Question about Canon Office Equipment & Supplies
Canon MG6460 won't print on Mac
A new Canon MG6460 has been successfully installed on a Mac running OS X Lion, I installed the latest firmware but it will not print anything. It is currently connected via Ethernet
New too mac osx software having trouble setting up my canon pixma mg6460 software? any help much appreciated
Posted on Feb 02, 2014
SOURCE: Canon MP210 with Mac OS X 10.4.11 problems with printing docs
Hi
I have OS-X 10.4.11 and had the same issue; any printing just spat out blank pages.
I installed the following driver which completely resolved the issue:
http://software.canon-europe.com/software/0029270.asp?model=
There's a similar one for 10.5 that I haven't tested, to be found here:
http://software.canon-europe.com/software/0028432.asp?model=
If you use 10.5 and this driver works for you, please let others know by posting here, too.
Good Luck
Draqul
Posted on Dec 22, 2008
SOURCE: Canon Pixma MP610 not connecting to scan
Had the same problem. Don't think it scans wireless; worked fine when I connected with USB cable.
Posted on Jun 12, 2009
57 varieties
  • 1653 Answers
SOURCE: Pixma Mp630 dont sacnn and dont print Cd with Mac OS X 10.6
I can sympathise as a fellow MAc OSX user!
Make sure that you have all the installation files shown at the following link
http://software.canon-europe.com/products/0010643.asp
In Mac then start Solution Menu from the menu bar, select the Go menu, Applications, Canon Utilities, Solution Menu, then double-click Solution Menu. Select
Use Solution Menu to get the information on the machine or change the print settings by only clicking buttons on a screen. With Solution Menu, you can start the software applications supplied with the machine or display the operating instructions. It also provides you with the information on troubleshooting.
If you get problems then please come back to me for assistance with details of what you have done and what errors you get etc.
Posted on Sep 30, 2009
  • 1099 Answers
SOURCE: Panasonic KXMB2000 AllInOne Laser Printer drivers for mac os x
Go to http://panasonic.net/pcc/support/fax/common/table/macdriver.html#p01 it is beta but it should work. Hope this helps.
Posted on Jan 09, 2012
  • 5 Answers
SOURCE: Need a printer driver for Dell 2155cn for Mac Os X Lion
Google Cloud Print works with all printers I've tried. Good solution for those printers with no Mac drivers
Posted on Feb 10, 2012
Factory reset macbook without disk
You cannot do what you want without the original installer disc that came with the computer or a later version of OS X installer, unless the computer came originally with Lion or Mountain Lion.
Follow these instructions step by step to prepare a Mac for sale:
Step One - Back up your data:
A. If you have any Virtual PCs shut them down. They cannot be in their "fast saved" state. They must be shut down from inside Windows.
B. Clone to an external drive using using Carbon Copy Cloner.
1. Open Carbon Copy Cloner.
2. Select the Source volume from the Select a source drop down menu on the left side.
3. Select the Destination volume from the Select a destination drop down menu on the right
side.
4. Click on the Clone button. If you are prompted about creating a clone of the Recovery HD be
sure to opt for that.
Destination means a freshly erased external backup drive. Source means the internal
startup drive.
Step Two - Prepare the machine for the new buyer:
1. De-authorize the computer in iTunes! De-authorize both iTunes and Audible accounts.
2, Remove any Open Firmware passwords or Firmware passwords.
3. Turn the brightness full up and volume nearly so.
4. Turn off File Vault, if enabled.
5. Disable iCloud, if enabled: See What to do with iCloud before selling your computer.
Step Three - Install a fresh OS:
A. Snow Leopard and earlier versions of OS X
1. Insert the original OS X install CD/DVD that came with your computer.
2. Restart the computer while holding down the C key to boot from the CD/DVD.
3. Select Disk Utility from the Utilities menu; repartition and reformat the internal hard drive.
Optionally, click on the Security button and set the Zero Data option to one-pass.
4. Install OS X.
5. Upon completion DO NOT restart the computer.
6. Shutdown the computer.
B. Lion and Mountain Lion (if pre-installed on the computer at purchase*)
Note: You will need an active Internet connection. I suggest using Ethernet if possible because
it is three times faster than wireless.
