Question about Canon iRC2380i
Error E000748-4000 it doesn't work. i can't start the printer. i only see this error code E000748-4000
Whenever I switch on to start operating, during my waiting to warm up, it displays error code C-D369. and it doesn't function from there.
Error code reset:turn OFF the copier ,press and hold the Utility key to right hand,to left hand turn ON the copier,wait appaire on the display Trouble reset,touch the screen and turn OFF the copier.Wait 2 minute and turn ON.
Jan 17, 2013 | Konica Minolta bizhub C250 All-In-One...
Stuck in start up repair 1525
Try the next oldest restore point until the issue is resolved. Any software installed after the selected restore point needs to be reinstalled.
If system restore still doesn't work, run the "Pre-Boot System Assessment (PSA) Diagnostics and Error Codes For Dell Computers", you may click the link below to go directly to the support site, it contains instructions in running PSA Diagnostics and Error Code List with possible fixes.
http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=dhs&docid=266787#Issue2
Hope this helps.
Nov 19, 2011 | Dell Inspiron 1525 Laptop
I have a cannon pixma mp 500 printer and I and getting a error code 5010 how can I fix this issue? Thank You
unfortuantely according to canon website, if turning it off/on doesn't clear the error then it will require a "repair service". Doesn't acutally say what the problem is I'm afraid.
good luck
Don
Sep 01, 2011 | Canon Pixma MP500 All-In-One InkJet...
Error code P03. It won't print, it doesn't make any noise when I turn it on, and I don't see any traces of paper.
Error code PO3 is caused by Timing Disk dirty / damaged.
Please use this methods
1. Check the timing disk sensor located to the left of the printer
2. Check and clean the board.
And start to print... thanks
Aug 11, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Im trying to scan a document but its saying error code 2106. i have it hooked up through wireless
Try these things:
1. place a doc to scan in the scanner. Close the lid and hit MENU, COPY document, START.
If that doesn't work you'll need to contact kodak. If it does then try this next:
2. Check for ADMINISTRATOR rights.
  1. RIGHT CLICK on the kodak icon and select Properties > Compatibility tab > Run this program as an administrator
  2. Select RUN AS ADMINISTRATOR
  3. click APPLY
  4. click OK
Then try scanning again. If it still doesn't work then-
Reload the driver:
  1. select Start > Run.
  2. Type %windir%, then click OK.
  3. Double-click twain_32.
  4. Right-click Kodak, then select Delete.
  5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to (cd drive: > printer > scanner.
    Double-click aioscannr.msi, then follow the instructions to remove it
  6. Then go to cd drive: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
  7. Open Home Center Software
  8. Select Scan Documents and Pictures.
  9. Scan a document
If it still doesn't work then you'll need to take it in for service.
Jun 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a color laserjet printer 5225 printer the problem is showing the code 55.0601 on display after the printer running
Error code says that printer has a DC Controller NVRAM problem.
If power cycling the printer doesn,t work, the DC Controller is
going to need replacing.
If you have a warranty...use it.
If not a tech is going to have to look at the printer.
Jun 10, 2011 | Office Equipment & Supplies
Printer not activated-error code 30
Sometimes, you may get printer not activated - error code 30 when you try to print using your printer. It may occur when you try to print a PDF document. Sometimes, your Antivirus scripts block you from generating the document and you may have to face this issue. If you have installed Antivirus software and you have encountered "Printer not activated" error, you need to disable script blocking. If this does not resolve the issue or you do not have installed Antivirus, you need to change the Calyx Document Converter printer settings. If it also doesn't work, you need to reinstall the printer driver in your system.
Jul 12, 2009 | Cannon Office Equipment & Supplies
6010 error canon pixma mp600
You did not state which version of windowns that you are using . Try this . Go to the control panel printers and delete the printer. Go to the canon website and get the software drivers for your version of windows.  Instal the printer using the windows install routine telling it where the driver is located when it asks. If this doesn not work , pleas ewrite back. I am not positive as I dis seardches on you error code and am fairly certain that the code means wrong driver for OS.
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
Dec 14, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Epson 4800 set ink crtg error
Check the following information for reset the printer cartridge.......
http://www.fixya.com/support/t2689003-set_ink_cartridge_invalid_ink_cartridge
hope this helps you.
Oct 30, 2008 | Office Equipment & Supplies
?Scanner failure? error message
Usually this type of error message pops up when the scanner lamp isn?t warming up properly. This is what you should do: 1. Check if the lamp is on. 2. Unplug the scanner?s power supply and plug it back in. Try connecting it diretly to the wall. 3. If that doesn?t work: a. Unplug the unit?s power supply. b. Press ?cancel? and left arrow while reconnecting the unit. c. Release the buttons when the printer starts up. 4. Try scanning again. 5. If it doesn?t work, have it serviced.
Feb 22, 2006 | HP PSC 750 All-In-One InkJet Printer
Canon iRC2380i Logo
old marine
old marine
