Question about Alcatel OmniStack 6124 (OS-6124) Networking Switch
Reset admin password on alcatel 6124 switch - Alcatel OmniStack 6124 (OS-6124) Networking Switch
Recover password reset
You may have to update the firmware using a com port cable - check here for information about your product and to get firmware
https://service.esd.alcatel-lucent.com/portal/page/portal/EService/product_specific_support_media?p=OmniStack_6x24_6148
Apr 13, 2014 | Alcatel OmniStack 6148 (OS-6148)...
How to reset admin password
Reset Windows 7 admin password is not hard in fact, as long as you follow these methods to do.
Method 1: To Reset Admin Password with Administrator Account
On Win 7 logon screen, click user and "Switch user" to choose another administrator to sign into. Turn to Control Panel and navigate to User menu. Choose the account you want to reset its password, and remove its password. And then set a new password for it.
Method 2: Reset Admin Password with Password Reset Disk
You have two ways to get password reset disk. One is create it when you still have the administrator password. The other is to create it with third-party software, such as Windows 7 password genius.
Similarly, on Win 7 logon screen, after type wrong password, click link "Reset Password" to go on. Or insert password reset disk into Windows 7 computer and boot it from disk. Windows 7 Password Genius runs, at the same time, all accounts and password list for you. Choose the administrator account, and click "Reset Password" to finish Windows 7 admin password reset.
May 29, 2013 | Samsung SRD-440-500
I need to disable ports on my network so that they aren't open for non network workstations to plug into how do I do this on an alcatel 7700 switch
interfaces (slot/port) admin down
eg
interfaces 3/24 admin down
The above example will disable port 24 on slot 3. Admin up to enable it again.
Aug 08, 2011 | Alcatel OmniSwitch 7700
Where can I find my DI-524 Username and Password?
If you have not changed it, the default username and password can be:
Username: can be left blank or use "admin"
(without the quotes)
Password: can be left blank or you can use either "password", "1234", "admin"
Jan 03, 2011 | D-Link AirPlus DI-524 Wireless Router
Default password is incorrect or reset doesn't work
The default ip is 192.168.1.1
default user-name and password for the 5 models of 3com are as follows.:
1.
3com default ip: 192.168.1.1
username: n/a
password: admin
or
2.
user-name: adminttd
password: adminttd
or
3com default ip 192.168.1.1
user-name: admin
password: n/a
or
user-name: n/a
password: PASSWORD
OR
5
user-name: root
password: !root
ok try
this
Note that at time you will need to set your local ip of your pc from which you are acess the device to the same range...
That is for example 192.168.1.10
Good luck
uttam
Feb 26, 2010 | 3Com 2816-SFP Plus (3c16485-us) 16x1000...
I want default password
try this user name is admin password is admin
Apr 17, 2009 | Alcatel SpeedTouch Pro (3EC18804HC)...
Wants to reset 3824 3com switch via console
You forget the password for the "admin" user account and can no longer perform important management operations. solution.gif Use the password recovery method outlined below to define a new password for the "admin" user account:
  1. Access the Command Line Interface from the console port and enter the user name "recover" and password "recover" to place the Switch in password recovery mode. The Switch remains in password recovery mode for a maximum of 30 seconds, before it returns to the CLI login prompt.
    note.gif You must use the console port to recover the passsword. If you attempt the recovery method using the network, the password will be rejected.
  2. Perform a hard reset on the Switch whilst it is in password recovery mode by switching it off, waiting a few seconds, and switching it on again.
    note.gif You cannot use a soft reset operation to reset the password of the "admin" user account. This will end the password recovery procedure and return you to the CLI login prompt.
  3. When the Switch has rebooted following the hard reset enter a new password for the "admin" user account.
Mar 05, 2009 | 3Com SuperStack 3 3824 (3cr17402-91-uk)...
Password for belkin router
If you have the router, the default username and password is usually printed on the bottom if not try these.
Username | Password
Admin (none)
Administrator (none)
Admin password
Administrator password
Admin admin
Administrator admin
try these in any order and switch round passwords to usernames these are the default passwords, if these dont work, then a simple push button reset will sort you out.
Ben.
Feb 07, 2008 | Belkin (F5D7230-4) Router (587009)
Alcatel OmniStack 6124 (OS-6124) Networking Switch Logo
70 people viewed this question
Top Alcatel Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
