Question about Breville BBL550XL 5-Speed Blender
Breville ikon cuts out - Breville BBL550XL 5-Speed Blender
Breville instruction manual
breville website
Jul 27, 2014 | Blenders
Hello. I need two parts for my Breville Classic BlendMaster Model CBL-10. I need the removable centrally located inner lid and also the blade assembly features patented stainless steel twin cutting...
Breville CBL10 has been a fantastic appliance but now electrical section works at slow speed only so I will get rid of it, however the glass jug complete with lid, blade etc is still perfect. Does anyone need this part? I am in Rockhampton.
Jan 23, 2011 | Breville CBL10 BlendMaster Classic Work...
I need to replace frayed wire
You can get a new plug from any hardware store and replace the plug you have . 2 prong or 3 prong to match the original, cut the wire back just enough to get away from the frayed part ,.. when connecting the wire , curl the bare end of the wire around the screw in the direction of tightening the screw, clockwise .
thoughts?
Please Vote !!
May 14, 2010 | Breville BBL600XL. 5-Speed Blender
I need to acquire a glass jug for a breville BLR-3 Blender. Any suggestions would be appreciated !! Thanks
Hello. The best route to go is to work directly with the manufacturer. here is their contact info
  • AskUs@BrevilleUSA.com
  • 1.866.BREVILLE (1.866.273.8455)
  • 8a to 5p Pacific Time
  • Mar 22, 2010 | Breville CBL10 BlendMaster Classic Work...
    Grease build up around blade and where it attaches to base
    Grease can only creep into the blender vase if the oil seal has worn out, or the blenders blade shaft is worn and wobbling. Try cleaning all parts in alcohol to soften the seals. Rebuild kits and replacement blades can be found here (http://www.brevilleusa.com/breville-parts/blending.html)
    Mar 09, 2010 | Breville BBL600XL. 5-Speed Blender
    Breville Blender
    I need the blend jar for Breville Blender electronic Model BL3. I did not notice that a stainless steel spoon was in the blender. When I switched it on the crossed blade broke off.
    Oct 15, 2009 | Breville ikon Hemisphere Blender - Silver
    Breville blender bbl550 stopps after 5 seconds any setting
    Mine does this as well... 5 seconds of operation and then OFF.
    My guess is this is a fail safe where the blender is turning itself off to avoid overheating and what could potentially cause this overheating is the blender is struggling to turn the blades. What could cause this struggling of turning the blades I am guessing is a lack of oil in the blades rotating parts.
    If you hold the circular blade part and turn it, you'll probably find that its hard to turn? Mine is... and I oiled it up a bit and found I got a bit more usage out of it... although only temporarily.
    Ideally I need to pull it apart and oil it properly.
    Jan 29, 2009 | Breville BBL550XL 5-Speed Blender
    Any idea where we can get a new jug for a breville blender?
    This happened to me recently. Go to this site and order it directly from Breville. They were very fast and customer service very helpful.
    http://www.brevilleusa.com/home.do
    Jan 11, 2009 | Blenders
    Received the Breville Ikon 600 blender as a Christmas present in 2006 and have used it 3 times, with the third time being this past weekend. The product is now out of warranty and low and behold, it...
    My IKON 600 Blender fuse had blown. It was located on the circuit board and can be found by removing the bottom of the blender. Fuse is Fast Blow 10A, metric 5mmx20mm. The fuse blew because the bearing in the bse of the jar froze. Bearing # 608-RS. The beraring froze because the seal in the base of the jar was leaking. Solution: Clean seak surfaces, replace bearing and fuse. Total cost of $6 with my labor.
    Apr 16, 2008 | Breville CBL10 BlendMaster Classic Work...
    Breville BBL550XL 5-Speed Blender Logo
    37 people viewed this question
    Top Breville Blenders Experts
    Mike
    Joseph Hoffmann
    Are you a Breville Blender Expert? Answer questions, earn points and help others
