manager i am getting a...
Try connecting it to a different computer.
EXACTLY what error-message do you get?
When you double-click that entry in Device Manager, and click "reinstall drivers", allow Windows to connect to the Internet to look for a device-driver for the USB-to-disk-drive adapter (no device-driver is needed for the disk-drive itself).
Dec 11, 2010 | Seagate Momentus 5400.3 Hard Drive
Device no reconized , my W7 don't want install drivers for simpledrive 640 GB pinifarina
The usb device not recognized error generally means the right drivers are not present on the computer. I would expect that Windows 7 can recognize most external HDD automatically, but you might need to install a driver for it.
But try the disk on a different USB port, or even computer, to see if it still works properly.
Jun 28, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
How do you get the simpletech external hard drive to store information, and how do you know when it is stored?
Plugging in a USB device before installing the driver disk is the most common USB mistake people make.
An external hard drive, driver properly installed, looks just like a normal hard drive in 'My Computer'. Use it like a hard drive.
If you cannot see it in My Computer when it is plugged in (Go ahead, unplug it and reconnect while My Computer is open) then the driver is loaded wrong. A wrong driver needs to be removed with 'Device Manager', the USB drive DISCONNECTED, the driver reinstalled and the device plugged in at the end or when it is asked for by the installer, not windows (unless it does not have an install disk)
Poof, you can see the disk as a hard drive in My Computer.
See 'Device Manager' on the Internet for help with this.
Mar 20, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
USB's slow and external drive
For the USB ports, you may want to verify that the drivers for the "enhanced USB" are up to date and for USB 2.0 or 1.1. USB 2.0 ports are generally backwards compatible for 1.1 devices. The "enhanced" does indicate USB 2.0 controller. 30mins to backup 3GB to your external drive is a VERY long time. USB 2.0 transfers data up to 480mbps, but if you get an error message indicating that the device can perform faster on a 2.0 port, you maybe transferring data at 12mbps which is USB 1.1 speed
To speed up the transferring of data, identify which USB contoller in Device Manager is the USB port you're having a problem with, and delete it from Device Manager. Then, plug in your external drive into a USB port its never used before.
As for the naming of hard drives, Hitachi partners with several drive manufacturers including Dell and IBM.
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Feb 22, 2010 | Philips Computers & Internet
Computer freeze on saving files to USB 2.0 External Hard Drive (and USB2 flash drive)
Suggest you look at the motherboard book to check if or how many USB connections are in fact USB 2 compatible. Most modern Motherboards only have 2 USB 2.0 Compatible connections, most are 3.0 or 4.0 compatible. Hope this helps, Malcolm Campbell.
Mar 12, 2017 | Belkin Hi-speed USB 2.0 5-Port PCI Card [...
Acer Aspire 5100 Notebook Logo
1,375 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
