Question about NEC NP100 Projector
I need to change the settings and don't have the remote
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
May 23, 2016 | RCA TruFlat 27F520T 27" TV
Remote won,t work all functions for yamaha 70cu sound bar
Set-up the remote control with an other set-up code said for your device.
Sep 24, 2015 | Yamaha Televison & Video
I changed battery in the remote with a cr2032. The remote lights up but the doors still don't unlock. any suggestions ?
read qowners manual for exact number of times... but put key in ignition turn on and off between 7 and ten times..... locks will actuate! hit lock button on remote... remote is then set
Jan 29, 2013 | 2005 Chevrolet Equinox LS
Is it possible to change the on screen language of a Japanese Panasonic Viera? I don't read Japanese and am having trouble using the TV.
i will need the model number of the panasonic in order to assist with changing the language . Please respond to this same post for assistance.
Jan 02, 2013 | Televison & Video
Can't change input - don't have remote
Unless there is a source or input button on the set you need the original remote.
Dec 18, 2012 | Toshiba 30HF84 30" TV
My television set is stuck on one channel....the audio changes with the channel but the picture stays blurred on one channel...whats wrong with it?
Lots of possibilities. If you are using the remote, try also using buttons on the TV to change channels. If TV buttons work, the remote is broken or perhaps try changing batteries and cleaning battery contacts on the remote. If neither work, lots of other things to try. You may need to set preselect channels, so your TV thinks there is only one channel out there until you do. If you are on a cable box you just need channel 3 and change channels on the cable box. I can't tell what you mean by "audio changes with the channel" ... if you mean that when you try to advance channels, it increases volume and moving down in channels lowers volume that would be strange -- if you are using a programable remote it might not be set correctly (try another programming code). The "blurred" picture is probably symptomatic of having the set on the wrong channel, and if you could set channel it might clear up ... I'd start with getting channels to change. If you need more help, give the brand and model of TV, say if you are using a remote (original or programable), and what the 'audio changes' comment means in more detail. Probably worst case is that your tuner circuit is fried, but don't assume that without more diagnostic.
Aug 29, 2011 | Televison & Video
My xbox 360 remot keeps moving down
You don't mention which remote you have?
Two issues that might assist. First try to go to: system > console settings > remote control and try changing the options there. Making sure you have the correct setups.
If you do then simply try and change your batteries to your remote. As like the remote controllers... weak or cheap batteries will sometimes cause faulty signal from your remote to your Xbox system.
Hope this helps?
Jul 20, 2011 | Video Game Consoles & Games
Don't know how to set up for any tv need instruction booklet
don't know how to set-up or program the code (1047) for a RCA tv. using URC-3021 remote control
Jul 10, 2011 | One For All URC-3021 Remote Control
My harmony 600 wont control my Bell 9241 PVR
Your 9241 needs to be set to remote codes set #1 in order to work. The Harmony uses code set #1. You can do this by following the manual in the guide which comes with the unit. I don't remember exactly how to do it but it is in the manual. Once you change the remote code set to #1, the Harmony should work. I did this with a Harmony 300 and it worked flawlessly. QuintusPRE.
Feb 12, 2011 | Logitech Harmony 600 Remote Control
How to program tv without remote
Some TVs have a set of buttons behind a door or panel on the front that will give you access to menu, arrow keys, etc.  You should be able to use those to make the changes you need.
May 20, 2009 | Televison & Video
NEC NP100 Projector Logo
22 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
