Question about Dishwashers
Kenwood kdw60x10 dishwasher not cleaning properly
2 Suggested Answers
SOURCE: Hi Kenwood dishwasher kdw60x10 -
I have the same problem :( e1 fault and full of water, I have check pressure and drain for blockages too.
Posted on Jun 03, 2011
My KDW60X10 dishwasher is emptying the salt container in 3 washes and everything comes out coated in white salty scale What is the problem?
Either the lid seal is damaged or lid isn't in properly, or the softener valve is letting by and would require a new softner
Jan 08, 2018 | Dishwashers
My dishwasher is not enough with water at the start of the cleaning cycle
My new DW had the same problem but when I had a tech come to the house he explained that the DW only uses .8 gallons of water and that what I am seeing is normal. Do your dishes come out clean? My did, so I guess he was right. Good Luck...xo
Sep 20, 2014 | Kenwood KDW243A Builtin Dishwasher
My dishwasher smells inside
Have you tried running the hot cycle with just a dishwasher cleaning product inside?
Aug 05, 2012 | Kenwood KDW243A Builtin Dishwasher
E4 showing on the panel KDW60X10
The Kenwood KDW60X10 shows the E4 code when there is a water leak or a problem with the float switch (or it's PCB board connection). This could be a leak at the tank, the hose, or that the drain pump's anti-flooding system has been tripped.
Disconnect the dishwasher from power and the water line. Look for signs of a water leak under the unit. If the hose is leaking, you may be able to replace or reseat the drain hose. (Also make sure that there are no kinks in the hose.) Note: sometimes the leak is in the plastic where the drain hose connects to the dishwasher. That is harder to fix.
If the tank is leaking, replace the entire unit. For the other possible problems, you should consult a repair tech to narrow down the issue. Float switches are easy enough to replace; the PCB board and the anti-flooding system are not as easy to reset.
The manual for your dishwasher is available here: http://www.partmaster.co.uk/company/partmaster/manuals/Kenwood%20KDW60X10.pdf .
I hope this helps.
Apr 12, 2012 | Kenwood Dishwashers
I am looking for a user manual for the KDW60X10 dishwasher.
Please click on the link below to download the user manual for the Kenwood KDW60X10
You will need to have Adobe Reader or another PDF file viewer installed on your PC to open the file.
http://get.adobe.com/reader/
Regards,
BElectric
May 25, 2011 | Dishwashers
Hi Kenwood dishwasher kdw60x10 - runs cycle then stops showing error E1 - still full of water.
May 14, 2011 | Dishwashers
My kenwood KDW12SL3A dishwasher dysplays E3 error every time I use it. dishes don't get cleaned properly. Can I fix it myself? if not how much will it cost me to get it fixed by a professional? thank you
Hi
E3 error code neans the water is not being heated to the required temperature in the machine.
This may be either a defective heating element or faulty thermostat.
It is unlikely you can fix this yourself.
Depending on what is wrong it might cost you around $150
Dec 20, 2010 | Kenwood Dishwashers
My Kenwood KDW243A built in dishwasher is desplaying what I assume is an error code, E3. What does this mean? The washer is not washing properly.
E3 means the base is full of water. A quick fix is to tilt the machine back for 10 mins or so but you need to find the cause of the leak and repair it
Jun 03, 2010 | Kenwood KDW243A Builtin Dishwasher
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