1. Restart the computer while holding down the COMMAND and R keys until the Mac OS X
Utilities window appears.
2. Select Disk Utility from the Mac OS X Utilities window and click on the Continue button.
3. After DU loads select your startup volume (usually Macintosh HD) from the left side list. Click
on the Erase tab in the DU main window.
4. Set the format type to Mac OS Extended (Journaled.) Optionally, click on the Security button
5. Click on the Erase button and wait until the process has completed.
6. Quit DU and return to the Mac OS X Utilities window.
7. Select Reinstall Lion/Mountain Lion and click on the Install button.
8. Upon completion shutdown the computer.
*If your computer came with Lion or Mountain Lion pre-installed then you are entitled to transfer your license once. If you purchased Lion or Mountain Lion from the App Store then you cannot transfer your license to another party. In the case of the latter you should install the original version of OS X that came with your computer. You need to repartition the hard drive as well as reformat it; this will assure that the Recovery HD partition is removed. See Step Three above. You may verify these requirements by reviewing your OS X Software License.
Dec 31, 2013 | Computers & Internet
Tip
Experience Apple's Mac OS X Lion in the First Time
Normal 0 7.8 &#30917; 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:&#26222;&#36890;&#34920;&#26684;; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} <p><a></a><a></a><a><span><span><span>This week Apple gave the world an early look at their forthcoming operating system, and tech journalists got their first peek at some of the concepts driving development of Apple's next desktop operating system, dubbed Mac OS X Lion.</span></span></span></a><br /> <p><span><span><span><span>Could the company be preparing to bring one of the most frequently demanded features, a fully functional Mac OS, to the iPad?</span></span></span></span><br /> <p><span><span><span><span> </span></span></span></span><br /> <p><span><span><span><span>Our brief glimpse of Mac OS X 10.7 Lion told us one thing: Apple is attempting to bridge the gap between their mobile platform, iOS, and their Mac operating system, <a>Mac OS X. When it arrives next year, Mac OS X 10.7 will bring new several staple features of iOS 4 to Apple's Mac computers, specifically Launchpad, an icon-focused interface that arranges all of your available apps, complete with app folders, just as they would appear on your iPhone, iPod touch, or iPad, on your Mac desktop.</a> Unlike a full iOS interface, however, Mac OS X 10.7 Lion makes the system toggleable, and users will still have access to the dock, desktop, and menus of a full Mac OS. </span><span><br /> <br /> </span></span></span></span><span><span><span><span>Furthermore, apps designed for Mac OS X 10.7 will feature full screen modes that occupy your entire desktop or laptop screen, much like an iPad app, and will support trackpad gesture controls that could easily be applied to a touchscreen interface. <br /> <br /> Primary among those drivers, as Apple chief executive Steve Jobs announced, was bringing to Lion what Apple had learned from its experience with the successful iPad tablet. Like the iPad, Lion will run apps from a similar central app store. A new Launchpad for apps and a Mission Control feature will combine the talents of Spaces, Expos&eacute;, and Dashboard.</span></span></span></span><br /> <span><span><span><span>Jobs announced that Lion would emerge in the summer of 2011, but the Mac App Store will open within 90 days. Another anticipated Mac OS feature is coming along much sooner: Facetime for Mac, which will let Mac users make video calls with iPhone 4 and iPod touch users. It is available now. So it's not part of Lion, but coming already for Snow Leopard.</span></span></span></span><br /> <span><span><span><span>Multitouch support was another much-predicted feature for Lion, but Jobs was careful to state that it wouldn't be in the form the pundits expected. Apple researchers determined that multitouch doesn't work on vertical screens, because of arm fatigue. Instead, Lion's multitouch support will be for larger trackpads. If you want multitouch on an actual screen, you'll have to get an iPad. </span></span></span></span><br /> <span><span><span><span>Over 7 billion iPhone, iPad, and iPod touch apps have been downloaded from the Apple App store, and then the ipad or ipod touch ursers </span></span></span></span><a href="http://www.ipad-to-mac.org/guides/transfer-music-from-ipad-to-mac.html"><span><span><span><span>transfer music from ipad to mac</span></span></span></span><span><span><span></span></span></span></a><span><span><span><span> , Jobs noted that there will still be places other than the store to get Mac apps. Installation will be as easy as it is on the iPhone, and developers will get the same 70 percent of revenue on paid apps. </span></span></span></span><br /> <span><span><span><span>"We think bringing some of these things back from</span></span></span></span><a href="http://www.ipad-to-mac.org/"><span><span><span><span> iPad to Mac</span></span></span></span><span><span><span></span></span></span></a><span><span><span><span>, with some fresh new things like Mission Control, will really delight Mac users," Jobs said. With all the attention bestowed on the iPad and iPhone, it's about time Mac users get to enjoy some of the delight. This was just a first glimpse, but it's promising. We'll be there when it debuts.</span></span></span></span><br /> <span></span><span></span><span></span> <p><span> </span><br />
on Oct 26, 2010 | Computers & Internet
Hi! How to perform factory reset with a macbook air mid 2013? Is there a battery reset as well? Thanks in advance for the help!
