My fellowes powershred ds-1 is making loud clunking noises
It still accepts paper but the noise is making me worry
4 Suggested Answers
SOURCE: Where to oil a Fellowes Powershred 320 CC paper
I continued to search via Google until I found the manual for this shredder, which I then printed out and read how to lubricate the shredder.
Posted on Jan 26, 2010
  • 41 Answers
SOURCE: fellowes powershred 480 has a screeching noise.
no wd40 will harm the bearing
Posted on May 10, 2010
  • 99 Answers
SOURCE: Fellowes Powershredder, making clunking noise and ceases to shred
2 probably causes
to check this 1st unplug the machine
now take the top off ,there are 2 screws underneath the front edge of the cover assessable when the door is open, and 2 on the back you will want to back the shreddr up to a table when you take off the top (the sensors and switches are all still connected so this takes the stress off of the wires)
now you will need to remove the blade guards there are screws at the left and right ends of the guards,
once these are removed you should have a pretty good view of the blades, look for any visible obstruction (part of a binder clip or paper clip or metal closure from an envelope for example)
if this wasn't the cause try this
on the side of the blades there is a fan wheel that is connected to the motor. When you turn the fan with your hand you can manually turn the blades, typically you will be able to turn it to a given point and then it will be increasingly hard to turn, you might also notice that the bar on the outer edge of the blades begins to bend at this point. These bars seem to break under fairly low stress and having one break will also produce the symptoms you described. replacing one of those is a costly repair, (cost is largely because it is very time consuming,)
Posted on Oct 30, 2011
Fellowes c-480c squealing noise
Shredders get incredibly dirty with paper dust. There is also a lubricant that you are supposed to put on the blades. There is a basic guide here:
Mar 13, 2015 | Fellowes Manufacturing Powershred C-480C...
What causes the Fellowes Powershred SB-15C shredder to show that it's full when it isn't?
Check and make sure there is no paper or paper dust covering the Bin Full sensor. underneath the head.
Aug 03, 2014 | Fellowes Office Equipment & Supplies
Clunking noise when turning the steering wheel at stationary.
When rocking the steering there is usually some noise from a steering system that has a few miles on it especially from the majority of power steering types as not only is the rack slipper bearing likely to make noise but also the hydraulic spool valve and possibly even the rack end bush.
Sometimes the clunking noises can be worrying they are so loud.
If there are steering stops on the lower arms and hubs the noise can be very loud on full lock and a moving vehicle.
There might be track rod problems but there is no point guessing - the car has to be inspected, jacked up and the wheels shook to check for wear and free play and on the ground the steering wheel has to rocked while the steering gear is inspected.
If inspection finds nothing the noise is clearly caused by "acceptable" wear...
Feb 13, 2018 | Ford Focus Cars & Trucks
Squealing noise when shredding
Have you tried putting any shredder oil on a piece of paper and running that through the shredder?
Feb 03, 2014 | Fellowes Manufacturing Powershred C-480C...
Fellowes Powershred 220 gives a perfect cut on half of the paper only? How can this be fixed to give a perfect shred across a whole sheet of A4 paper? Can anyone help?..PLEASE..
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 16, 2011 | Fellowes 220 Powershred Strip-Cut Shredder...
2 probably causes
Jul 08, 2010 | Fellowes 220 Powershred Strip-Cut Shredder...
I was shredding paper when it started making a loud grinding noise and wouldn't accept any more paper. I've tried running it back and forth, but it only goes, maybe half way, either way, and it still...
This is a very common problem. Go out to the hardware store and buy some silicone spray. With the shredder unplugged, spray a good amount of the silicone inside all of the teeth and try to get all sides.
Plug it back in and work it back and forth a few times. It should work better with less noise now.
Jul 24, 2009 | Fellowes DM15C Shredder
Fellowes powershred 320
seems to be an issue with the paper feed sensors i suggest you call Fellowes customer service. 1-800-945-4545
Mar 09, 2008 | Fellowes Powershred 420 Shredder
k24674
jasbo
jasbo
