Question about Vehicle Parts & Accessories
Datsun 200b I need a new coil for a datsun 200b motor, not sure if the coil needs a resistor built in or not
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 137 Answers
CHECK WITH PARTS STORE. SOME STORES CAN TEST COILS AND RESISTOR.
Posted on Nov 25, 2013
After installing motor an transmission I 1983 datsun 280Zx car won't start could this bhai e the timing needs settinh
Sure, if timing is way off it may not start. Do static timing adjust, check for spark and basic timing using a timing light while cranking. This will tell if you are in the ballpark, and also if you have spark at all. If no spark, test coil, etc.
Oct 08, 2015 | Datsun Cars & Trucks
What else could I check.
not sure but check to see if there is a white porcelain resistor mounted on firewall if its gone datsuns wont start with spark or fuel ok
Sep 06, 2014 | Charging & Starting Systems for Datsun...
No fire to sparkplugs
Bit late here, but I love Datsuns! First check if you are getting power to coil on the + side of coil. Pretty much a straight path from ignition switch to coil. Then pull off coil to distributor cable at the distributor and check for spark on that wire when cranking engine over. If good, rotor, distributor cap, plug wires, or sparkplugs need checked. If no spark from coil, it should be tested with an ohmmeter for proper resistance values, or swap in another coil.
Does it have mechanical points and condenser or electronic ignition?
Nov 22, 2012 | Datsun 510 Cars & Trucks
Datsun 180b wont keep running
Replace the ballast resistor on the coil.
Mar 19, 2012 | Datsun 1600 Cars & Trucks
I have numerous Chauvet 200b LED lighting fixtures. The problem I am having is: the "blue" LED"s on most every fixture are starting to go out. All the other colors are fine (it's just the...
Before jumping to conclusions, one should do some testing. It is posssible that you are having a DMX data error. If your lines are long, please review the need for a termination resistor at the far end of a DMX chain. The reflections of the data pulses can confuse or cause errors. Test a unit up close to your controller so the cable is short. If that magically works, install a terminating resistor.
Beyond this, electronic testing needs to be done. I did find in a Chauvet LX5 a bad solder joint at a connector that brings the power for, in my case, the green LED's. There will be surface mounted resistors on the back of the board that limit the current to groups of LED's.
If the whole fixture loses the blue at once, either suspect a DMX error or the driver in the fixture.
Mar 02, 2011 | Chauvet (2) Chauvet Ledsplash 200b Dmx...
Need a relay for a MotorGuide Stealth 200 troll motor - part VF4-899F11
I have a Motorguide Stealth 200B trolling motor, works perfect but getting a new boat with a new motor. Trolling motor has original manual and paperwork with it, as well as 4 blade Ninja prop and prop wrench. Has some cosmetic scratches on motor. looking for $25.00
Feb 12, 2011 | MotorGuide Standard Motor Replacement...
What are the timing marks for a 200b datsun where do they sit and where dose the cam sit
hi, normally the inlet vale of the camshaft (s) sticks up and to the right, this is the first valve No. 1. normally at the back of the camshaft there is a off set groove to aline it gerry
Sep 09, 2010 | Datsun 210 Cars & Trucks
Need to replace ac/heater fan resistor I am not sure of the location does anyone know? Thank You
The Blower Motor Resistor is located on the passenger side firewall, not far from your A/C's H-Valve (or expansion valve), going inside of the vehicle. The blower motor resistor has a 4 or 5 way black connector plugged into it and this is the only visible portion of the Resistor you will see. Remove the wiring connector and remove the 2 or 3 screws with an 8 mm or 5/16" socket (8 mm and 5/16" are the same). Once the screws or fasteners are removed, just pull the blower motor resistor out of the firewall and if you look at it, it will have various coils of wire on it, sometimes it will show burnt coils, but you can always check the various coils with an Ohm-meter.
Aside from that, install the new Blower Motor Resistor and Voilà! Your inside Blower Motor should work just fine.
A brief note here, if your fan doesn't work when the fan switch is on High, then it's not the Blower Motor Resistor, but possibly the Blower Motor itself. Should this occur, please get back to me insofar as how to replace the blower motor and why the blower motor's wires have to be twisted...even with the new blower motor fan.
Best of Luck,
"00 Buck"
"Still living on the Right Side of Dirt..."
Jun 05, 2010 | 2001 Dodge Caravan
How to connect power to champion uh-200b single phas
I don't see the date when you posted this problem but it is still on unsolved suport section. So I try to let you know that all Champion dishwashers need the first inital start up . That is make sure water is in the booster , Locate the Installation and service toggle switch on the extreme left side of the control box.Prime the booster .
Let me know if you still want more information about this unit. God Bless,
May 08, 2009 | Champion 24 in. UH-200B Built-in...
Vehicle Parts & Accessories Logo
62 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