side.
startup drive.
4. Install OS X.
Nov 04, 2013 | Apple MacBook Air
Cannot find driver/software for my dusty Canon imageCLASS MF3240 on mac OS 10.7 Lion?
There is no driver for your printer to work with OSX. It was for Windows OS only. AND Apple does not support this particular model either.Link below list support printers by Apple OSX>
http://support.apple.com/kb/ht3669
Jan 08, 2013 | Canon imageCLASS MF3240 All-In-One Laser...
Lide 60 not working in mountain lion
Guide to installing Canon CanoScan LiDE 35, 50 and 60 on Mac OS X 10.8. Mountain Lion:
FIRST PART: DELETING OLD LiDE DRIVERS AND SOFTWARE
  • If this is the first attempt to install the scanner, skip this part
  • Trash the following files/folders from these folders:
HD:/Library/Image Capture/Twain Data Sources
delete the CanoScan CanoScan XXXX.ds file
(Make note of any other files that may be in this folder. If other files are present, move them to the desktop for now. Then place them back after successfully using the scanner.)
HD:/Library/Preferences
delete the 'CanoScan XXXX' folder
HD:/Users/Shared
delete the folders containing the name CanoScan, or starting with CNQL.
HD:/Applications
delete the CanoScan Toolbox Application
HD:/Users/YOUR-MAC-USERNAME/Library/Preferences
delete any items named "CanoScan Toolbox"
  • Restart your computer, then empty the trash
SECOND PART: MAKING YOUR SCANNER WORK
  • Make sure your scanner is well connected
  • Download the right driver depending on your Model. Also download the Scanner Software. Copy the filenames and search them via Google. Make sure you download the Canon files from an official Canon domain.
CanoScan LiDE 50 and LiDE 35 work both with the 35 driver:
lide35osx7721en.dmg
CanoScan LiDE 60 driver:
lide60osx11131en.dmg
VueScan Software:
http://www.hamrick.com/#download
VueScan 9.2 (or later) x32 for Mac OS X
Alternative to VueScan: CanoScan Toolbox. I prefer VueScan.
Try your luck with Version 4 or Version 5.
CanoScan Toolbox 4: cstbosx4934ej4.dmg
CanoScan Toolbox 5: cstbosx5014ej4.dmg
  • Open the downloaded driver file (lide35osx7721en.dmg or lide60osx11131en.dmg)
  • and Double-click the ScanGear file, install and restart when prompted
  • Open the downloaded VueScan file (vuex3292.dmg) and drag the VueScan application to the Mac Applications folder
  • Open the VueScan application. The scanner should be recognized automatically.
(Alternatively try and install CanoScan Toolbox 4 or 5)
Nov 04, 2012 | Canon Office Equipment & Supplies
Mac OS X Lion compatibility with HP officejet K80
Hi Li Louba,
Thats right,you cant print because there are no Hp K80 printer drivers support for your Operating System[Mac OS Lion] as yet.Check out your printers compatible Operating Systems here.
Hope this helps.Thanks!
Dec 05, 2011 | Computers & Internet
482 people viewed this question
old marine
old marine
