Question about Kyocera Echo Greatcondition Bad Esn Flash Cricket Metropcs Uscelular
UPGRADE ROM/ROOT/FLASH FOR SPRINT - Kyocera Echo Greatcondition Bad Esn Flash Cricket Metropcs Uscelular
Someone has hacked my phone,lg Optimus s ls670 cdma, they have somehow installed a VPN into it. How do I fix this nightmares? They have installed root files or file, I had a ransom app on it2weeksago
That doesn't make too much sense but I would take as much information as I could, install it on an external sd or memory card. Then do a factory reset.
If phone has a recovery installed I would download a factory rom for that particular phone then flash it or side load it onto the phone and start over.
Good luck
Oct 08, 2016 | LG Optimus S Ls670 Android Touch Screen...
I root my phone but now Phone stuck at boot How to fix and how to root my phone properly
By this time, The phone will dead. I think you won't reuse this. You can't do it. It is dead man
Aug 09, 2016 | Samsung Galaxy Grand Prime G530H/DS...
There's a problem on my DS R4 game, after 8 hours of game I can't begin a battle because when I do a black screen appears and the music continue but I can do nothing to continue the game
Normally this happens because the game you downloaded, also called a rom, is incomplete or is not compatible. The solution is to download a different rom of the same game and see if it works. If not, then you may need to upgrade the R4 software available here, http://www.r4ds.me/download/r4ds.html For a how to video, go too, R4 DS Card Firmware Download And Set Up For R4 DS
Hope this helps.
Apr 22, 2014 | Video Game Consoles & Games
I need to find a custom CyanogenMod Rom to copy to my SD card so I can upgrade my OS.
Hi Michelle Shumate, I can see that your phone model is out of date, there is one small problem, and that is that the only CM ROM available for your device, that I've known so far, is still GB, and checking the CM webpage notice that the ROM has been discontinued. But if you still want to go ahead and do it, I'll post some links and video to help you out. Notice that this is on your own and I won't be responsible if anything goes wrong or your brick your phone.
The first thing you need t do is root your phone. Here is a YT video on how to root with one click and also how to install a custom ROM.
How To Root And Install Custom Rom For Samsung Indulge
Before proceeding with the root, make sure you have the usb drivers for your model install in your computer.
Mar 14, 2014 | Samsung Cell Phones
1005ha bios update usb
Upgrading BIOS is dangerous and can cause fatal damage to your PC. If you are aware of that and decide to take this risk, then continute. 1. Visit http://support.asus.com/download/download.aspx?SLanguage=en-us, search 1001HA and choose DOS as operating system. Download latest bios rom file.
2. Save and extract the downloaded file. You will get a rom file named like "1301.rom" 3. Format a usb pen drive to FAT-16 partition. In my case I used a 32 MB SD card which came with my old Kodak camera, and I used a SD card reader that PC can see it as a usb disk. Copy 1301.rom to its root folder and rename it to 1005HA.ROM. The reason for renaming it to 1005HA.ROM is that EZ Flash on this 1001HA netbook looks up rom with this name. If EZ flash failed saying trying to find a rom file with another name, just shutdown the netbook and rename your rom file to the required name and try again. 4. Plug in the usb pen drive and reboot the netbook. Make sure that during the ASUS splash screen, press ALT+F2. Then EZ Flash will run automatically and try to locate the usb drive and read from file 1005HA.ROM (in my case). 5. It takes around one minute for me to upgrade everything. DO NOT TURN OFF OR EVEN TOUCH YOUR NETBOOK DURING UPGRADE. Read the messages on the screen and when it says you can press the shutdown button, you can turn off your system. 6. Turn on your netbook again and enter BIOS to check if the BIOS version is up to date.
http://www.youtube.com/watch?v=61awfpVe49k&feature=player_detailpage
Jun 11, 2012 | ASUS Eee PC 1005HA Atom N270 TFT Notebook
Hi, I have a Sprint HTC EVO 4G phone. I have version 2.2 software and I am trying to upgrade to 2.3. When I try to upgrade my phone freezes. I've tried to upgrade several times but all my phone...
The fact that your phone is rooted voids the warranty and leaves you out in the cold with Sprint. If you can revert your phone back to factory settings ( backup first) you should be able to upgrade to the new OS, re-root your device, then re-upload your backup with the 2.3 OS in effect
Good Luck!
Jul 26, 2011 | HTC EVO 4G Smartphone
Need to install the adobe flash player on my motorola clique
The CLIQ runs Android 2.1 if it is upgraded to its most recently release ROM, which doesn't support Flash. You may find that you can root your phone and install a ROM with 2.2 and Flash support by checking out ppcgeeks.com
Mar 16, 2011 | Motorola Mobility CLIQ Cell Phone
WM 6.1 flash compatable with Australian NextG network settings?
The GSM/3G bands are hardcoded in the phone's radio chip, for what you can flash your phone to v1.77 WM6.1 ROM. This ROM was plublished by i-mate back in Nov. '08, and it is the most recent ROM released for the 9502 so far.
You see, the i-mate's Configurator application, which you most probably used with the stock WM6 ROM, will still be there. So, your internet and MMS settings will, most probably, be done automatically after flashing your device. If not, just check Telstra's Help page, or call them, to manually set those data.
Just my 2 cents... Carlos
May 08, 2010 | i-mate Ultimate 9502 Cell Phone
Htc ppc6900
If you ask Sprint they will try to sell you this phone-as-a-modem plan, but they are really just selling their support to get you going... if you can get connected yourself they will not charge you, but if you need their help then it's a monthly fee for the service.
Two options:
  1. I pretty sure the latest ROM upgrade will allow for this: http://www.htc.com/us/supportdownloadlist.aspx?p_id=76&cat=2 (be sure to backup all your files, contacts, programs, etc. as the upgrade will wipe out everything).
  2. It's not free, but I have been using PDAnet for Windows Mobile from http://www.junefabrics.com - it works great I started using it befor the ROM upgrade and liked it so much (and since I paid for it) I've been using it evr since.
Jun 30, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Kyocera Echo Greatcondition Bad Esn Flash Cricket Metropcs Uscelular Logo
16 people viewed this question
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
