Question about Baygenie eBay Auction Sniper Pro
Time left indefinite - Baygenie eBay Auction Sniper Pro
Harmon nuvi 1300 won't go into preboot. I've tried everything I can imagine (power on touching each corner) none working even center. Tried holding the power button, loads up to garmin then powers off
Pre-boot mode is accessed by powering off the device and touching the left upper corner of the screen, while plugging in the USB cable into the unit with the other end already inserted into the USB port of a PC. Please note that pre-boot mode has a time limit and does not stay on indefinitely.
Jan 22, 2016 | Garmin GPS
How can I disable the programmable function and just use as a conventional thermostat
5. Temperature Adjustment
Extended Hold (Vacation) Mode
1. Press the HOLD button to bypass the program schedule. The current set point temperature will be held either permanently or for 24 hours, depending on the setting selection made in section 4.
2q==
2. Press the
HOLD button again to return the thermostat to the normal program operation.
3. The hold period will last until the hold is released as in step number 2 above, or is limited to 24 ours if the default was changed in the User Options Settings (see section 4).
4.Programming User Settings
Setting the Extended Hold Time (see also section 6)
The default setting is Long (indefinite) Hold. If the HOLD feature is activated, the current set point will be held until HOLD is released.
1. In normal operating mode, press and hold the
RETURN button for 4 seconds. Press RETURN again to skip past differential setting. The display will show "HOLD LG", where LG is indefinite hold.
z
2. Press the or button to change the Extended Hold time from indefinite (LG) to 24 hours (SH).
3. Press the
RETURN button again to set the Filter Check Monitor or wait 30 seconds for the thermostat to return to the normal mode.
6.Additional Operation Features
Resetting the Thermostat
The Reset feature allows the user to completely reset the thermostat to register new manual switch settings.
1. To erase all entered programs, current time of day, day of week and other user settings, gently press the
RESET button using a paper clip or a small pencil tip.
2. This will return all thermostat settings to their default values and register all new manual switch settings for proper operation (incl.
Extended Hold = Indefinite).
Dec 28, 2014 | Proselect PSTS21P52 Programmable 2 Stage...
My Honeywell T8001C doesn't allow me to change the indefinite temperature hold for some reason
It sounds like the thermostat is malfunctioning; the Set should not be flashing at all, only the Hld should show after pushing the hold button.
Do you have a new battery in the unit? Is it set to Heat or Cool? Is it already programmed for current Time/Date and does it have a schedule programmed in already? If you've lost the user manual it's here: https://customer.honeywell.com/resources/Techlit/TechLitDocuments/69-0000s/69-1431.pdf
Jul 06, 2014 | Honeywell Programmable Thermostat Heater
Is there a way to calculate indefinite integrals (anti-derivatives) with the Casio FX-115ES?
No. The calculator can compute definite integrals by numerical integration, but it does cannot do indefinite integrals.
Feb 11, 2011 | Casio FX-115ES Scientific Calculator
How long should i recharge the battery?
Most all rechargeable vacuums are fine if left plugged in indefinitly. What make and model ? how old ?
Dec 05, 2010 | Vacuums
Can i leave my digital frame playing all the time
There should be little problem with it being left on all the time, the frame should be able to run indefinitely with little defect. Make sure there is nothing like drapes or books etc around the frame so it can give off the heat that will naturally occur from being left on all the time.
Feb 22, 2010 | Kodak EasyShare EX1011 Digital Picture...
When I turn it on, it says 'warming up...' indefinitely. what do i do?
I had this problem several times. I used to unplug it for a short time and then restart it. worked everytime for me.
Nov 14, 2009 | HP Officejet 6310 All-In-One InkJet...
No Heat on Whirlpool Gas Dryer
The timer should advance in the time dry cycles if it does, it is fine Its common for them to not in automatic cycles when there is no heat I would call for service unless you have basic gas appliance knowledge , as it is dangerous If you decide attempt i can tell you what to look for Please rate my help .....Thanks
Oct 02, 2007 | Dryers
Computers & Internet Logo
19 people viewed this question
Top Baygenie Computers & Internet Experts
David Payne
David Payne
Are you a Baygenie Computer and Internet Expert? Answer questions, earn points and help others
