Question about Ricoh Aficio 1018D Copier
How do I clear the of error sc390 in my ricoh 1018 copier?
NALDZ
  • 38 Answers
SOURCE: Functional Problem with RICOH Copier Error No-SC:541
YOU NEED TO RESET THAT CODE
Posted on Oct 22, 2008
Nic61
  • 1073 Answers
SOURCE: I NEED Ricoh Aficio 1018 Printer/COPIER AND SCANNER DRIVER
http://support.ricoh.com/bb/html/dr_ut_e/ra/model/x1015_18/x1015_18en.htm
There you go M8!
Just selcet your OS and download the files you need
Good luck to you
If you find my answer helpfull, dont forget to vote
Posted on Dec 15, 2008
  • 7 Answers
SOURCE: error code sc500
Your main motor is hard to turn.. Check your Drum unit. Pull it out then on the back side you'll find a small agitator gear then tried to turn it. If it doesn't rotate then you might have to change its paddle gears, idle gear or that development sleeve is stuck. Hope it helps.
Posted on Apr 20, 2009
SOURCE: used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Posted on Sep 14, 2009
SOURCE: Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Posted on Dec 07, 2009
I replaced thermistor on ricoh 1018 and still have sc error 546...can't seem to reset it
reset by going into service mode "clear modes (yellow) and 1 0 7 then hold stop for 5 or so seconds -Carl
Jan 27, 2016 | Ricoh Aficio 1013 All-In-One Laser Printer
How could i solve the error sc390 on ricoh
This Error is for TD Sensor but most of the time when you replace the Drum kit the Copper bising plate on the back side of unit gone out of position, you can check it by open the rear side of Drum Unit
Sep 26, 2014 | Ricoh Office Equipment & Supplies
How do I clear error sc390 on Nashautec 1505 photocopier
  • Press C the yellow 4sec
  • Press 107
  • Press C the Orange Until display changed
  • Press 1
  • Go to mode by arrows
  • Chose clear all memory
  • Press Yes and # then turn of/on
  • If not so or some times the code return chick the sensor under the developer tank and clean't from inside the developer tank
  • also chick the connector of the tank pull out the D/Tank
  • at the other end of the tank and clean't well.
Jul 20, 2012 | Ricoh 6513 Copier
Error message sc390
SC390: TD sensor error
-Definition- [B]
The TD sensor outputs less than 0.5V or more than 4.0V 10 times consecutively
during copying.
- Possible causes -
· TD sensor abnormal
· Poor connection of the PCU
Jul 07, 2011 | Ricoh Office Equipment & Supplies
Sc390
SC390 = Toner Density Sensor abormality
Possible causes:
  • Poor concentration of developer
  • Toner density sensor faulty
Are the prints/copies coming out ok? If the copies are very faint or heavily overtoned then changing the developer may cure the error code. If the copies look OK then you probably need to get the toner density sensor replaced by an engineer.
Hope this helps.
Feb 10, 2011 | Ricoh Aficio 450 Copier
Sc390
- Possible causes -
Dec 30, 2010 | Ricoh Aficio MP 1600L Black and White...
Mi copiadora es una ricoh oficio1022s/p y marca un error sc390
TD sensor error
Symptom: The TD sensor outputs less than 0.5V
consecutively during copying.
Possible Cause: • TD sensor abnormal
• Poor connection of the PCU
Dec 29, 2010 | Ricoh AC104 All-In-One Laser Printer
How can i solve error code sc:302 in ricoh Aficio 2000 copier.
You should have a service technician take a look at your copier. SC302 is a charge roller current error, and it could be caused by a number of things, from a dirty charge roller to a faulty high voltage supply board.
In the meantime, try turning the machine off, unplugging it, and then plugging it back in and turning it on the see if the error message will clear.
Aug 24, 2010 | Ricoh Aficio MP 2000 Black and White...
Have an aficio 1018 copier with an error code SC544 any ideas ?
that's a fuser unit error do an Sc reset and restart the machine if not replace the fuser unit
May 19, 2010 | Ricoh Aficio 1018 Printer
My Ricoh 2232c copier has displayed error SC374 can you tell me what this means?
SC322 Laser synchronization error SC324 LD drive current over SC390 TD sensor error 1 SC374 Development bias leak SC393 TD sensor error 2 SC401 Transfer roller leak error 1
Jan 14, 2010 | Ricoh Aficio 2232C Color Copier
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
