Question about Acer Extensa 390CX Notebook
When trurning on unit lcd is blank - Acer Extensa 390CX Notebook
    Top Expert:
  • 12,223 Answers
See the flowchart and fix it. God bless you
when trurning on unit lcd is blank - 1af513c3-4ef7-4568-8adf-beaace756a3f.gif
Posted on Nov 24, 2013
Lcd blank
From the information I have, the unit will need to be repaired. No quick fix to repair for a blank display problem. Either the cable to the LCD screen became detached or the display is bad. The cable will be internal.
Nov 29, 2013 | Samson Graphite-49 Keyboard Usb Midi...
Is not charging
Blank LCD on these models going out are usually due to the PCB connection.
I found units I've seen have broken traces or the pins mounted on the PCB have lost their connection to the traces...
this is the ribbon cable from the display to the main UPS PCB...
Oct 03, 2012 | Tripp Lite Tripplite Omniplus 1000 LCD UPS...
Slow coming on. Blank screen until you press the on button a few times
guest, If you do not have any time to explore (investigate, read) then trade your old unit for new!! If that not option you wish to take , then read fixya monitor profiles of "louie12fix" , "budmrtn", "buddymc" and other tech's that specialize in repair of "cold-cathode-fluorescent-lamp back-lit lcd monitors. Follow all "links" you find in the profiles and view some video clips on YOUTUBE that deal with "lcd monitor disassembly" and "lcd monitor repair" to learn just WHY your unit acts the way it does. Why don't you try the "flashlight-test" that EVERY owner of an lcd monitor should know when a BLACK or BLANK screen shows up when it shouldn't be there in the first place. My best guess is that your monitor's problem is internal to unit and not a software problem. 12fixlouie Bye for now
May 19, 2010 | Gateway FPD1975W 19" LCD Monitor
Va912b first cuts on with mostly blank but with broken strips of lines from top to bottom and have some together and some with blank seperation between them. then goes blank
joaye, First place to look would be the monitor's "switch-mode-power-supply" and /or the INVERTER circuit. When strange things start to occur with LCD monitor's w/CCFL backlighting, the first place to look would be the internal or external SMPS for the unit. You should be careful in your third use of the word "BLANK". Some monitors will be BLACK and not BLANK! Some will be both BLACK and BLANK. Read more Black screen stuff in my profile and you will understand WHY your unit is behaving like it is and some useful options you and other's like you have. Also visit www.ccl-la.com/badcaps.htm and www.lcdparts.com or YOUTUBE for videos on lcd repair or lcd monitor disassembly FYI DIY type stuff. I'm 12fixlouie on fixya.
Dec 05, 2009 | ViewSonic Computers & Internet
THE LCD DISPLAY WENT BLANK AND IT SEEMS THAT THE
Try unplugging the unit for five to ten minutes and plug it back in. The default settings should reset
Jul 19, 2009 | Freezers
Blank screen
probably failure in the LCD controller IC in the lcd controller board. that no signal was sent out to the lcd driver IC thus you could only see white display. A replacement of LCD panel is the best solution. I suggest to bring the unit to an authorized service center to properly diagnose & fix the problem. regards
May 21, 2009 | ViewSonic OptiQuest Monitor
Poloroid 42" lcd monitor went blank
30 YR SERVICE TECH
YOUR UNIT NEEDS EITHER THE POWER SUPPLY BOARD OR THE MAIN TOTAL ASSY.TAKE IT IN TO A AUTHORIZED SERVICER.
Jan 12, 2009 | Polaroid FLM-4201 42 in. LCD Television
HANDY CAM LCD SCREEN BLANK
Inside the door hinge area is a small switch that normally would turn off the viewfinder and turn on the LCD panel. THat switch could be defective or mechanically not being switched. WIthout opening up the unit, I can not tell specifically. This shouldbe a simple repair for any shop that repairs cameras.
Dan
Oct 06, 2008 | Sony Handycam DCR-HC30 Mini DV Digital...
Sony LCD HS73 LCD goes blank 2sec.
defective backlight inverter unit. Replace the inverter unit or chek if there is any dry joints inside the unit.
Apr 02, 2008 | Sony SDM-HS73P 17" LCD Monitor
LCD Blank when in camera or movie mode
Defective ccd imager!! There's an internal loose inside ccd imager. Sony will replace this ccd imager free of charge. Year 2002 up to 2005 released units has a factory defect ccd imager. the company recalled those units and replaces with a stronger version of ccd imager.( they are still doing it). check it out.
Sep 06, 2007 | Sony Cyber-Shot DSC-P100 Digital Camera
Acer Extensa 390CX Notebook Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
