How to tune to Prime with Starview????
I would like to tune Prime station on Starview as it has moved it's satellite location???
Why no am reception on grundig 800 millinium satelite radio
It depends on your location. Set reception mode to AM waves. Dial in the frequency of the station or enter it using the keypad. To tune in on a station, rotate the radio.
Jul 19, 2014 | Grundig Satellit 800 AM/FM/SW Radio
I have a sharp aquos LC32AF3x which was working fine . We have moved and now it will not tune into stations. I have used the same connections on another tv and that tv locates the stations when tuned but...
Your TV has to be able to sense local station signals as part of the tuning process. there may be a problem with the antenna or cable connection.
Jan 05, 2018 | Sharp Televison & Video
How do I change the radio station on my pioneer vsx-d903s
Welcome to FixYa.
You need to use the remote control to access the radio station frequencies.
Follow the instructions below:
Thank you for using Fixya. Have a great day!
Jas247
Jul 23, 2011 | Audio Players & Recorders
Emerson rp 6247 radio AM stations does not come in clear
Try moving the telescopic antenna around in different directions until you get a clear reception. If that doesn't work, try moving the whole unit (radio) to another location. Make sure you are using the tuning knob to switch between stations. Moving it to a different location may be the best thing because the radio antenna may be received in frequency waves from another electronic device (i.e. a television set, another radio or in microwave) which is causing a reception to be poor.
Mar 21, 2011 | Emerson RP6247S FM/Weather/AM/TV Radio
My Grundig Satellit 700 Radio is not working on FM Band but is working well on AM and Shortwave Band. After pressing ON/OFF button and FM/RDS-AF button when we try to operate the FM Band of this radio...
As a side note, most AM/FM radios use a separate antenna for each band, thus why you can pick up AM but not FM. Check your mast antenna connections to make sure they are solid and not missing or loose.
Dec 10, 2010 | Grundig Audio Players & Recorders
What radio station do I tune the radio to for the satellite radio to come in
Look on page 12 of the Roady 2 user guide. There are 12 stations listed. Pick one that is not in use in your area
Mar 14, 2010 | Delphi Roady2 SA10085 XM Radio Receiver...
Setting preset stations
Hi Gil, not sure what you mean by RE-setting presets but I assume your using a dock of some kind, and in that case you simply tune to the station you desire then hold down the preset number you'd like to set it to. It will overwrite the previous setting. hope that helps.
Feb 22, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Setting my preferred stations
you need to select your station then press the preset button then 1 thru 0 to store the station. repeat for the rest of yoiure stations you want to store.
Jan 08, 2008 | Audiovox XCS9 XM Radio Receiver
Getting blank radio stations
when you get to the station you want push both seek buttons at the same time the left and the right
Nov 14, 2007 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Tune fm stations manual
You use the satellite tuner to change stations, not the head unit.
Jul 18, 2006 | Verge VMP508 CD Player
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
