Question about 1994-1997 Infiniti J30 Designer Auto Mat Floor Mats DM-IN-109R-1029 - Carpet
Horn won't shut off
Car horn goes off randomly and won't shut off until I disconnect the battery while parked and not in i. Also blinker lights on dash stay on solid when blinkers are not being used.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
Sound like a defective horn switch shorting out.
Posted on Nov 24, 2013
  • 46 Answers
Sounds like the problem lies withing your steering column. Check for shorts... Pull horn fuse in the mean time...
Have electrical issues on a 2004 mazda 3.
I would check every single fuse in the car. Blown fuses can cause weird issues like this. While the initial issue with the mechanic does sound like an alarm problem....the rest does not unless the shop that installed it really butchered the job.
Jul 18, 2016 | 2004 Mazda 3
1998 cadillac horn goes off randomly
Sounds like a bad horn button which is actually part of the airbag. Replace your airbag. They're cheap on e-bay and it's not hard to do. Just make sure you disconnect the battery before doing any airbag work.
Mar 21, 2014 | 1998 Cadillac DeVille
My car battery got dead so I bought new battery and tried to replace the old one. As soon as I reconnected the terminals of the new battery the car started making panic horn noise. Its horn alarm goes on...
On some models you can disable the alarm after you connect the battery by locking and unlocking the driver door with the key.
I would disconnect the horn or pull the relay until you can get the alarm turned off.
Sep 25, 2013 | 1999 Toyota Corolla
1997 Lincoln Continentalhorn won't stop honking
First, Have your Battery tested. The Alarm systems in Ford made Products are very sensitive to Voltage. There are 3 systems in the car which interrupt power, the Alarm system (horn honking) and the Battery saver and finally the starter interlock system.
The Alarm system will do several things to disable the car from starting. It will reduce the voltage to the starter to prevent the engine from turning over. Some will even kill the ignition system so that if the starter is jumped, the car still won't start.
The Battery saver will disconnect any system to prevent discharge below a minimum threshold. Unfortunately, when the Alternator is working extra hard to charge a really bad battery: it will disconnect the charging circuit because it reads the Draw going to the Alternator to produce the power as a parasitic drain. Even at 70mph I have seen the charging disconnected and the vehicle coast to a stop when the electric runs out.
The last system worth mentioning is the Starter interlock. Under the dash and at the top of the Brake pedal lever is a switch. When you press the brake pedal, the switch allows the starter to crank provided the shifter is not in D or R. Drivers feet routinely hit this switch and either move it or break it. When it breaks it can short and drain the battery.
As you mentioned a Random problem, the Brake switch can shake to create a random problem if it is loose or broken. Your rear brake lights can be affected.
With the horn honking, at least part of your problem is the Alarm system. You can have a bad ignition switch too, which reads the keychip to disable the alarm. Your keychip may be bad and setting off the Alarm.
I had a new Lincoln myself which set off the Alarm randomly. I actually slept inside the car one night so I could turn off the alarm in the Apartment complex parking lot. Did'nt know if it would start again if the battery was disconnected and then reconnected. The Battery was shorted with less than 1000 miles on the car. It was a factory defective battery less than 3 months old.
But your car has many years and miles on it so it was worth mentioning the wear items. I hope my solution is helpful.
Sep 07, 2012 | 1997 Lincoln Continental
The Alarm keeps going off , previous owner cut the horn wires so that part doesnt work but the lights just randomly start blinking and going on and off and cant cut it off. remote key chain is no longer...
The day time running light module on the back side of the front drivers fender likely needs to be replaced to fix your problem.Unplug it and the lights will work normally from the headlight switch but the day time running lights won,t work and also the high beam indicator light in the dash won,t come on when you switch to high beam but all the lights will work properly.You should replace the drl module as soon as you can but unplugging it will at least keep you from having to remove a battery cable.
Sep 17, 2010 | 1993 Dodge Dynasty
Horn honks randomly but wont shut off until I hit horn on wheel. Need to remove fuse until can get it to mech so it wont go off in the middle of the night. My manual says the fuse for horn is on pass side...
open hood (bonnet) and disconnect battery cable but do not close hood tight .vehicle's that we do not know MAKe ,MODEL,YEAR are hard to help fix any thing on
Dec 28, 2017 | Cars & Trucks
1996 Chrysler Cirrus horn wouldn't stop beeping too!!!
was it hot outside-heat could deform the steering wheel horn pad and make the horn go off,remove the horn pad and airbag unit(take fuse out for airbag system wait a few mins)then put the fuse that you removed back in place and see if the horn goes off again.
Sep 18, 2009 | 1996 Chrysler Cirrus
Car horn and lights sound alarm @ random times while parked
Alarm Disarm LIGHT GREEN (-) DRIVER'S KICK PANEL
Jun 10, 2009 | Aiwa CDC-X504MP CD Player
1994-1997 Infiniti J30 Designer Auto Mat Floor Mats DM-IN-109R-1029 - Carpet Logo
90 people viewed this question
Top Intro-Tech Automotive Vehicle Parts & Accessories Experts
David Harrelson
David Harrelson
Lawrence Oravetz
Tom
Are you an Intro-Tech Automotive Vehicle Part and Accessory Expert? Answer questions, earn points and help others
