Boost wifi range with prolink 9300g
How to turn my old router "Prolink 9300G" as a booster or to extend the wifi range??
2Gigs
  • 141 Answers
SOURCE: modem/router
You need to call your INTERNET SERVICE PROVIDER. You need a USERNAME and PASSWORD from your ISP when you set your modem to bridge. This username and password will serve as your connection authentication. Once the modem is already bridged you have to set the INTERNET CONNECTION TYPE on the router to PPPOe(that is where you type your USERNAME and PASSWORD). When you are already online, you might need to forward the port number for your ip camera for it to work.
Good Luck
Posted on Mar 20, 2008
Bat1956
  • 585 Answers
SOURCE: setup linksys wrt54g2 broadband router with prolink h9200 modem
You probably will need to make some configuration changes in the Linksys router, or in your computer, or both. Your are correct that you connect the Linksys WAN connection to the LAN connection of the modem. If your connection type is PPPOE, you will need to set that up in the Linksys with the username and password provided by your ISP, so the modem will allow you to login and connect to the internet. If that is how you were connecting to the modem with your computer, you will need to configure a new LAN connection in the computer in order to connect to the Linksys. You can then configure the Linksys through your web browser to connect to the modem.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Dec 28, 2008
rahul26485
  • 611 Answers
SOURCE: i have a g wireless router and i do not have any
yes he has the access point you take it
Posted on Mar 28, 2009
  • 10 Answers
SOURCE: How can I open my NAT? It is for playing MW2..
The factory default router address is 192.168.1.1. However, if the router detects a
conflict with the address it gets from your modem, it automatically picks a different
address for itself. In this case, you can log in to the router using
www.routerlogin.net to verify its LAN IP address. Select LAN IP Setup under
Advanced on the main menu. Take note of the LAN TCP/IP setup IP address,
which should match the default gateway IP address on your computer.
Once you get there you will be able to change the settings, I hope this help you, here is also the link for the manual:
ftp://downloads.netgear.com/file/WGR614v9_SM_26Oct07.pdf
Go to page 24. Thanks for using Fixya, don't forget to rate and/or leave a testimonial if it resolved your problem
Posted on Mar 13, 2010
SOURCE: s it possible to use
For that you need to change wireless channel type on router also enable DHCP on router. For that follow below method to access router. You can also RESET it to defaults for that press RESET button for 10 seconds it is in the back side of router then configure it with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Posted on Dec 09, 2010
HOW TO CHANGE wifi password on prolink h5004n
how to change the password for wireless internet in H5004N router
Jan 21, 2013 | Computers & Internet
Nececito el driver de la tarjeta
1. Siga este enlace para la p?gina de descarga:http://members.home.nl/fly2000/download_e.html
2. Puedes buscar "drivers WDM para Philips SAA713x"y haga clic en ?l paradescargar.
3. Abra el paquete de instalaci?n del controlador e instalar.
O simple descarge aqui:
Windows Vista/ 7: http://www2.prolink.com.tw/TVExpert_v1.36-Prolink.zip
Windows XP: http://www2.prolink.com.tw/TVExpert_v1.36-Prolink.zip
Si nada de esto trabaja para usted pues puede tratar lo sigiente:
http://www.freedownloadmanager.org/downloads/ChrisTV_Lite_67906_p/free.htm
Jun 09, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
Can I boost signal strength?
You will need to get hold of a Belkin Wireless G Universal Range Extender relays the signals of your wireless network and extends its range model number F5D7132 from PC world or another online dealer.
You will still need the wireless router as the central connection point, using the booster your network now reaches further I have one at the top of the stairs with the Router downstairs to I can browser wirelessly in the loft conversion of my old house
Oct 11, 2009 | NetGear DG834G Wireless Router
H9601C prolink modem driver
i cannot install prolink h9601 adsl modem on windows xp home edition,, any luck??????
Sep 02, 2009 | D-Link DFM 562IS (DFM-562IS) Modem
I lost my prolink web cam drivers and software
I am making the assumption that your web camera is the Prolink PC1320. If it is the try the following link:
http://www.prolink2u.com/downloads/drivers/accessories/PCC1320_Driver.zip
If this isn't the driver that you need, please let me know and include the model of the camera that you have. I will then find the correct driver/software for you. Binary Bob
Nov 29, 2008 | Computers & Internet
I need driver for prolink mvg-clm30p for winxp.... helpme...please!!
search for them on prolinks website:
http://www.prolink.com.tw/
but 2 mb for real, that sounds like a really old card, it may not be supported by xp.
Nov 27, 2008 | Prolink MVGA-CLM30P, (2 MB) Graphic Card
How to set up a 32bit motherboard
http://www.prolink.com.tw/style/content/CN-08-2cp2/faq.asp?lang=2&customer_id=1470&name_id=36168&fid=521 Sending this link to prolink site all is there for your card.RICHARDM69
Aug 28, 2008 | Prolink PV-BT878P+ w/FM RC
DLink Wireless Extender
  1. move the router,
    the router can be anywhere, as long as it is connected to the modem
  2. reorient the antenna,
    its surprising just how much difference changing the antenna direction has.
  3. ensure the router is broadcasting at 100% power in the router settings page
might not solve the problem, but have worked in the past
Jun 23, 2008 | D-Link AirPlus G Wireless Range Extender...
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
