Jbl cinema bd 100 bluray disc region code crack
How to crack Blu Ray code on JBL Cinema BD100 Blu Ray player to play all region Blurays
  • Vidya Deshpande
    Vidya Deshpande Feb 13, 2014
    do let me know if u have found a solution
My harman kardon player will read blurays, however it wont read dvds. Any idea why?
More than likely the lens that read dvd discs has failed. On blu-ray players, there are two (2) optical lens. One reads blu-rays and the other dvd/cds. They are independent of one another.
Nov 26, 2014 | JBL Harman Kardon Bds 2 2.1 Blu-ray Home...
Unlock region code for Samsung bd-f5500
The copyright protection seems to be embedded in the firmware and is tied into the whole system. I added a fan to my BD-E5900 and the extra draw of power on the board caused the copyright protection to not allow Blurays to play.
Feb 27, 2014 | Samsung Televison & Video
MAKING A SAMSUNG HT-F6500W REGION-FREE
1) Switch Player off then On (this is to clean-boot firmware).
2) Wait until main menu appears
3) Open Disc Tray and Close Disc Tray (May not be necessary)
4) As soon as "No Disc" is displayed quickly press REPEAT on
remote quickly use the following code for your current
region:
Region 1: Press - 2,9,3,3,4
Region 2: Press - 5,7,5,3,8
Region 3: Press - 5,6,7,3,2
Region 4: Press - 7,6,8,8,4
Region 5: Press - 5,3,8,1,4
Region 6: Press - 2,4,4,6,2
5) Your current Region will appear in the top-right corner
6) Quickly Press "9" before it disappears (It should replace
the code with a "9" in the corner)
7) Switch Player Off and then On again.
Note that REPEAT is part of the code so one smooth press of
6 keys is required.
There isn`t currently a region hack for Blue-Ray Disks
Dec 27, 2013 | Samsung HT-F6500W/ZA Home Theater System -...
Hi have just bought a panasonic blu ray player model dmp-bd77 here in australia we have put in a b/ray dvd from the usa that plays perfectly but when we have put in another american dvd(not blu ray a...
Every blu ray or dvd player sold in the world comes as standard unlocked to play any disc from any region. On the fifth play of a disc the DVD or Bluray will become locked to that region. So if you play 5 USA dvd's on the player after the fifth disc has been played only US dvd's will be recognised by the player, Same applies to BLUrays. So if i were you i would be careful about what discs you are putting in the player. Otherwise you will be left with a bluray player that cannot be used in Australia. After that happens the only way to play other region discs would be to get the player unlocked. Another point to add , a blueray player has two lasers one to play bluray and another to play DVD's. Lasers can fail so you could be able to play DVD's but not Bluray or vice versa depending on which laser has failed.
Aug 02, 2017 | Panasonic 2012 Dmp-bd77 All Region Code...
Have Aquos Multi region Blu Ray Player. Model # BD-HP24U. When I play newer Blu rays (Social Network, Kick ***) message appears Mismatch between disc and player region codes. See disc...
These units are generally hardware modified to make them multizone. It may be that the newer discs use a slightly different zone coding and the modified hardware cannot handle this.
Mar 09, 2011 | Televison & Video
American Blu ray dic not playing in my malaysian sony bdp -s370
BD media does have region codes. But, unlike current DVD players, the region codes for BD media use letters instead of numbers to indicate a particular zone or region where the discs can be played.
The BD region codes are as follows:
  • Region A: North America, South America, U.S. Territories, Japan, South Korea, Taiwan, and other areas of Southeast Asia
  • Region B: Europe, Africa, Middle East, Australia, and New Zealand.
  • Region C: Asia (except for Japan, Korea, Taiwan, and other areas of Southeast Asia)
Jan 21, 2011 | Sony BDPS370 BluRay Player
How to play region A blu ray discs on region c Blu ray player. i have bought this player in India but would like to play BD discs got for USA, and the player does not plays such disc.
The Player will not play the Blu-ray discs other than Region C.
This is because all the Blu-ray/DVD Players are designed such way that it will play only the discs that are manufactured and sold in the same country where the Player is manufactured.
You can play the discs that are "Region ALL".
However, you may try copying the content of the Region A/B Blu-ray discs to a Computer then create a video Blu-ray disc to check whether you can play them in the BDPS370.
Jul 21, 2010 | Sony BDPS370 BluRay Player
Blue ray disc want play in samsung bd p1600
Is your software up to date. If player has old software and you try playing some newer Blurays, it wont play.
Feb 03, 2010 | Samsung BD-P1600 Blu-ray Disc Player
Why is it that my LG BD 360 will play most bku-ray
I have the same problem with the same movie you need to connect the bluray player to your modem and update the bluray to be able to watch newer blurays
Jan 01, 2010 | LG BD370 BLU RAY PLAYER
How to region free code for JBL DVD PLAYER CINEMA SOUND 3
The model number would be helpful as well. Below are a few universal process's for JBL dvd players. Not 100% guaranteed..
Give them a try, if they don't work then post the model number for further info.
PROCESS 1
1. Turn on player without disc and wait for "no disc"
2. Press OSD on remote control
3. Press 314159
4. Press 0 for region 0 (or 2 for region 2, etc.)
5. Turn off player with 'off'
6. Ready.
PROCESS 2
1) Open DVD tray
2) Press and hold "6" button on remote control.
3) Press "Menu/PBC" button. The current region code will be displayed on screen.
4) Keep pressing the "Menu/PBC" button until the preferred region code is selected (0,1,2,3,4,5,6).
5) Press and hold the "Angle" button for more than 2 seconds to save the region code. "Writing Region ID" will appear on screen.
PROCESS 3
Volume off
Slide Open
Press volume+ for 3 sec on remote
Then press Language on remote fast
Then choose 0 for region free
Press ok
Good luck , let me know if one of them work. Thank you for trying Fixya!
Mar 21, 2009 | Televison & Video
Televison & Video Logo
209 people viewed this question
Top Televison & Video Experts
Electro Med Services...
