Question about TRT MX174S 17" Flat Panel LCD Monitor
Computer does not turn on monitor
Start up the conmputer and the monitor does not respond. Have tried this with another monitor and still no responce. Not a problem with the monitor but with the computer. Is it a video card problem?
  • 93 Answers
Yes and no...if you can hear long beeps that means your vc is def
Posted on Oct 10, 2007
Turned key in ignition got no responce tried connect to ecu unable to respond
With a voltmeter check out the main battery fuse cartridge located in the fuse box usually 3 or 4 of them bolted to fuse box you cant mistake them they are the largest physically in the fuse box , If this reads ok check your Battery Earth strap and Engine earth strap .sometimes the dash lights if these straps are poor but they can not carry enough power to complete circuit.
Jul 03, 2015 | Cars & Trucks
My computer crashed and when I try to diagnostic the problem with the TechAID diagnostic Card of Soyo, it tells me that FF is not functioning. After that I bougt a new processor for socket 775 and I turned...
sounds like a faulty motherboard. try testing the motherboard after removing everything apart from the cpu and ram then add one piece at a time to eliminate one thing at a time.
Feb 14, 2014 | Asrock Computers & Internet
Monitor Not responding
you have a video board problem in your monitor, but before you send to fix try with a diferent computer or even a laptop using the same cables.
Jun 15, 2010 | Acer AL1916W 19" LCD Monitor
On dual-monitor setup after period of inactivity flatron stays dark and fails to respond, while the old hitachi crt responds immediately
try resetting the setup i mean setting it up again also what happens when you turn the monitor off and back on
Apr 05, 2010 | LG Flatron 295LM 22" LCD Monitor
I just had my DVD drive replaced in my computer. I replugged everything in, and am not sure I'm plugging in my speakers in the right hole. I tried all 3 (blue, green & pink) and the 2 below, but no...
The green should be the audio jack. I'm sure you checked, but I've done the same only to find that my speakers weren't turned on and up even though they have power. Some monitors also have an audio jack--you may try that if you still aren't getting anything (btw, good call turning the computer off and on--allowing it to recognize the new hardware at start-up). It's completely possible that wires or connections became undone during the optical drive re-installation. Good luck.
Feb 24, 2010 | Audio Players & Recorders
Modrl 710N Monitor. I have just turned on this replacement monitor for the first time in about 3-months. The screen is blank with a flashing green light on the control panel. Pressing the test button tells...
When a monitor goes black and the solid green starts flashing it normally means the computer is sleep mode the screen saver blanked out the display the comp is off ect... However in this case since i assume you allready tried wiggling the mouse tapping the spacebar pressing the resume button ect... It is one of 2 things either the video card is going bad.( perhaps the computer has been on for a while and it is getting hot. With video card issues except the obvious, the case fan should be checked. there is a fan on the videocard it should checked as well the pc coul and mostlikely needs the dust blown out of it cause thats what kills fans and power supplies Hey power supply is the next possibility to th issue. No matter which part solves the problem I reccommend you do the other maybe premaintenance things I suggested. Good Luck.
Dec 03, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Thw on/off button isnt responding, but the light above it is flickering, the screen doesnt show anything.
I apologize then, the monitor is definitely bad. If the menus can't be accessed and you can't get a self-test to come up then the monitor is done. From my experience, sounds like it might be bad capacitors on the power board that go puffy, but taking it into an electronics shop and having it fixed might cost more then the monitor is worth.
Wish I could of helped you more.
May 16, 2009 | LG L1530S 15" LCD Monitor
Ev 700
you must attatch agp(accelareted graphics port) card in pci slot it is specially for 3d games and excellent video output fast motion responce but if you want to see normal ordinary display then no need of agp card
Oct 27, 2008 | Gateway EV 700 17" CRT Monitor
Monitor menu
I have the same problem with the emachines E14Te monitor. I have emailed emachines support several times and no responce. Iave tried calling, and vet the computerized maze of press the number for X department. I have yet to talk to anyone in their support problem area.
Jun 06, 2008 | E-Machines eMachines Monitor E15T4
Monitor flashes 7 or 8 separate colors
Your monitor's inverter board is a toast you will have to replace it.. Post back if you have experience in electronics and you wanna try it yourself..
Mar 26, 2008 | Liquid Video A170E101 Monitor
TRT MX174S 17" Flat Panel LCD Monitor Logo
131 people viewed this question
Top TRT Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a TRT Computer and Internet Expert? Answer questions, earn points and help others
