-   Just got a replacement remote from RCA's contracted replacement part company or WHATEVER. No instructions came with it. all it says is "REM506" I have no idea how to get it to work with this stereo.
-   Wochka
The Audio System does not respond to the remote control.
1. To reset their connection, turn on the remote control and switch the Audio System to Standby mode.
2. In Standby mode, press and hold both INFO and SOURCE on the front panel of the Audio System. It is reset to default when"RF ID clear" displays.
3. Press and hold both PROGRAM and SELECT on the remote control. When “ID claer” displays on the LCD of the remote control, the connection is reset.
4. By now the remote control and the Audio System should be connected to each other. Press and hold PROGRAM and SELECT on the remote control again. When
“ID Locked” displays on the LCD of the remote control, the connection between the remote control and the Audio System is locked.
sounds like you need to program it to the radio i am having the same problem but i had to get a new remote thats why mine is saying that if you have a book to it can you let me know how to program the remote
I too had no sound from speakers. headphones worked, so unit does operate. I removed side panel and...
(More)
I too had no sound from speakers. headphones worked, so unit does operate. I removed side panel and saw a blown fuse. I went to radioshack and bought a 4-pack of 5A125V fuses, and installed. It blew as soon as I plugged in unit. Swapped in another new fuse-same thing. less than 30 hours of use. Something is causing fuses to blow instantly. any help?
I am quite certain that I have connected the speakers correctly and the volume is turned up, but...
(More)
I am quite certain that I have connected the speakers correctly and the volume is turned up, but there is no sound for radio or CD. CD does spin in player. Did I miss a step along the way? RCA is close for holiday.
System is a RCA RS2100. Put in a CD, but now CD will not play and the eject button will not eject...
(More)
System is a RCA RS2100. Put in a CD, but now CD will not play and the eject button will not eject the disc. Is there a way I can manually remove the disc?
The unit says the CD player is reading the CD but does not play it. I have tried everything I can...
(More)
The unit says the CD player is reading the CD but does not play it. I have tried everything I can think of without success. I can hear the cd player running. Am I missing something? I just bought this system and really like it otherwise. I have tried using the remote as well as the base unit,
