Question about Weller Portasol Pro Cordless Butane Soldering Iron Kit
Torch will not turn on after last filling - Weller Portasol Pro Cordless Butane Soldering Iron Kit
Tip
Flashlight Battery and Bulb Installation and...
FLASHLIGHT
BATTERY INSTALLATION FOR TORCH:
Open the Torch Battery Door located on the bottom of the Torch.
Insert 4 “A A” (1 .5V UM-3) (not included) batteries (alkaline
batteries are recommended) into the torch compartment. Be sure
the polarity (+ and
-) matches, as marked inside the battery
compartment.
FLASHLIGHT:
Slide the Torch Function Switch to the “FLASH” position, the Torch will light. To turn off, slide the Torch Function Switch to the “OFF’ position.
FLASH/BLINK FUNCTION:
Slide the Torch Function Switch to “FLASH/BLINK” position, tha Torch will light and thc bulbs on both sides of Torch will blink.
BULB REPLACEMENT:
Rotate the Torch Cover anticlockwise to hear “click”
then p
ull out the cover, remove the old bulb. Then pull
out the torch cup, remove the blinker’s
old bulbs and
reinstall new bulbs. Replace the torch cup, then reinstall
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
Why cannot i install torch browser on my laptop?
It contains malicious software and your anti malware programme, luckily has blocked it. If you want junk in your system, fill your boots by turning anti virus off.
Oct 22, 2014 | Computers & Internet
Blackberry Torch Charging problem
Try replacing the usb cable. A lot of people have had the same problem. Updating the operating system might also fix the problem.
Jan 03, 2014 | RIM BLACKBERRY TORCH 9800 TOUCH SCREEN...
Why won't my blackberry torch turn on completely?
This may be due to the following reasons:
1. The battery may be down. Recharge.
2. Your firmware(Blackberry OS) may be corrupt due to some physical or software problem.. Try to Update it.
3. Some lastly installed software/app may be causing any problems.. Try to Restore device settings from backup..
4. The last installation may require device rebooting and it is nmt able to do that...
Jan 01, 2012 | Motorola Cell Phones
The crank shaft front pulley bolt on a Toyota Camry 94 (5S-FE motor) is seized. How can I stop the motor from turning to get the bolt undone? Its an auto.
If the bolt is seized and u tried everything!
The last resort would be to torched the BOLT untill it loosen up!
Removing and torching it, might as well replace the CRANK OiL SEAL, carefull not to burn the CRANK PULLEY, some have a RUBBER insulation in the mid pulley!
Dec 01, 2010 | Toyota Camry Cars & Trucks
The Blazer micro torch does not ignite (no hissing sound for the gas either) and we did fill it with butane? Any suggestions - have had it for awhile - maybe it needs new flint? or whatever ignites it....
Hi. Get a piece of very fine wire, hardware store is a good source, and run it into the nozzle. Chances are that the nozzle is clogged. Once it is hissing again it will ignite unless you also need a new flint. J.
Jul 08, 2010 | Omega Blazer Self - Igniting Butane Micro...
Burners do not adjust and are on full blast and uneven.
The Controls, once they ware out they are not serviceable most of the time.
May 20, 2010 | Jenn-Air JLG7130A
Zelda blowing out torches
try calling nintendo at 18002553700 or go to www.nintendo.com for cotsumer service and tell them what is happening and give them the number on the DS (my is NU40286551 [1] THE LAST "1" IS IN A BOX)
gamer_freak_93
Jan 01, 2008 | Nintendo DS Lite Console
Weller Portasol Pro Cordless Butane Soldering Iron Kit Logo
153 people viewed this question
Top Weller Welding Tools Experts
Lawrence Oravetz
Mike
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
