Question about Explorer Appliances GRQ15 Top Freezer Refrigerator
Propane refrigerator Lower refrigerator does not cool Freezer works.
Freezer works fine on propane but not the fridge
You may wish to check the flue clear anything that you find. Old birds next etc. Also make sure the flame and orifice are clean free from debris or rust. Propane should burn blue not orange. Incorrect gas setting if the flame is orange. Some yellow at the tip is ok. Proper adjustments are critical. Have you tried the unit on AC?
Other tips I have read indicate possible freezing in the back.
Defrost freezer completely as some here mentioned and restart see if this helps. Here is a good RV forum I saw good tips worth investigating.
If your not comfortable cleaning the jets and adjusting the flame have a professional do this. Safety comes first!
Freezer works refrigerator doesn iRV2 Forums
Mar 28, 2014 | Dometic RM2652 Refrigerator
Fridge does not get cold during propane gas function only. Upper Freezer section does. Whole unit does perform and freeze and cold function fine with electric and generator function. Why only during...
According to the manual the following is the most likely items to cause that failure. But since it is only in the frigerator section and not the freezer section it could be the lower circuit board.
LP Gas
Orifice
Flue Baffle
Flue Tube
Burner
Lower Circuit Board
Sep 10, 2011 | Dometic RM2652 Refrigerator
Freezer working OK, lower refrigerator is barely cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Amana Refrigerators
The freezer compartment of my refrigerator is working. But the lower compartment is not working.
heatman101
Nov 18, 2010 | Electrolux ERC3709
Danby propane fridge model # dpr2262w-6. the freezer still works great but fridge portion does not . the fridge has a bad smell. the fridge is at a cabin and no service
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 24, 2010 | Danby DPR2262 Top Freezer Refrigerator
Danby Propane Refrig-- Low Cooling Output
good day,
hope this link below will solve your problem.
ref
Aug 12, 2009 | Danby DPR2262 Top Freezer Refrigerator
Not working on ac on propane freezer gets down to
Possible bad thermistor in the unit. Open the front fridge door and view the cooling fins across the back. On the right hand side is a clip with a wire going to it. Slide that up the cooling fins towards the top and see if that fixes the problem. If it does not, then access the rear panel and check the ohm resistance in the thermistor. Remove the cover of control board and unplug the two wire plug (white). Ohm resistance should be present on the thermistor.
Jul 02, 2009 | Dometic RM2652 Refrigerator
No cooling in refrigerator
air passage from freezer to the lower door maybe blocked with ice build-up
May 06, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Not cooling refrigerator part
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
fgjkgd
Dec 03, 2008 | Roper RT21SKXLQ Top Freezer Refrigerator
Open Questions:
See all Explorer Appliances GRQ15 Top Freezer Refrigerator Questions
Explorer Appliances GRQ15 Top Freezer Refrigerator Logo
18 people viewed this question
Top Explorer Appliances Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you an Explorer Appliances Refrigerator Expert? Answer questions, earn points and help others
