Question about Black Diamond Camping, Backpacking & Hiking
Black diamond sprinter headlamp won't turn on
Seems the on/off button is broken
Battery Packs available? Where.
where di you buy the lantern? that is where I would look first .
Oct 06, 2015 | Black Diamond Apollo Lantern
HOW DO I CHANGE THE BATTERY
Any idea what model of headlamp you have?
http://blackdiamondequipment.com/en/faqs.html
Call: (800) 775-5552
Monday - Friday 8am-5pm, Mountain Time
Email: orders@bdel.com
Fax: (801) 278-5533
If you're in Europe and have a question, you can reach us at Black Diamond Europe by sending an email to climb@blackdiamond.eu. You can also reach our European office via phone or letter:
Black Diamond Equipment AG
Christoph Merian Ring 7
4153 Reinach, Switzerland
p: +41/61 564 33 33
f: +41/61 564 33 34
Oct 22, 2014 | Black Diamond Sport & Outdoor - Others
1994 cutlass ciera turn signals won't work with headlights on
From your description, T/S not working with headlamps on, it seems apparent that your turn signals have lost their ground and are grounding back through the headlamps when they are not on.
May 19, 2011 | 1994 Oldsmobile Cutlass Ciera
Can't open up to replace battery on headlamp
aspen643-
Look for a slot on the top. There will be a gray tab in it that must be pushed in while gently prying apart the two halves of the headlamp.
Hope this helps.
Regards,
DIYpro
May 05, 2011 | Black Diamond Equipment 620593 CHILI...
Where can I purchase replacement Black Diamond Bright Bulbs?
GearX.com sells them for $6.50. Hope this helps ! Matthew
Jan 20, 2011 | Black Diamond Bright Bulb
How do i take the headlamp holder out merc sprinter 1998
first, open the hood of your van. and look for the bolts that hold it in. some may be hidden toward the bottom by the bumper. once unbolted completly, it should come out easily. i hope this helped
Dec 17, 2010 | 2010 Mercedes-Benz Sprinter
My myo xp headtorch has suddenly stopped working. As the bulb can't be replaced, how do I fix it?
Very strange. Mine just suddenly stopped working last night as well. I have changed the batteries, but it makes no difference.
Dec 01, 2009 | Petzl Myo XP LED Headlamp
Low beam of one headlamp not working. Do I need new bulb or other possible cause? 50cc chinese scooter. thx!
With all bulbs on this lamp being LED the fault has to be the individual bulb. Unfortunately these are not repairable or replacable. Is the lamp still within warranty? If so I'd get it back to BD.
Hope this helps..
Aug 14, 2009 | Black Diamond Icon Headlamp
Merecedes sprinter 313 cdi. horn not working.
The wiring loom that runs down the front near the radiator and intercooler is prone to rubbing and corroding and shorting out. Check this loom.
If it is in bad shape i'd recommend replacement as the turbo boost sensor wiring and some of the headlamp wiring is in this loom also, and these can cause costly problems and cause the turbo to fail if not replaced.
Jan 20, 2009 | 2006 Dodge Sprinter
Camping, Backpacking & Hiking Logo
194 people viewed this question
Top Black Diamond Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Black Diamond Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
