Question about Acer Aspire 6920 Notebook PC
Acer Aspire 6920 Restarts in Normal mode and works only in safe mode
My Acer Aspire 6920 Restarts in Normal mode and works only in safe mode. I reinstalled the Windows & professional and the problem remains same, i removed all the startup files from msconfig still same problem :(
  • VaNu Dhungana
    VaNu Dhungana Nov 26, 2013
    @saranden i already formatted and installed a fresh windows 7 but also the problem remains same and another interesting fact is that the while installing it during the installation time also computer restarted several times and the main problem is that it works fine in safe mode
    New Friend:
  • 52 Answers
Sounds like the MBR ( boot files) are corrupted. Try formatting the hdd before you instal again. I'm sure you have a restore sector on the hdd in which case, if you have done anything to that then you'll need to have the restore disc set which usually comprises of the restore disc and the drivers disc. Either way....just make sure you format c and not d which is usually the resore partition. Good luck
Posted on Nov 24, 2013
4 Suggested Answers
  • 133 Answers
SOURCE: acer aspire one is not starting up. It goes back to OS start up
there are two possibilities i can think of, one, a virus, two, a bad driver file. what you can do, is run it in safe mode, if it goes to the log in screen, you could log in, and when a dialogue box appears to run in safe mode, click yes. then, go to the start menu, then locate my computer, right click on my computer, and click on manage. A window will pop up that says computer management on the top. In the middle, click on system tools, then device manager, and it will show a list of all of the devices that are installed. Lots of times, your display driver is updated and causes your computer to be unstable, there fore, giving you the bluescreen error, which causes your computer to constantly restart. (make sure all recently installed devices are unplugged before doing this. new devices may also cause this error). look for any devices with an exclamation point, right click, and uninstall them, then restart the computer to see if it solves your problem. if not, then it might be a virus that activates with internet acces, if so, run your computer in safe mode, and run a virus scan and hope that it finds the virus. If that doesn't work, then what i recommend is try to back up your work in a flash drive or disk and running the backup disc that comes with your computer. to run that, sometimes your computer comes with a disc, run that disc and follow the instructions. if not, then sometimes it comes preinstalled, and have to press f10 on the first boot screen. if none of those options are available, then call the manufacturer and ask for the restore disc for your computer model. Good luck
Posted on Jun 27, 2009
  • 93 Answers
SOURCE: acer aspire one AOA150 starts normally. Comes to
Hi frnd..
Go to safe mode and create a new user account... also delete ur prevoius accont.. make sure u click on the option DELETE ACCOUNT ONLY.. the files of the deleted account will be stored in the folder with the deleted account name on the desktop of the new account.. also update the BIOS from the vendor site... Take care..
Posted on Sep 21, 2009
bronk50
  • 27725 Answers
SOURCE: acer
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. if this hails to fix the problem http://support.microsoft.com/kb/307545/ restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice Select safe mode with networking to download you could select the option start with command prompt you should be in DOS mode black screen type chkdsk/r/f which will scan for and attempt recovery any bad sectors and automatically fix any corrupt files on your hard drive you should have no input while chkdsk utility is in progress any input might further damage your hard drive
Posted on Apr 06, 2013
Acer 8920 G restarts after 3 min and again shuts down
First make sure your fan is operating on your processor it takes about 3 mins for it to over heat and stop and shut itself down for safety to prevent burning up the processor.if its not this read on.
Also when you boot into safe mode then do a system restore to a date before the problem started. But first in safe mode run your antivirus scan to find something that is missed while being hid behind the operating system while functioning. Remember to rate my solution and leave testimonial this is how i earn my achievements here on FixYa thanks in advance
Apr 28, 2012 | Acer Aspire 8920-6048 Notebook
My acer 6920 restarts automatically when AC power pluged in.. it runs fine in safe mode and on battery too it runs fine..... what to do ?? service center says d mother board is causing problem but no...
Start your system in Safe mode.
and try to restore your system for previous date.
If your are not compatible with how to restore, Go to the link and follow the steps.
http://support.microsoft.com/kb/306084
Otherwise you can try to reinstall the OS.
Thanks for using FixYa.
May 17, 2011 | Acer Aspire 6920 Notebook PC
Acer aspire one
Unplugg any external device and restart the computer. If still not, Click on F2 as soon as the computer restarts.. It will open BIOS, press F9 & then F10. Restart the computer.
Mar 17, 2010 | Acer Aspire One PC Notebook
Acer 110 boot problems
This could majorly happen because of sp3 conflict with one of your hardware drivers
log in into safe mode and rollback the last software or hardware driver update
Jan 01, 2010 | Acer Aspire One Netbook 8.9" Notebook
Windows will not start
Have a tech look it over, it could be a more serious issue that requires reloading Windows from scratch.
Sep 10, 2009 | Acer Aspire 6920 Notebook PC
I have an acer aspire desktop. blue-screen and no start up disk.
1.remove all your disks from disk drives
2. cd, floppy remove it from the drives
3. still it gives you the same display
4. format your system and reinstall Windows
Jun 30, 2009 | Acer Aspire 6920 Notebook PC
Acer Aspire 3684 nwxi
Have you tried booting into safe mode? If not, hit F8 at startup (before the Windows logo) and see if safe mode works. If you can get into safe mode and not normal mode, you have either a) driver problem or b) Windows corruption
If that is the case, you can remove your drivers from your device manager (video and audio drivers are the biggest culprits) and try booting normally again. If the drivers are the problem, windows will boot and try to load drivers for the devices that you removed.
If you end up removing all devices and Windows still won't boot, you either have spyware or viruses on your system ... or Windows is so corrupted that you will need to reinstall.
Be aware that if you have bugs in your system, a simple "Windows repair" might not work. You can try it, but just be aware. Worst case scenario, boot into safe mode again, back up your files to a flash drive, external drive or another partition, then reinstall Windows "clean", which will wipe the C drive and reload a clean install with no bugs and no problems :)
Good luck - hope it helps!
Sep 29, 2008 | Acer Aspire 3680 Laptop
Cant get out of hibernation
does the laptop boot at all ? or just not logging to windows ?
if not logging to windows then unplug the laptop's battery the replug it and restart
if the problem remains,, try to boot in safe mode by pressing F8 continuously and then choose Safe Mode
if you success in booting in safe mode go to control panel and disable hibernate then try to reboot in normal mode
Dec 25, 2007 | Acer Aspire 5610-4648 Notebook
Acer Aspire 6920 Notebook PC Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
