Question about Shure KSM27 Professional Microphone
No sounds pass through the unit
I purchased the unit over a year ago from a reputable dealer. I didn't put it into service until a month ago but it didn't reproduce any of the music. I'm using a Mic Power I 48volt Phantom power supply (PB23). Any help would be much appreciated
This microphone thru out in canal dont repair dont exchange
Posted on Oct 10, 2007
SOURCE:
Looking for the manual for the Sunbeam Bread Maker
www.sunbeam.com/...support/service-and-support.ht...
Jun 05, 2015 | Sunbeam Kitchen Appliances - Others
I received bad gas, so far they had to change my oil, fluid pump, spark plug and my car still want stay started! The bill is increasing yet they dont know what
Oil changes have nothing to do with your car not starting. You obviously want to keep it changed every 3,000 miles but changing it monthly wont make your car run better. i would suggest you take it to a dealer where they will actually diagnose and fix the problem instead of just throwing parts at it. I know dealerships have a reputation of being expensive but many times, in a situation like this, it is cheaper to go there and have it fixed correctly the first time rather than going to a "shade tree mechanic" who is just guessing and slapping parts on, at your expense, hoping he/she solves the problem. Good Luck!
Nov 15, 2011 | Cars & Trucks
BATTERYS DIE AFTER 3 MONTHS, ON A FE500V?
The batteries in a FERRUPS typically last 3-6 years depending on how many power outages you have, how much heat there is, etc. So, 3 months doesn't sound right. Hopefully, you are buying batteries from a reputable source. Eaton bought Powerware about 6 years ago and retained their service network which has lots of techs trained on the FERRUPS. I suggest you contact them:
Toll Free: 1 800 356 5737
E-mail: [email protected]
Dec 14, 2010 | Powerware FERRUPS FE500 (FA000AA0A0A0A0A)...
I am having problems with my condensing unit, fedders mod# ch48acd1vf. The unit will come on for about a minute and shut off and does not come back on. I have 24 volts at the red and white wires and the 2...
Whoever installed this unit need to come back and fixed the problem. Normally I would say dirty coil causing unit to shut off on high pressure but since it's 4 months old coil should be good.
You need the installer to put his guages on and check pressure because I seen a lot of so call Technician leave the service port back seated so you are not having any refrigerant flow
Jan 10, 2018 | Heating & Cooling
MY CAR'S AIR CONDITIONING ISN'T WORKING. MY SON
mcdevito75 here, either your son in law didn"t put in enough freon or the compressor is not working, Have your local shop check it out.
Jun 18, 2010 | 1998 Cadillac DeVille
System shuts off and turns to red light standby
Hello. You may want to double check your connections and cables. The only time I've ever heard a clicking before a system shut it's self down was when a kid had stuck the battery cover from a TV remote into the disc drive.
Also, if the PS3 keeps acting like that, Sony will repair/replace the unit for free including shipping since it's under a year old. Thanks and good luck!
Jan 09, 2009 | Sony Playstation 3 (PS3) Console
Sharp aquos hdtv has sound but shows a white screen
yes and no. That particular tv you have is done for, but if you just purchased it 6 months ago, you are still within you 1 year warranty with sharp. they will ask you to take it to a authorized service center and you need to follow through with the process. about a week or 2 will pass and the service center will deem the unit unrepairable and sharp will replace it if they cant solve the problem. give em call..good luck 2u
Dec 24, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No sound pass through
1) Try a different phantom powered mic into the same cable and same phantom power supply to see if it works.
2) Take the mic to a friend or the dealer to see if it works into a different mixer.
If the mic doesn't work into a different mixer, return it to Shure for repairs: www.shure.com/service
Sep 24, 2007 | Shure KSM27 Professional Microphone
Sure KS M27 does not pass through sound
ty anther power phantom once and differnt cable
Sep 23, 2007 | Shure KSM27 Professional Microphone
Shure KSM27 Professional Microphone Logo
93 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
