Question about Intel DH55TC Motherboard
How to use usb power after shut down - Intel DH55TC Motherboard
My powered USB port on my Dell Latitude D410 shorted out. Can this be repaired/replaced?
The USB plug will need to be removed from the computer, if luck is with you the computer will work, if no part is available, use a none powered USB hub on a spare port if available to run your applications.
Jun 23, 2012 | Dell Latitude D410 Notebook
PMP-120 Battery Discharges too quickly
Yes,
you will have power through the usb port, so leave it plugged in.
Even when it is shut down it can drain batteries.
Feb 25, 2008 | iRiver PMP-120 Digital Media Player
While shutting down after downloading pictures, I
Try going to this page at the Nikon site, and work from there. You might find your answer if you start here:
http://www.nikon.com/about/news/2004/0128_03.htm
Good luck,
-a.
Apr 01, 2010 | Nikon Coolpix 3200 Digital Camera
My Deskjet 5440 will not even respond to being plugged in to power or USB. Just a solid green light. Like it's frozen. Computer will not even notice it's plugged in.
shut down the pc, shut down the printer.
power it back on and the pc.
if still does not detect, do the following
on the desktop chose My Computer/right click/System Properties/Hardware Tab/Device Manager/go to Universal Serial Bus Ctl (this will be at the last of the list)/ + click plus sign on the left to expand /go to each and check if all devices are working properly by right clicking go to properties, then go to USB root hub (if there are more than 1 then go to each one by one and do the foll)
go to 1st USB root hub, right click, properties, power management tab, remove the tickmark on the box that says "Allow the computer to turn off power to save power"
Do this for all the USB root hubs listed there.
Shut down PC and restart. Check if now the printer is being detected.
Dec 07, 2009 | HP Deskjet 5440 InkJet Photo Printer
Computer shuts down when I plug in my iphone
if the pc its shutting down when ya plug that device ..this just means that it has some settings against this kinda devices or windows do not recognize it well and it sees it like pest ...and shuts down the pc as protection .....its eiter doesnt have a USB 2.0 port ..or its just a firewall kinda problem ...try it on other pc-s and see if the problem persist there ...if not its from your machine ..if other computers shuts down too ..its from the "bloody " I phone ...might have something in it ..a bug ..or a software protection ...
Jul 06, 2009 | Gateway GT5034 PC Desktop
Cmos checksum bad...usb current status detected system shut down 15 sec
asus manual .pdf bios Version 1301 is the last one what is your version
also does your power supply support 1amp for 5VSB
Apr 05, 2009 | Computers & Internet
Usb ports
hi im josh in cebu phils. may i help you?
Friend if you put something like usb or etc.it shut down. the problem is your power supply.your power supply dont have enough power to gve the new installed device thats why it shuts down.
Feb 21, 2009 | Asrock P4V88 (P4V88 RAID) Motherboard
Power shut down after inserting usb driver or usb mouth
This failure is caused by the usb drivers conflicts, power supply or failure on the motherboard - You can go to the IBM website and check it out more about this issue.
Sep 24, 2008 | IBM ThinkPad T41 Notebook
Laptop keeps shutting off,battery is not on electric cord is connecting.. cord has a slight buzzing from the square is this normal..and i cannot use my usb ports
"Buzzing" from the brick generally means the fields are breaking down. This could also cause a problem to the main board.
Sometimes Radio Shack has the IGO Universal on sale, I paid $28.95 for mine with 8 different tips.
As far as the USB, the northbridge chipset should be updated, google the north bridge after installation and running
Also if the USB's bus is not operating, check the pcmcia card bus, if you install a wireless card or cardbus usb adapter and it hangs you have a motherboard chip issue.
Apr 10, 2008 | Computers & Internet
SHUT DOWN PROBLEM
try to add-on memory that compatible to your computer so that your computer become faster.....
Dec 17, 2007 | ASUS P5PE-VM Motherboard
Intel DH55TC Motherboard Logo
14 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
